I2C Problem — Parallax Forums
I2C Problem
I have an issue with configuring a PropCam directly from the P2v. Currently, I have a P1 hooked up and all it does is the initialization:)
The initialization is pretty simple and I have transliterated the code directly from Phil's code which appear as comments throughout:
PropCam_Initialize
             mov  i2c_delay,##400
             'set serial snapshot
             mov  i2c_address,$88
             mov  i2c_register,#1
             mov  i2c_setting,%0100_0001
             call #_Configure
             'set exposure
             waitx i2c_delay
             mov  i2c_register,#3       'register 3 sets lower byte of _EXP
             waitx i2c_delay
             mov  i2c_setting, ##_EXP  'set exposure
             call #_Configure
             waitx i2c_delay
             mov  i2c_register,#5       'register 5 sets upper byte of _EXP
             mov  i2c_setting,##_EXP
             shr  i2c_setting,#8
             call #_Configure
             ret
_Configure
             setb outa,#_SCL   'outa[Scl]~~
             waitx i2c_delay
             clrb dira,#_SDA    'dira[Sda]~
             waitx i2c_delay
             clrb outa,#_SDA    'outa[Sda]~
             waitx i2c_delay
             setb dira,#_SDA    'dira[Sda]~~
             waitx i2c_delay
             clrb outa,#_SCL     'outa[Scl]~
             mov i2c_data,i2c_address         'i2c address
             call #_Write_i2c
             mov i2c_data,i2c_register        'which register
             call #_Write_i2c
             mov i2c_data, i2c_setting        'register setting
             call #_Write_i2c
             waitx i2c_delay
             waitx i2c_delay
             waitx i2c_delay
            ret
_Write_i2c
  {{ This section is Low-level I2C write method from Phil's code:
  '' `Parameters:
  ''     `data: byte to write to I2C
'  repeat 8
'    dira[Sda] := i2c_data & $80 == 0
 '   outa[Scl]~~
 '   i2c_data <<= 1
'    outa[Scl]~
'  dira[Sda]~
'  outa[Scl]~~
'  repeat while ina[Sda]
'  outa[Scl]~
           mov     i2c_reps,#8
           mov     i2c_bit,#7
DataByte_Out
           isob   i2c_data,i2c_bit   wc
           setbc  dira, #_SDA
           waitx  i2c_delay
           setb   outa, #_SCL
           waitx  i2c_delay
           clrb   outa, #_SCL
           sub    i2c_bit,#1
           waitx  i2c_delay
           djnz   i2c_reps,#DataByte_Out
           waitx  i2c_delay
wait5   isob   ina,#_SDA wc           ' repeat while ina[Sda]
          if_c jmp #wait5          '<<<<<--------- hangs here
           waitx i2c_delay
           waitx i2c_delay
           ret
I have highlighted a place in the code, (4 lines from bottom) where it hangs. If I insert a simple delay rather than the Boolean, it returns but the initialization fails.
I must be doing something pretty stupid to mess it up, but for the life of me, no clue:)
Ideas?
