Crystal/PLL+ Prop issue?
TymkrsTymkrs Posts: 533
edited 2014-10-12 - 15:29:32 in Propeller 1
Hi all,
Question! We designed a board with Prop1 (of course) and added a 5mHz crystal (as expected). Ran it through its paces and ran code on it and it was doing fine. However, after a couple of days of doing that, the code "stopped running". So we could still compile to the RAM and EEPROM, but the code wasn't doing what it was supposed to. So for example, we used a multimeter on a Prop pin to see if a 1/0 could be seen, and it couldn't.
We then switched out the crystal information with RCFast, and the code ran. We tried then to see what would happen if we ran it only with XTAL1 and it ran fine (or rather we could see voltage from the pin we measured) and as soon as we added any form of PLL to it, it stopped working. We also replaced the crystal just in case it was a malfunctioning crystal.
Has anyone else come across this issue before? Ie, what causes the phase lock loop on the chip to go bad?
Many thanks for any insight!
Addie
Whisker is a hardware and wetware hacker, and produces geeky content on a daily basis. Atdiy is a cardiovascular nurse by day and an electronics n00b at night. Together we're the Toymakers (Tymkrs) and we post videos/blogs on electronics, DIY projects, and whatever else we happen upon! Visit us at http://tymkrs.com, http://zombietech.tv, and http://firstspin.tv! Our projects are on https://www.reddit.com/r/Tymkrs/ and you can chat with us daily at #tymkrs!
  • Phil Pilgrim (PhiPi)Phil Pilgrim (PhiPi) Posts: 22,440
    edited 2014-10-07 - 19:02:33
    Yours is a well-known symptom (i.e. PLL dies) of bad power distribution and/or inadequate bypassing, Please post a schematic and an image of your layout, and we will take a look at it.
  • Mike GreenMike Green Posts: 22,917
    edited 2014-10-07 - 19:42:28
    When there's inadequate power bypassing close to the chip and/or the power traces leading to different sides of the chip go by somewhat different paths of some length (large fractions of an inch say), there can be a transient voltage difference between two points on the Vdd or Vss busses on the chip. This can be enough to damage part of the chip. The PLL multiplexor happens to be the most vulnerable and first to blow.
    The best way to design this out is to copy one of Parallax's designs, at least as far as power distribution near the chip. You'll notice that there are at least two bypass capacitors very close to the chip, one on each side. The multiple Vdd pins and multiple Vss pins are each connected together, usually under the chip so the traces are very short.
  • TymkrsTymkrs Posts: 533
    edited 2014-10-08 - 14:57:29
    Hmm - here's a snapshot of the layout for the bypass caps. I have 0.1uf bypass caps on all 4 vdd/vss pairs and they're connected - power connected on the top layer, and ground connected on the bottom layer of the board.
    There's also a ground plane on the bottom of the board, but I've undone the fill for the sake of the picture.
    809 x 630 - 39K
  • Peter JakackiPeter Jakacki Posts: 8,641
    edited 2014-10-08 - 16:59:34
    Tymkrs wrote: »
    Well that part looks fine then but the component in the top left hand corner has a +5V supply but a pin goes from there direct to the Prop which is a problem if the component is sending a 5V signal into a 3.3V Prop.
    --->CLICK THE LOGO for more links<---
    P2 +++++ TAQOZ INTRO & LINKS +++++ P2 SHORTFORM DATASHEET
    P1 +++++ Latest Tachyon includes EASYFILE +++++ Tachyon Forth News Blog
    Brisbane, Australia
    edited 2014-10-08 - 17:14:34
    Nope, that module's just listening for a signal from the Prop, not sending anything into it.
    Also a new oddity. When I run the code with just xtal1, the leds that I'm turning on and off are taking say 500ms to go through their cycle instead of the 10ms that I want it to go at. When I use RCT fast, the LEDs are going faster (as I expect)
    edited 2014-10-08 - 17:41:08
    Tymkrs wrote: »
    That's a bit strange too. Looking at the crystal I have always said that these huge gull-wing HC49 crystals are just wrong, they really are a kludge adapted from a standard through-hole HC49 but bending out the leads turns them into big antennas and creates routing problems. So much easier and better to use proper SMD crystals (5x3mm etc) or even cheap oscillators which are very compact as you can see, but that's my take on things.
    Now anyway, I've gleaned enough info from your board to know what all the pins bar a couple are doing so the only other thing I don't know about is the regulator, if it's LDO it has to have the right cap on it's output, usually 10uF tant for it to remain stable. If it doesn't and it oscillates then you can rather large voltage swings. So at present I'm scratching my head too.
    1023 x 899 - 683K
    Brisbane, Australia
  • Hal AlbachHal Albach Posts: 747
    edited 2014-10-08 - 18:42:40
    Recently I had a Project Board USB exhibit similar conditions that you are having. Everything worked according to Hoyle while running under RCFast, but as soon as I selected the crystal for a clock source everything came to a screeching halt. Thought I had a bad crystal, tried some others I had laying around. None of them would work. Removed the crystal and ran the multi-led blinking program using just the PLL, program did run but hideously slow. Leds would come on and off in 3 - 4 minute intervals when it should have run infinitely. faster. It sort of seemed like the PLL was triggering on 60Hz from nearby sources. I had a 6 MHZ oscillator (the four legged kind) and connected it to the appropriate crystal pin and the prop came back to life on all cylinders. With the PLL set for x16 the program ran as expected - very fast.
    What I'm trying to get across is that the PLL may very well be your problem, or it could be the crystal driver in the prop that is not working, which was my case. However, given that you have a custom board made for this one, hanging an oscillator on it will be rather ugly and impractical.
    Florida, between St. Petersburg and the Gulf of Mexico
    Do not look directly into laser with remaining good eye...
  • Cluso99Cluso99 Posts: 15,398
    edited 2014-10-08 - 18:45:47
    While I do a few things different too to help with overclocking, I cannot see anything that would cause the PLL to die either.
    How did you solder the prop? Perhaps it got too hot???
    Have you tried a second board just in case???
    Website: www.clusos.com
  • jmgjmg Posts: 13,918
    edited 2014-10-08 - 19:46:38
    Hal Albach wrote: »
    .. I had a 6 MHZ oscillator (the four legged kind) and connected it to the appropriate crystal pin and the prop came back to life on all cylinders. With the PLL set for x16 the program ran as expected - very fast.
    Trying an external Osc is a quick and easy sanity check, and can confirm if the PLL is actually toast.
    edited 2014-10-08 - 19:54:42
    That's a really good clue! It means your crystal is oscillating -- if at all -- at a much lower frequency than expected. As a consequence, its frequency is lower than 4 MHz, the lower limit for successful PLL driving, so the PLL is not able to lock.
    I would replace the crystal with another one. BTW, what's the part number of the crystal you are using?
    edited 2014-10-08 - 21:35:12
    OP said in top post "We also replaced the crystal just in case it was a malfunctioning crystal."
    Brisbane, Australia
    edited 2014-10-09 - 00:35:39
    'Missed that, obviously, but still: the crystal is apparently not oscillating at 5 MHz. What would cause that? The wrong drive setting? Maybe XTAL1 is not appropriate for that particular crystal. A check of the XO pin with an oscilloscope would reveal a lot.
    edited 2014-10-09 - 03:08:54
    You need an 18-20pF xtal. Maybe your xtals are quite different and therefore not oscillating correctly (as suggested).
    edited 2014-10-09 - 12:29:00
    I'll have to get the specific part number when I get home, but it's a 20pF 5.0mHz crystal
    edited 2014-10-09 - 12:32:31
    edited 2014-10-09 - 12:39:44
    jmg wrote: »
    If you don't have a 5MHz Osc Module handy, but do have a spare Prop Board, you could output 5MHz to a pin on that, using a counter, and wire that to the suspect Prop, as an external osc equivalent.
    You can also run the same code in the suspect prop, and use a freq counter to check PLL operation, and no-pll cases are as-expected.
    What loads is this driving, and what sort of energies ?
    edited 2014-10-09 - 12:42:33
    That crystal should work fine. Check to make sure the affected leads on the Prop and on the crystal have good solder connections and that there are no hairline breaks in the traces leading to the crystal. I've seen intermittent problems resulting from both of these causes. Do you have an oscilloscope? Checking the XO output will tell you -- and us -- a lot about what's going on. Also, check to make sure that all of the Prop's power and ground leads have good solder connections. One bad connection there could destroy the PLL.
  • RaymanRayman Posts: 9,716
    edited 2014-10-09 - 12:55:08
    You probably already did this, but make sure you have good continuity between Prop xtal pins and the xtal...
    Prop Info and Apps: http://www.rayslogic.com/
    edited 2014-10-09 - 19:29:48
    Agreed. That xtal should work. Perhaps you inadvertently destroyed the xtal osc / pll while probing - just a thought???
    Can you build another board???
  • LawsonLawson Posts: 870
    edited 2014-10-09 - 22:33:37
    If you're mixing 5v and 3.3v logic on the board and any of the 5v signals to the propeller idle at 5v it's pretty easy to pull the 3.3v rail higher. Most regulators won't sink excess current to hold a power rail down to the set point. (exceptions are some uA LDO's, reference regulators, and some switching power supplies) I've gotten caught by this one recently.
    I've also found that the Prop's XTAL oscillator to be touch sensitive. I've stopped it several times by poking at the wrong spot with my fingers. A power cycle has always re-started the crystal just fine though.
    micro-power experiments with the propeller.
    Drivers for TAOS TSL3301 line sensor Forum thread, and OBEX
    Lumen Electronic Jewelery Website
    My AWD motorcycle Website and action video
    What I'm paid to work on. UW Lidar Group.
    FME, a Spin-only floating point library with trig, exponential, and logarithm functions. OBEX and Forum.
    edited 2014-10-11 - 15:48:15
    We finally got some time today to do some probing around. We haven't tried an external oscillator just yet, but for sure something's wrong with the PLL as none of the code will run if we call it in the CON section.
    That said. We checked to make sure that the crystal was working and that there was good continuity between the xtal pins and xtal - and all was fine there.
    One of the items we're driving is a solenoid (prop pin to base of fet to solenoid), and while probing the 3.3v power line, we noticed that whenever the solenoid drew current, there was a voltage upspike, which is possibly what killed the pll. So we've added a massive cap between the 3.3v and ground and now when scoped, the voltage is nice and smooth.
    Whisker's currently putting on another prop chip so we'll see if that runs any better. Thanks to you guys for your help - we had no idea about the PLL issue before!
    Addie
    edited 2014-10-11 - 16:02:25
    Tymkrs wrote: »
    Addie
    I suspected you had an inductor in there somewhere :)
    It's good practice to drive the MOSFET through a resistor even though it doesn't need it, it is mainly for protection for the Prop I/O as you can get a spike through the drain-gate capacitance or even to protect it in case of catastrophic failure. Also add a pulldown on the I/O side and this also acts as a voltage divider back into the I/O. I'd suggest 1K to 10K or more for the series resistor since it is only a solenoid and the pulldown could be the same.
    BTW, it's just as well the PLL suffers first as otherwise it could be almost anything, at least the Prop can limp along if it needs too. Tough little tyke it is.
    Brisbane, Australia
    edited 2014-10-11 - 18:28:54
    yeah, solenoids and motors and such can all give you voltage spikes due to inductance: V=L*di/dt... If you try to switch off the current in an inductor, it will develop a voltage to fight back...
    I'd recommend using some kind of isolation between Prop and inductive load.
  • DomanikDomanik Posts: 233
    edited 2014-10-11 - 20:58:39
    Addie,
    Tymkrs wrote: »
    It's common practice to attach a diode across the coil to clamp the inductive kick. A collapsing magnetic field can induce significant voltage back into the coil driver device. It could be punching through your FET and into your prop. Depending on the bandwidth of your scope and the parasitic C of your circuit, you may not see the full extent of the transition.
    Dom...
    <br>
    edited 2014-10-12 - 05:21:06
    This is true. I think it's often called a "free-wheeling diode". That might be enough.
    Still, personally, I'd use some kind of isolation to have the coil on a separate circuit.
    Could be relays, optoisolators. Transistor might be good enough as long as the power supply for the Prop is well isolated from the power supply for the coil.
    I think a Parallax board uses a 10uF inductor between the power for Prop and power for servos to provide some isolation.
    That plus the diode might be enough.
    edited 2014-10-12 - 05:48:07
    Rayman wrote: »
    By power you of course mean the bulk DC supply as I am aghast when I see solenoids and motors hooked up to the 5V supply or worse still, the Prop's 3.3V (oh, the humanity).
    Don't forget the series gate resistor, it's really important for a couple of different reasons and nothing to do with how BJTs are driven of course. The fact that the turn off is slowed down means it takes longer for the magnetic field to collapse thereby reduced the severity of the spike. Any "punch-through" back into the gate is limited by the series resistor and also the pulldown on the I/O side.
    Brisbane, Australia
    edited 2014-10-12 - 14:38:35
    Hi all,
    To address some of the suggestions brought up - I have a 10k resistor in series between the prop and the gate of the mosfet. And there is also a diode across the solenoid. The power supply for the prop is also fairly isolated from that of the solenoid's.
    We changed out the propeller, and it's working magnificently. So we might add the large bypass cap and see if that's enough.
    (We may also add in the pull down resistor, though before we had a pull up resistor and had to take it off for the solenoid to even work)
    Addie
    Tymkrs wrote: »
    That does suggest it was stress damage to the PLL
    Tymkrs wrote: »
    Was the spike most noticeable on Activate,or De-activate of the solenoid ? What current is the Solenoid ?
    What about the ground currents ?
    A 'fairly isolated' positive supply, does not guarantee safe ground paths.
    Turn-on of any inductive load tends to self-slew-limit due to the inductance, but turn off can generate a fast current edge, and the current path changes significantly from the FET source, to the Flywheel diode.
    Slowing down that turn off (with the large series Gate resistor) lowers the dI/dt of the edge.
