Prop2 FPGA files!!! - Updated 4 July 2017 - Version 20
cgraceycgracey Posts: 7,747
UPDATED 4 July 2017 - Version 20
WHAT's NEW:
SKIP/SKIPF/EXECF/XBYTE now allow CALLs in skip sequences, as well as interrupts
XBYTE optionally writes C/Z with bytecode index[1:0]
Pin filtering improved with selectable CT[31:0] tap and 2/3/5/8-sample unanimity
No more changes planned, barring any bug fixes.
smart
	           cogs	  pins	RAM	Freq	CORDIC	Filename
Prop123-A9       | 16	  12	1024k	120MHz	Yes	Prop123_A9_Prop2_v20.rbf
Prop123-A9       |  8	  64	1024k	120MHz	Yes	Prop123_A9_Prop2_v20_64smartpins.rbf
BeMicro-A9       | 16	  12	1024k	120MHz	Yes	BeMicro_A9_Prop2_v20.jic
Prop123-A7       |  4	  38	 512k	120MHz	Yes	Prop123_A7_Prop2_v20.rbf
DE2-115          |  4	  34	 256k	120MHz	Yes	DE2_115_Prop2_v20.pof
BeMicro-A2       |  1	   8	 128k	120MHz	No	BeMicro_A2_Prop2_v20.jic
DE0-Nano         |  1	  10	  32k	120MHz	No	DE0_Nano_Prop2_v20.jic
DE0-Nano Bare    |  1	  10	  32k	120MHz	No	DE0_Nano_Bare_Prop2_v20.jic
DOCUMENTATION:
https://docs.google.com/document/d/154ZiYV1K0sPJQ6DfwvP8ERqJ3WnAqBsM1B_dREwKD9A/edit?usp=sharing
https://docs.google.com/spreadsheets/d/12LZ9KPEy5FEz8aVAG1DBVur36MB2eTVNT4QZ7wgpc-c/edit?usp=sharing
NEWEST ZIP FILE:
https://drive.google.com/file/d/0B9NbgkdrupkHcmk4cWV0dkgxOHM/view?usp=sharing
Older news:
* New RFVAR/RFVARS variable-length, two-clock, unsigned/signed data reading, 1..4 bytes
* TESTB/TESTBN and TESTP/TESTPN (were TESTIN/TESTNIN) now have flag AND/OR/XOR
* XORO32 instruction to iterate xoroshiro32+ long for high-quality repeatable PRNG
* XBYTE now has LSB/MSB-bias selection based on '_RET_ SETQ {#}D' LSB
* 120MHz top speed - your code starts at 60MHZ, use 'CLKSET #$FF' to switch to 120MHz
* New custom bytecode executor with 6-clock overhead (see xbyte.spin2 in zip file)
* SKIPF now behaves like SKIP during hub-exec
* PRNG upgraded to Xoroshiro128+ (accessed via GETRND, was 32-bit LFSR)
* New _RET_ instruction prefix for automatic RETurn, adds 2 clocks in cog exec mode.
* New SKIP/SKIPF instructions for bitmask-based instruction skipping.
* New EXECF instruction for branching plus fast skipping in cog memory.
* Additional ALTxx instructions for reading and writing nibbles, bytes, and words within cog registers.
* Single-stepping/interrupts around REP blocks made consistent between cog and hub execution modes
* 'FLTxx D/#' instructions clear DIR bit and affect OUT bit, read IN bit into C
* 'DRVxx D/#' instructions set DIR bit and affect OUT bit, read IN bit into C
* 2-clock RDPIN/WRPIN/WXPIN/WYPIN with automatic acknowledge
* 2-clock RQPIN ('read quiet') like RDPIN without acknowledge, allows concurrent reading
* Improved booter ROM now runs at 2M baud, thanks to Jmg's ongoing efforts
* ALTB added to facilitate accessing multi-register bit fields (SETBYTS removed)
* Event jumps added: JINT/JNINT/JCT1/JNCT1...
* SETPEQ/SETPNE replaced with SETPAT, C flag picks INA/INB, Z flags picks equal/not-equal
* Improved booter ROM, now supports 3-pin SPI and half-duplex serial
* ADRA/ADRB renamed to PA/PB
* New 'CALLPA/CALLPB D/#,S/#' instructions write D/# to PA/PB and call S/#
* 4 selectable events for pins, locks, and LUT r/w's
* Direct pin DIR instructions: DIRL/DIRH/DIRC/DIRNC/DIRZ/DIRNZ/DIRN D/#
* Direct pin OUT instructions: OUTL/OUTH/OUTC/OUTNC/OUTZ/OUTNZ/OUTN D/#
* Direct pin IN instructions: TESTIN/TESTNIN D/#
* Increment-test jumps: IJZ/IJNZ/IJS/IJNS D,S/#rel9
* Interrupt-triggering instructions: TRGINT1/TRGINT2/TRGINT3
* Support for Prop123-A7 boards added after Tubular fixed PLL problem
* Support for the BeMicro CV A9 board was added
* Hub/eggbeater can now be 16, 8, 4, 2, or 1 slice of cog and hub RAM
* Fewer slices means lower latency
* Cogs' FIFO's are reduced to match slices now, saving logic
* FPGA images are optimized for their number of slices (not all 16, anymore)
* The Verilog source code is now capable of making any sub-version of Prop2
Older zip files:
https://drive.google.com/file/d/0B9NbgkdrupkHdjMxaXRkaWlxR3M/view?usp=sharing
https://drive.google.com/file/d/0B9NbgkdrupkHWVNTY2pSNHRxUkE/view?usp=sharing
https://drive.google.com/file/d/0B9NbgkdrupkHMlVrUjRLd2c5SlE/view?usp=sharing
https://drive.google.com/file/d/0B9NbgkdrupkHRnRtMDFRS0RDOXM/view?usp=sharing
https://drive.google.com/file/d/0B9NbgkdrupkHQkVvaXU1QmVxNXc/view?usp=sharing
https://drive.google.com/file/d/0B9NbgkdrupkHa0hFa01CamZNMms/view?usp=sharing
https://drive.google.com/open?id=0B9NbgkdrupkHRUwxSER4Q3ZXOE0
https://drive.google.com/file/d/0B9NbgkdrupkHMmRKNzNpLW5BdTg/view?usp=sharing
https://drive.google.com/file/d/0B9NbgkdrupkHRWswaUdaS1g0SjQ/view?usp=sharing
https://drive.google.com/file/d/0B9NbgkdrupkHUVZOdE5WLS1vaEE/view?usp=sharing
https://drive.google.com/file/d/0B9NbgkdrupkHMDBEejlldDh6eTQ/view?usp=sharing
https://drive.google.com/file/d/0B9NbgkdrupkHWnJobU5oajVoYUU/view?usp=sharing
https://drive.google.com/a/parallax.com/file/d/0B9NbgkdrupkHVklDQ0J5TzZpRVE/view?usp=sharing
https://drive.google.com/a/parallax.com/file/d/0B9NbgkdrupkHN0t6NjFFZnNnOWc/view?usp=sharing
https://drive.google.com/file/d/0B9NbgkdrupkHSThLdkFVZVA3ZWc/view?usp=sharing
https://drive.google.com/file/d/0B9NbgkdrupkHRTlOUWVWMXBJYU0/view?usp=sharing
https://drive.google.com/file/d/0B9NbgkdrupkHUlZjWkI4ZlRLQVk/view?usp=sharing
https://drive.google.com/open?id=0B9NbgkdrupkHRTFfeG9POU42YzA
https://drive.google.com/file/d/0B9NbgkdrupkHZi01dWdDdWZ2VTA/view?usp=sharing
https://drive.google.com/file/d/0B9NbgkdrupkHS0dPbDkwZVRneXM/view?usp=sharing
https://drive.google.com/open?id=0B9NbgkdrupkHS0tacW5wNndFb0U
https://drive.google.com/open?id=0B9NbgkdrupkHNE1NdVNaSWFKbEk
https://drive.google.com/open?id=0B9NbgkdrupkHN2E1bkk2YW5tZGs
https://drive.google.com/open?id=0B9NbgkdrupkHV3h0dTV2ZGZmVkk
https://drive.google.com/open?id=0B9NbgkdrupkHbTZ2U2ZNN1gzRVk
https://drive.google.com/open?id=0B9NbgkdrupkHVDA2Vm5hN1FwaTA
https://drive.google.com/open?id=0B9NbgkdrupkHZE1FMDNnUVJydlU
https://drive.google.com/open?id=0B9NbgkdrupkHWW94bW5HLXc2N0E
https://drive.google.com/open?id=0B9NbgkdrupkHbkliR0YtZGFUbE0
https://drive.google.com/file/d/0B9NbgkdrupkHSEhHOFROWk52cXc/view?usp=sharing
https://drive.google.com/file/d/0B9NbgkdrupkHR2dBcjZYZEpnWlE/view?usp=sharing
«13456787
  • 2602 Comments sorted by Date Added Votes
  • Thanks Chip!
  • David Betz wrote: »
    Thanks Chip!
    I trust you have that add-on board we made?
  • Thanks Chip! :)
    Melbourne, Australia
  • cgracey wrote: »
    David Betz wrote: »
    Thanks Chip!
    Yes, I have the original DE2-115 add-on board. I don't have the revised one that was released more recently. Is the original one okay?
    David Betz wrote: »
    Thanks Chip!
    If it looks like this:
    1328 x 747 - 291K
  • Chip
    P2 loaded into Prop123-A7 Ok.
    16 cog leds program blinks ok.
    No DAC output from sin_cos_dacs.spin? :(
    What are your dac clock pin assignments?
  • That's the one I have. I think there is a newer version with mounting holes on either side of the header. I just powered up my DE2-115 board and it is still running the most recent P2-hot image so I guess everything is working. I get a monitor prompt. I'm now downloading Quartus so I can program the new FPGA image. Thanks!!
  • Thanks Chip, I'll have a play now, and let you know how it goes.
  • ozpropdev wrote: »
    Chip
    I just poked my scope into the upper VGA pin receptacles. It's outputting on Dac0 Green and Blue.
  • Baggers wrote: »
    Thanks. Without doc's, it's kind of an adventure game.
  • All the more fun :D
  • It's neat to think how in the blink program, every cog is running in hub-exec simultaneously. That egg beater is going to town. All this time, I've just been doing one-cog compiles for testing. I've never seen it all work together, until tonight.
  • Ok, confirm dac0 green and dac0 blue working.
    cooment in code tricked me
    'Goertzel mode, output sin/cos on dacs 1/0
    Scope was connected to Dac0 red and dac1 red
    Schematic refers to dac0 and dac1, pcb overlay refers to dac0 to 5.
  • cgraceycgracey Posts: 7,747
    edited September 2015 Vote Up0Vote Down
    ozpropdev wrote: »
    We are swapping those signals around on the A9 board so it makes sense. Sorry about that. You might have heard about Mixed-up Signal Processing.
  • Thanks Chip, I am dusting off my DE2-115 and the add-on and see how it goes :)
    TACHYON DEMONSTRATOR
    Brisbane, Australia
  • I hate to admit it but I seem to have lost the instructions for programming an image into the DE2-115 board. I have the programmer downloaded but I'm not sure how to configure it to program Chip's image. Can anyone give me instructions?
  • ozpropdevozpropdev Posts: 1,860
    David
    On DE2-115 set switch on left side to program
    In Quartus programmer
    Mode - Active serial programming
    Open file DE2_115_prop2.pof
    Check pconfigure
    Press start
    P.S.: USB cable connected to USB Blaster port top left corner of DE2-115.
    Prop plug on adapter board (logo facing away from you)
    David
    Open file DE2-115_prop2.pof
    Check pconfigure
    Press start
    Thanks! I made the mistake of trying to use JTAG mode and "Find Device". That doesn't work. :-)
  • Ugh. Now I can't use PNut.exe to load a program because my PropPlug got assigned COM24.
    Never mind. I went into the device manager and reassigned it to COM2 and I now have 9 LEDs blinking! I assume that means that there are 9 COGs implemented on the DE2-115?
  • Could you go into windows device manager, show hidden items, then delete one of the com ports thats not being used, but allocated to one of the lower port numbers?
    David Betz wrote: »
    Press Ctrl-G to "Get Hardware Version"
    532 x 158 - 22K
    607 x 162 - 27K
    David Betz wrote: »
    David Betz wrote: »
    I just noticed that before I read your message. Very nice! Now, does anyone have a serial driver that will work with this image?
  • RaymanRayman Posts: 8,245
    Guess it's time to unbox my Parallax DE2-115 board... Got it that April 1 when P2 was too hot and wasn't a joke... Been sitting in unopened box since...
    Thanks for the screen shots, answers a question about what we get with DE2-115...
    Looks like 9 of 16 cogs (as mentioned) and 256 of 512 kB.
    Prop Info and Apps: http://www.rayslogic.com/
  • Hey! It's Saturday morning, here in the States, don't any of you guys have chores to do? Errands to run? Honey-do's to do? Kids to tote to soccer? Wives to appease? :(
    ...at least I can dream of P2 a bit more while I chore my way around the house.
    MOV OUTA, PEACE <div>Rick </div><div>"I've stopped using programming languages with Garbage Collection, they keep deleting my source code!!"</div>
  • mindrobots wrote: »
    You're right! Time to head to the dump...
  • Great job Chip!
  • I think I almost understand the blinky example, but some things look magic...
    What does "orgh 1" do? Why not just orgh ? Does this code start at $1000 (I think so)?
    The last two lines with org and res x are hurting my brain...
    Does the compiler load anything after "org" into cog before starting?
    Or does this only work for "res" reserved space that doesn't need initializing?
  • I think I see both Parallax DE2-115 add on boards and the FPGA123 board have a 40-pin header for access to P2 digital I/O.
    Unfortunately, they are wired differently.
    Looks like the DE2-115 board with give me P0..P28 with 3.3 V I/O on 40-pin header.
    FPGA123 appears to give P0-P31 with 3.3 V I/O on 40-pin header.
    Do I have this right?
  • After getting DE2 out, visitors came, they've now gone and I've got it booted up and LEDs flashing! :D
    Time to play!
    Thanks Chip :)
