GPS Waveshare NEO-7M-C (Parallax #28511) First test
NikosG
Hi All,
This is my fist test with Waveshare NEO-7M-C (Parallax #28511) GPS
This GPS is awesome and extremely easy to use and wire . I followed this link http://bit.ly/2pxsaEy and I made the wiring diagram
(you need only 3 cables). Then I wrote the Blockly code (another awesome feature of that product) and here is the result:
I have to say that the module fixed extremely fast the 5 satellites! (I have a Garmin GPS for my car and takes minutes to start)
I took Lat and Long in order to verify my position on Google Maps and here is the result: I can assure you that is by far better from the result from my Garmin!
Till now I had my computer connected to the propeller board via USB, in order to have the coordinates on serial terminal. Next step is to use one LCD
Are you able to test that ?
Thanks for your evaluation.
From your post notes we can get an idea of the horizontal accuracy.
Please can I ask you to do some readings to establish the vertical (elevation) accuracy.
From the internet I found an article which suggests vertical accuracy is about 1.5x horizontal accuracy.
visualgps.net/#visualgpsview-content
This nice soft analyse dilution..... golsnas, galileo, ...
You have to enable all the nmea outputs in the GPS
