Prop Dip 40 Main board
DigitalBob
in Propeller 1
This one of my prop boards with prop plug and ribbon connectors for daughter boards
I don't see any decoupling capacitors on there.
Do you have bypass caps for the Propeller power supply pins under the chip? You really want them, 0.1uF as close to the pins as you can.
