C'mon... 34-Cent Stereo Amp 2x3W? 29-Cent Battery Savior?
Can these be for real? Five pcs for $1.69: http://www.ebay.com/itm/201574969988
I have a pile of 386 amps but I gotta try these out, that price seems cheaper than free. Small board.
Another noteworthy tiny board (practically microscopic at about 1/8" x 5/8"), is this 29-cent (OK, ten pcs for $2.89) Li-Ion battery protection chip, which claims to do it all. Overcharge protection, over-discharge protection, short circuit protection, overcurrent protection. I just got these in, will test soon. http://www.ebay.com/itm/162025038275
How can you not?? 2.5v to 5.5v operating range - cool!
Good deal it seems - Adafruit sells the mono version (PAM8302) for $3.95 each https://www.adafruit.com/products/2130
Update: Argh, what a waste.. should have gone for the 5 for $1.40 deal: http://www.ebay.com/itm/161995184749
(or ten for $2.80 in a separate deal)
-Tor
Surely you're the only person still using the LM386. This is 2016, my friend -- you know, the 21st century!
(Sorry for calling you Surely.)
Noise and THD are generally worse for class D amplifiers than for analog ones, but the NAS D 3020 specs are pretty impressive. They are at a level where 99.99% or more of audio listeners would not be able to tell the difference between the NAS and a top of the line analog amplifier.
C'mon, if it's a cute little module under a buck, you know I'm on it like stink on a monkey! http://www.ebay.com/itm/200-Times-LM386-Audio-Amplifier-Module-Input-10K-Adjustable-Resistance-5V-12V-/301953923632
I wired one up to some 3 ohm speakers and 4.5V battery pack.
It sounds better than the video - my camera doesn't have the best microphones,
BTW - The eBay specs for the amp indicate that you need two wires for each speaker - do not try to use a common wire for the negative!
Now you have me recalling which songs which 1980's stereo stores blasted to demo their high power stereo's dynamic range and all I come up with is Journey... Don't stop believin'!
My amps came today.
But I have no time to play.
Hoarding anyway.
Bonus points for rhyming!
Damn, now you have to influence me to buy one, will buy these soon!
... and I hoard them for future use!
Yeah, I'm in the middle of repairing a musical clock, so this one helps a lot too!
Care to Super-Size that?
Only in America. And China.
http://www.walmart.com/ip/Scosche-5x7-6x8-4-Way-Speaker-Set/46997824
Supposedly they handle 50 watts RMS - these little amps actually drive them pretty well!
Decided to upgrade the speaker enclosure from an old Sparkfun red box (in my video above) to a solid poplar one:
Looks better and sounds better, of course. Luckily I had a 4 inch hole saw so I didn't have to use a jigsaw for the speaker cutouts...
Pshaw. Get a CNC like the rest of us!
For a really nifty wood-cutting CNC in action, check out Frank Howarth videos on YouTube. His CNC is a more recent acquisition, so fiddle with the later vids. Your drooling can start here:
Thanks for sharing. NOT! Now I know I can't afford my dream shop.
I have the same Dewalt Radial Arm Saw, circa 1965. Still working as well as my circa 1965 Delta (Rockwell) band saw. Handed down from my grandfather, to my father, to me. I'm sure they will last to give to my son.
EDIT: I see this was WAYYY OT for this post.
Thanks for the demo! My boards arrived >10 days ago, but I'm ashamed to say I just looked them over and set them on a shelf. 200 WS2812b LEDs arrived about the same time and they got all the attention. After seeing the class D amplifier at work, I realize I've got to give it higher priority.
Way out of my price range - plus I don't have room for it.
Have to make due with my table saw, drill press, etc.
You ain't alone Ron! IOW this SOB is SOL WRT a CNC.
Have at it, mods! I had my acronym fun.
I put some Wipe-On polyurethane on it.
I decided not to bother with with a divider in this cabinet - since the separation is only a few inches.
You can hear the distinct left/right channels and I won't be pushing big watts thru it.
The speakers were out of an old CD boombox (I taped them in so I could mark the mounting tab holes with a punch).
Might swap out the speakers for some better ones although it sounds pretty darn good with the little Class-D amps.
Though fiberglass is better, you can use white polyfill from Joann's -- costs something like a buck for a sheet, and you'll only need one sheet to try it out. Worth a shot for the non-ported cabinet you've made (without a CNC...).
Thanks!
I was wondering where you could find batting - thought about ripping open an old pillow.
Look for a local fabric store. Even some Wal-Marts have batting, if it has a fabric section.
Thanks. I have a Jo-Ann's fabric store close and a couple of Walmarts...
