Random/LFSR on P2 - Page 4 — Parallax Forums
Random/LFSR on P2
1246792
    Heater. wrote: »
    True enough.
    It's just that when I played with the KISS32 PRNG it would take forever to start looking "random" when seeded with zero or a low entropy seed. Much better to have at least an equal number of zero and one bits.
    So I had to try the 1, 0 seed with xoroshiro128+. It gets into something looking "random" much quicker. Like so:
    0000000000000001
    0080001000004001
    0008402018000121
    8080563010444122
    09d0240b1809c401
    01d82012758940e2
    69b05d703207c544
    df59215fd8d25ee6
    9a652772eb590ca2
    4ba7fb3a655fc1b1
    a44648618c9bfe2c
    d89157b50d9ced27
    431bed2f5777656a
    Does the verilog/PASM version generate the same sequence?
    Yes!!! I'm able to output the 16 LSBs and they match your sequence. Here's what I saw:
    0001
    4001
    0121
    4122
    C401
    40E2
    C544
    5EE6
    0CA2
    C1B1
    FE2C
    ED27
    656A
    7508
    D26F
    44F2
    80C3
    4734
    4DCE
    1CB8
    364B
    3248
    E5DB
    A465
    40D1
    A65F
    CE36
    0C5E
    2CBD
    188D
    66F4
    8A00
    2225
    04EE
    3834
    9344
    602A
    7277
    C0EA
    CAD8
  • Ahle2Ahle2 Posts: 1,179
    edited 2017-03-03 13:57
    Main code
    int main(int argc, char *argv[])
        PRNG prng;
        uint64_t result;
        for(uint32_t i = 0; i < 12345; ++i)
            result = prng.getXoroshiro() >> 1;
        std::cout << std::hex << result;
        return 0;
    In the PRNG class constructor
        s[0] = 1;
        s[1] = 0;
    PRNG get method
    uint64_t PRNG::getXoroshiro()
        const uint64_t s0 = s[0];
        uint64_t s1 = s[1];
        const uint64_t result = s0 + s1;
        s1 ^= s0;
        s[0] = rotl(s0, 55) ^ s1 ^ (s1 << 14); // a, b
        s[1] = rotl(s1, 36); // c
        return result;
  • evanhevanh Posts: 17,317
    edited 2017-03-03 14:09
    It could just be a sample number dependency discrepancy. Out-by-one would yield no match.
    edited 2017-03-03 14:06
    Chip,
    Casting to 16 bits and printing from the beginning gives the exact same sequence as you!
    I lied; It does not! I got the same 32 bit result as Heater though... Something funky is going on!
    Ahle, Heater's and my results match. We seem to have implemented it the same way. There must be some difference in your code.
    Ahle2 wrote: »
    Chip,
    Your result was throwing away the LSB. After I shifted my result by 1 bit, I got your same values from the 12345th iteration, as well as the bigger one.
    I thought we agreed on shifting one step to the right?! Now it gives the same result!
    Ahle2 wrote: »
    In the normal Verilog, I don't use the LSB, but for single-stepping, I made it output result[31:0].
    Okay, we have it working then!
    edited 2017-03-03 14:14
    Now that we know that your P2 implementation matches the original C code I could just use that to feed the test suites with data! :)
    I fixed the error in my xoroshiro128+ PASM code on the first page. Everything agrees between my PASM, my Verilog, Heater's C, and Ahle2's C. Super!
    Ahle2 wrote: »
    Right. There should be no surprises, though, if that xoroshiro128+ page was accurate in its claims.
    edited 2017-03-03 14:32
    I'm not getting the same output from verilog as the C version. I modified my C test harness to output the high 31 bits:
    It starts out well, and many values along the way can be correct. With the odd error thrown in:
    C output:
    0000000000000000
    0040000800002000
    000420100c000090
    c0402b1808222091
    04e812058c04e200
    00ec10093ac4a071
    34d82eb81903e2a2
    efac90afec692f73
    cd3293b975ac8651
    25d3fd9d32afe0d8
    d2232430c64dff16
    ec48abda86ce7693
    218df697abbbb2b5
    1e994ae9f17d3a84
    d34d862e033fe937
    05f696ca131fa279
    3d5db0e43348c061
    263a9c552d81a39a
    25dab82a39faa6e7
    f55244eb04720e5c
    Verilog output:
    xxxxxxxxxxxxxxxx
    0000000000000000
    0040000800002000
    000420100c000090
    40402b1808222091 Err
    04e812058c04e200
    00ec10093ac4a071
    34d82eb81903e2a2
    6fac90afec692f73 Err
    4d3293b975ac8651 Err
    25d3fd9d32afe0d8
    52232430c64dff16 Err
    6c48abda86ce7693 Err
    218df697abbbb2b5
    1e994ae9f17d3a84
    534d862e033fe937 Err
    05f696ca131fa279
    3d5db0e43348c061
    263a9c552d81a39a
    25dab82a39faa6e7
    755244eb04720e5c Err
    Something seems to be going wrong with the top bits.
    Could be my test harness of course...
    I made a verilog test harness:
    module test;
      /* Make a reset that pulses low once. */
      reg reset = 1;
      initial begin
         # 1 reset = 0;
         # 1 reset = 1;
         # 200 $stop;
      end
      /* Make a regular pulsing clock. */
      reg clk = 0;
      always #5 clk = !clk;
      wire [62:0] value;
      rnd r1 (reset, clk, value);
      initial
         $monitor("%h", value);
    endmodule // test
    I use the plain verilog version as I don't have the regscan macro available.
    I run it under Icarus Verilog:
    $ iverilog -o xoroshiro128plus.vpp xoroshiro128plus_tb.v xoroshiro128plus.v
    $ ./xoroshiro128plus.vpp
    Chip, what have you done? I'm writing verilog!
    Heater, you've only got 63 bits in the verilog version. Your C version is outputting higher values than that.
  • TorTor Posts: 2,010
    @Heater,
    On AIX (Power 7) it fails with gcc as well, in 32-bit mode. Although differently than with xlc (IBM compiler). gcc 4.8.3
    All's well with xlc when compiled with -q64.
    '//' comes from C++, so I call it C++ comments, even if it's been adopted by C99 or whatever. Never liked the look of those comments either. I liked the Ada comments though:
    -- this is a comment
    evanh wrote: »
    Yes, Heater needs to change this line:
    wire [63:0] value;
    Heater. wrote: »
    And I'm reading C code.
    edited 2017-03-03 14:48
    I'm running Dieharder as we speak. On my i7-6700K @ 4GHz it will run for 30 minutes or so, using the raw input mode through the pipe mechanism in Linux!
    The data rate is 9.51e+06 random character / sec.
    /Johannes
    Ahle2 wrote: »
    /Johannes
    That's the Chr(0..255) byte rate?
    Yep!
    Ahle2 wrote: »
    Yep!
    Super! I'm going to sleep now, but I'll be checking this thread for the results when I get up. If I could work all day and night, I would.
    edited 2017-03-03 15:14
    No worries, my fault.
    My wire definition was fine. Changing it as suggested causes Icarus Verilog to give a warning:
    xoroshiro128plus_tb.v:17: warning: Port 3 (out) of rnd expects 63 bits, got 64.
    xoroshiro128plus_tb.v:17: : Padding 1 high bits of the expression.
    My C code test harness went wrong because I had a cast to intmax_t rather than uintmax_t so there was a signed shift right going on!
    C and Verilog results match up fine now.
    The C test harness:
    // Exercise the xoroshiro128+ PRNG
    // For 64 bit output Compile with:
    //    $ gcc -Wall -std=c99 -o xoroshiro128plus-test xoroshiro128plus-test.c
    // For 32 bit output Compile with:
    //    $ gcc -Wall -std=c99 -DOUTPUT_32 -o xoroshiro128plus-test xoroshiro128plus-test.c
    // Also works on 32 bit machines (-m32)
    // Note: 64 bit output will never contain zero. 32 bit output can be any 32 bit value.
    #include <stdio.h>
    #include "xoroshiro128plus.c"
    // Seed MUST not be all zero.
    #define SEED_0 ((uint64_t)0x1)
    #define SEED_1 ((uint64_t)0x0)
    #define SAMPLE_SIZE 1000000
    #define HEAD 100
    #define TAIL 8
    int main(int argc, char* argv[])
        uint64_t random64;
        uint64_t i;
        char ellipsis = 1;
        // Seed the state array
        s[0] = SEED_0;
        s[1] = SEED_1;
        // Print some randomness
        for (i = 0; i < SAMPLE_SIZE; i++)
            random64 = next();
            if ((i < HEAD) || (i > (SAMPLE_SIZE - TAIL - 1)))
                 printf("%016jx\n", (uintmax_t)(random64 >> 1));
            else
                if (ellipsis)
                    printf("...\n");
                    ellipsis--;
        return 0;
    Results:
    C output:
    0000000000000000
    0040000800002000
    000420100c000090
    40402b1808222091
    04e812058c04e200
    00ec10093ac4a071
    34d82eb81903e2a2
    6fac90afec692f73
    4d3293b975ac8651
    25d3fd9d32afe0d8
    52232430c64dff16
    6c48abda86ce7693
    218df697abbbb2b5
    Verilog output:
    0000000000000000
    0040000800002000
    000420100c000090
    40402b1808222091
    04e812058c04e200
    00ec10093ac4a071
    34d82eb81903e2a2
    6fac90afec692f73
    4d3293b975ac8651
    25d3fd9d32afe0d8
    52232430c64dff16
    6c48abda86ce7693
    218df697abbbb2b5
    edited 2017-03-03 15:17
    The results are in:
    #            dieharder version 3.31.1 Copyright 2003 Robert G. Brown          #
       rng_name    |rands/second|   Seed   |
    stdin_input_raw|  9.51e+06  |1595572412|
            test_name   |ntup| tsamples |psamples|  p-value |Assessment
       diehard_birthdays|   0|       100|     100|0.83379396|  PASSED
          diehard_operm5|   0|   1000000|     100|0.25558220|  PASSED
      diehard_rank_32x32|   0|     40000|     100|0.52897077|  PASSED
        diehard_rank_6x8|   0|    100000|     100|0.38678624|  PASSED
       diehard_bitstream|   0|   2097152|     100|0.29019586|  PASSED
            diehard_opso|   0|   2097152|     100|0.69787334|  PASSED
            diehard_oqso|   0|   2097152|     100|0.84063566|  PASSED
             diehard_dna|   0|   2097152|     100|0.62916350|  PASSED
    diehard_count_1s_str|   0|    256000|     100|0.92236112|  PASSED
    diehard_count_1s_byt|   0|    256000|     100|0.59253912|  PASSED
     diehard_parking_lot|   0|     12000|     100|0.83699181|  PASSED
        diehard_2dsphere|   2|      8000|     100|0.72079614|  PASSED
        diehard_3dsphere|   3|      4000|     100|0.92494671|  PASSED
         diehard_squeeze|   0|    100000|     100|0.76276892|  PASSED
            diehard_sums|   0|       100|     100|0.35705999|  PASSED
            diehard_runs|   0|    100000|     100|0.95657635|  PASSED
            diehard_runs|   0|    100000|     100|0.65493134|  PASSED
           diehard_craps|   0|    200000|     100|0.12569810|  PASSED
           diehard_craps|   0|    200000|     100|0.33025898|  PASSED
     marsaglia_tsang_gcd|   0|  10000000|     100|0.41365816|  PASSED
     marsaglia_tsang_gcd|   0|  10000000|     100|0.64628534|  PASSED
             sts_monobit|   1|    100000|     100|0.16772087|  PASSED
                sts_runs|   2|    100000|     100|0.91443072|  PASSED
              sts_serial|   1|    100000|     100|0.95551409|  PASSED
              sts_serial|   2|    100000|     100|0.11502741|  PASSED
              sts_serial|   3|    100000|     100|0.24329000|  PASSED
              sts_serial|   3|    100000|     100|0.95246396|  PASSED
              sts_serial|   4|    100000|     100|0.86703713|  PASSED
              sts_serial|   4|    100000|     100|0.94258614|  PASSED
              sts_serial|   5|    100000|     100|0.04708983|  PASSED
              sts_serial|   5|    100000|     100|0.15211892|  PASSED
              sts_serial|   6|    100000|     100|0.30394607|  PASSED
              sts_serial|   6|    100000|     100|0.16023796|  PASSED
              sts_serial|   7|    100000|     100|0.70988015|  PASSED
              sts_serial|   7|    100000|     100|0.75742550|  PASSED
              sts_serial|   8|    100000|     100|0.87835733|  PASSED
              sts_serial|   8|    100000|     100|0.74750865|  PASSED
              sts_serial|   9|    100000|     100|0.06143689|  PASSED
              sts_serial|   9|    100000|     100|0.11206147|  PASSED
              sts_serial|  10|    100000|     100|0.68131394|  PASSED
              sts_serial|  10|    100000|     100|0.16241324|  PASSED
              sts_serial|  11|    100000|     100|0.85577452|  PASSED
              sts_serial|  11|    100000|     100|0.84633148|  PASSED
              sts_serial|  12|    100000|     100|0.25783932|  PASSED
              sts_serial|  12|    100000|     100|0.96519459|  PASSED
              sts_serial|  13|    100000|     100|0.87453165|  PASSED
              sts_serial|  13|    100000|     100|0.80473399|  PASSED
              sts_serial|  14|    100000|     100|0.90976972|  PASSED
              sts_serial|  14|    100000|     100|0.46481592|  PASSED
              sts_serial|  15|    100000|     100|0.33824103|  PASSED
              sts_serial|  15|    100000|     100|0.35972982|  PASSED
              sts_serial|  16|    100000|     100|0.24205718|  PASSED
              sts_serial|  16|    100000|     100|0.58009166|  PASSED
             rgb_bitdist|   1|    100000|     100|0.72455794|  PASSED
             rgb_bitdist|   2|    100000|     100|0.08839988|  PASSED
             rgb_bitdist|   3|    100000|     100|0.72988534|  PASSED
             rgb_bitdist|   4|    100000|     100|0.02537498|  PASSED
             rgb_bitdist|   5|    100000|     100|0.99235347|  PASSED
             rgb_bitdist|   6|    100000|     100|0.92528294|  PASSED
             rgb_bitdist|   7|    100000|     100|0.66209713|  PASSED
             rgb_bitdist|   8|    100000|     100|0.39928028|  PASSED
             rgb_bitdist|   9|    100000|     100|0.09853240|  PASSED
             rgb_bitdist|  10|    100000|     100|0.33874593|  PASSED
             rgb_bitdist|  11|    100000|     100|0.19805425|  PASSED
             rgb_bitdist|  12|    100000|     100|0.89791848|  PASSED
    rgb_minimum_distance|   2|     10000|    1000|0.11514702|  PASSED
    rgb_minimum_distance|   3|     10000|    1000|0.09949151|  PASSED
    rgb_minimum_distance|   4|     10000|    1000|0.71371410|  PASSED
    rgb_minimum_distance|   5|     10000|    1000|0.42679082|  PASSED
        rgb_permutations|   2|    100000|     100|0.28438129|  PASSED
        rgb_permutations|   3|    100000|     100|0.13019670|  PASSED
        rgb_permutations|   4|    100000|     100|0.93910058|  PASSED
        rgb_permutations|   5|    100000|     100|0.34992170|  PASSED
          rgb_lagged_sum|   0|   1000000|     100|0.91389520|  PASSED
          rgb_lagged_sum|   1|   1000000|     100|0.45613194|  PASSED
          rgb_lagged_sum|   2|   1000000|     100|0.49300600|  PASSED
          rgb_lagged_sum|   3|   1000000|     100|0.71010206|  PASSED
          rgb_lagged_sum|   4|   1000000|     100|0.94808677|  PASSED
          rgb_lagged_sum|   5|   1000000|     100|0.98009360|  PASSED
          rgb_lagged_sum|   6|   1000000|     100|0.93957434|  PASSED
          rgb_lagged_sum|   7|   1000000|     100|0.12415484|  PASSED
          rgb_lagged_sum|   8|   1000000|     100|0.67596394|  PASSED
          rgb_lagged_sum|   9|   1000000|     100|0.00508887|  PASSED
          rgb_lagged_sum|  10|   1000000|     100|0.94249200|  PASSED
          rgb_lagged_sum|  11|   1000000|     100|0.60613939|  PASSED
          rgb_lagged_sum|  12|   1000000|     100|0.26155684|  PASSED
          rgb_lagged_sum|  13|   1000000|     100|0.08331932|  PASSED
          rgb_lagged_sum|  14|   1000000|     100|0.99955094|   WEAK
          rgb_lagged_sum|  15|   1000000|     100|0.85131082|  PASSED
          rgb_lagged_sum|  16|   1000000|     100|0.80457554|  PASSED
          rgb_lagged_sum|  17|   1000000|     100|0.36633132|  PASSED
          rgb_lagged_sum|  18|   1000000|     100|0.95989992|  PASSED
          rgb_lagged_sum|  19|   1000000|     100|0.09248094|  PASSED
          rgb_lagged_sum|  20|   1000000|     100|0.79549433|  PASSED
          rgb_lagged_sum|  21|   1000000|     100|0.52583117|  PASSED
          rgb_lagged_sum|  22|   1000000|     100|0.40921376|  PASSED
          rgb_lagged_sum|  23|   1000000|     100|0.58494999|  PASSED
          rgb_lagged_sum|  24|   1000000|     100|0.01392463|  PASSED
          rgb_lagged_sum|  25|   1000000|     100|0.85694357|  PASSED
          rgb_lagged_sum|  26|   1000000|     100|0.63171725|  PASSED
          rgb_lagged_sum|  27|   1000000|     100|0.42951286|  PASSED
          rgb_lagged_sum|  28|   1000000|     100|0.37432100|  PASSED
          rgb_lagged_sum|  29|   1000000|     100|0.97003672|  PASSED
          rgb_lagged_sum|  30|   1000000|     100|0.63896568|  PASSED
          rgb_lagged_sum|  31|   1000000|     100|0.30440336|  PASSED
          rgb_lagged_sum|  32|   1000000|     100|0.93002810|  PASSED
         rgb_kstest_test|   0|     10000|    1000|0.71159167|  PASSED
         dab_bytedistrib|   0|  51200000|       1|0.92653216|  PASSED
                 dab_dct| 256|     50000|       1|0.56538469|  PASSED
    Preparing to run test 207.  ntuple = 0
            dab_filltree|  32|  15000000|       1|0.72218965|  PASSED
            dab_filltree|  32|  15000000|       1|0.70765494|  PASSED
    Preparing to run test 208.  ntuple = 0
           dab_filltree2|   0|   5000000|       1|0.25990946|  PASSED
           dab_filltree2|   1|   5000000|       1|0.51931629|  PASSED
    Preparing to run test 209.  ntuple = 0
            dab_monobit2|  12|  65000000|       1|0.60109807|  PASSED
    Brilliant!
    I think we have a winner.
    edited 2017-03-03 15:33
    I'm running Dieharder on the original P2 LSFR now, but due to the bit reordering it is slow, just 1.82e+06.
    It will take 5 hours to complete! :)
    The first few tests looks like this
    stdin_input_raw|  1.82e+06  |1385337568|
       diehard_birthdays|   0|       100|     100|0.00000000|  FAILED
          diehard_operm5|   0|   1000000|     100|0.00000000|  FAILED
      diehard_rank_32x32|   0|     40000|     100|0.00000000|  FAILED
        diehard_rank_6x8|   0|    100000|     100|0.00000000|  FAILED
       diehard_bitstream|   0|   2097152|     100|0.00000000|  FAILED
            diehard_opso|   0|   2097152|     100|0.00000000|  FAILED
            diehard_oqso|   0|   2097152|     100|0.00000000|  FAILED
             diehard_dna|   0|   2097152|     100|0.00000000|  FAILED
    diehard_count_1s_str|   0|    256000|     100|0.00000000|  FAILED
    diehard_count_1s_byt|   0|    256000|     100|0.00000000|  FAILED
     diehard_parking_lot|   0|     12000|     100|0.00000000|  FAILED
        diehard_2dsphere|   2|      8000|     100|0.00000000|  FAILED
        diehard_3dsphere|   3|      4000|     100|0.00000000|  FAILED
         diehard_squeeze|   0|    100000|     100|0.00000000|  FAILED
            diehard_sums|   0|       100|     100|0.31392291|  PASSED
            diehard_runs|   0|    100000|     100|0.01074318|  PASSED
            diehard_runs|   0|    100000|     100|0.00803469|  PASSED
           diehard_craps|   0|    200000|     100|0.00000000|  FAILED
    Without bit reordering I guess every test would fail!
    Super, Ahle2!
    We've got a much better random number generator now.
    edited 2017-03-03 23:20
    Anyone out there want a programming challenge?
    I think it would be best to take the good 63 bits out of the xoroshiro128+ and come up with sixteen randomly-chosen static 32-bit patterns which each use 32 of those 63 bits. Most of those 63 bits should only be used 8 times across all 16 patterns, while a few will need to be used 9 times, since we only have 63 bits, not 64, from the xoroshiro128+. Each cog will get one of these 16 patterns for its own RND value.
    Here is what the result needs to look like, except those "--" need to become "00".."62" values:
    wire [62:0] x = xoroshiro128plus_output;
    assign rnd = {
    {x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--]} ^ 32'h428A2F98,
    {x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--]} ^ 32'h71374491,
    {x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--]} ^ 32'hB5C0FBCF,
    {x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--]} ^ 32'hE9B5DBA5,
    {x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--]} ^ 32'h3956C25B,
    {x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--]} ^ 32'h59F111F1,
    {x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--]} ^ 32'h923F82A4,
    {x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--]} ^ 32'hAB1C5ED5,
    {x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--]} ^ 32'hD807AA98,
    {x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--]} ^ 32'h12835B01,
    {x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--]} ^ 32'h243185BE,
    {x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--]} ^ 32'h550C7DC3,
    {x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--]} ^ 32'h72BE5D74,
    {x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--]} ^ 32'h80DEB1FE,
    {x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--]} ^ 32'h9BDC06A7,
    {x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--],x[--]} ^ 32'hC19BF174 };
    Those 32'hxxxxxxxx values are fractional parts of the square roots of the first 16 prime numbers. They are there to further distinguish patterns from each other. I know, they have no cryptographic benefit.
  • jmgjmg Posts: 15,200
    ... come up with sixteen randomly-chosen static 32-bit patterns which each use 32 of those 63 bits.
    Since the bits are random, do you need random pickoff ?
    eg you could allocate 4 groups of 32 to 4 COGS and get different results, then you could repeat that byte shifted 4 x, and everyone has a different snapshot of the 128 bits.
    If you really do want random taps, run this RNG to generate some ;)
    edited 2017-03-03 23:38
    jmg wrote: »
    Random pickoff matters, relatively, between sets of 32 bits.
    It's kind of a two-dimensional problem. Some divide-and-conquer is needed.
  • I assume the new FPGA images with this new random number generator will have the same instruction set and encoding as the current v16. Is that correct?
    David Betz wrote: »
    Yes. This is a very subtle change that almost nobody would recognize, in practice.
