Propeller II update - BLOG - Page 216 — Parallax Forums
1213214216218219223
    edited 2014-03-19 23:31
    Yes.
    I'm compiling the DE0-Nano now. I had to remove the PIX, CORDIC, CTRB, SERB, and waveform output from CTRA to get things to fit. If this compile works, I'll try putting the waveform output back in for CTRA. Anyway, you need the VID and XFR blocks to do multithreaded VGA w/SDRAM, and those blocks are both in the DE0-Nano compile. For the SDRAM writing/reading, you'll need to be single-tasking because that requires exact timing.
    I don't need the waveform output in CTRA (not the others you have removed). Not sure about the other DE0 users.
    edited 2014-03-19 23:37
    potatohead wrote: »
    While we are waiting, what did you add to the monitor Chip?
    I think it's high time to update the monitor document.
    I added a hub exec mode, where you see addresses (divided by four, four digits) and data (32 bits) as a cog does when executing in hub mode.
    I also added another cog-start command to handle initial-hub-exec. As well, a lot of little details were improved.
    Here's the new ROM_Monitor.spin program. Note that most of the code now lives outside of the cog. This allowed a maximum-sized data/string buffer in cog register space, so that it never runs out before the input-line length of 128 characters. Also see how strings are handled from hub memory:
    '*		Propeller II ROM Monitor		*
    '*		Version 0.5				*
    ' Version 0.1 - 2012/11/01 - original
    ' Version 0.2 - 2013/09/22 - added semicolon comments
    ' Version 0.3 - 2013/11/13 - began using SERA
    ' Version 0.4 - 2013/12/03 - expanded to 256KB hub memory
    ' Version 0.5 - 2014/03/15 - added cog view mode
    ' Usage:	cognew($52C, rx_pin << 10 + tx_pin << 2)	'start monitor in new cog
    '		rx_pin bit 7 can be set for rx inversion
    '		tx_pin bit 7 can be set for tx inversion
    CON		datasize = 128
    DAT		orgh	($52C)>>2
    '* Cog Entry *
    		org				'ptra = %rrrrrrrr_tttttttt_00
    entry		reps	#$1F2-reserves,#1	'clear reserves
    		setinda	#reserves
    		mov	inda++,#0
    		getptra	ctra			'get rx pin into ctra configuration
    		testb	ctra,#17	wc	'handle !rx
    		shl	ctra,#32-10-7		'clear high bits
    		shr	ctra,#32-9-7		'position rx pin in d
    		sets	ctra,#%1_100_01001	'ready state-time mode
    		setbnc	ctra,#5			'handle !rx
    		getptra	x			'get rx/tx pins into sera setup
    		ror	x,#10
    		or	x,#$100			'ready rx 8T/8N
    		setd	sera,x
    		shr	x,#32-8
    		or	x,#$100			'ready tx 8T/8N
    		sets	sera,x
    		setp	sera			'tx high
    		jmpt1	#baud_task		'enable baud detector task
    		settask	#%%1010
    		thalt	space,#1		'wait for <space> to set period
    		clrp	sera			'release tx
    		jmpt2	#rx_task		'enable serial receiver task
    		settask	#%%1210
    		mov	wsize,#1		'init word size to byte
    		call	@set_size
    		wraux	#0,#0			'init input line to <enter>
    		locptra	@hello			'ready to print hello message
    '* Cog Main Task *
    message		call	@tx_string		'print hello/error message
    cmd_new		call	@rx_line		'get input line
    		call	@parse			'parse first term
    	if_z	jz	x,@cmd_viewl		'if no hex and eol, view data
    		jmp	@cmd_go			'else, process command
    cmd_next_crlf	call	@tx_crlf		'print cr/lf
    cmd_next	addptrx	#1			'skip chr
    cmd_loop	call	@parse			'parse next term
    cmd_go	if_nz	jmp	@cmd_hex		'if hex, branch
    		setd	pinx,#w			'pin update redirected to w
    		locptra	@branch1		'not hex, vector by chr
    		call	@vector			'if returns, no match
    cmd_error	locptra	@error			'print error message
    		jmp	@message
    cmd_hex		mov	v1,value		'hex, save v1
    		setd	pinx,#pin		'pin update okay
    		locptra	@branch2		'vector by chr
    		jmp	@cmd_view2		'view data
    cmd_range	shl	v1,shiftx		'handle exec mode
    		call	@parse_next		'hex., get hex
    		shl	value,shiftx		'handle exec mode
    	if_z	jmp	@cmd_viewp2		'if no hex, view data
    		mov	v2,value		'hex.hex, save v2
    		locptra	@branch3		'vector by chr
    		jmp	@cmd_view3		'view data
    ' Byte/word/long/cog data
    cmd_byte	mov	wsize,#1	wz	'set byte mode, z=0
    cmd_word if_z	mov	wsize,#2	wz	'set word mode, z=0
    cmd_long if_z	mov	wsize,#4	wz	'set long mode, z=0
    cmd_exec if_z	mov	wsize,#4		'set exec mode, z=1
    		setbz	shiftx,#1		'for exec mode, shiftx=2
    		call	@set_size
    		jmp	@cmd_next		'next command
    ' View data
    cmd_viewl	mov	v2,#$F			'<enter> (eol), show line of data
    		call	@tx_range1
    		jmp	@cmd_new
    cmd_viewp	mov	v2,#$FF			'. (more), show page of data
    		call	@tx_range1
    		jmp	@cmd_next
    cmd_viewp2	mov	v2,#$FF			'adr. (more), show page of data
    		call	@tx_range2
    		jmp	@cmd_loop
    cmd_view2	shl	v1,shiftx		'adr, show unit of data, handle exec mode
    		mov	v2,v1
    cmd_view3	call	@tx_range		'adr.adr, show range of data
    		jmp	@cmd_loop
    ' Search
    cmd_search	mov	v1,view			'/, search from view to end
    		jmp	@cmd_search2x
    cmd_search2	shl	v1,shiftx		'adr/, search from address to end, handle exec mode
    cmd_search2x	mov	v2,amask		'set end address
    cmd_search3	call	@check_range		'adr.adr/, search range
    		call	@parse_data		'parse data string
    :start		setptra	v1			'start search, point to search address
    		setinda	#data			'point to search data
    		mov	x,#0			'reset word match counter
    :word		call	@rdxxxx			'get memory word
    		cmp	value,inda++	wz	'compare against search data word
    	if_z	jmp	@:match			'if word match, check if string match
    		add	v1,wsize		'word mismatch, advance search address
    		cmp	v1,v2		wz,wc	'at end of range?
    	if_be	jmp	@:start			'if not, start next search
    		mov	view,v1			'else, update view
    		and	view,amask
    		jmp	@cmd_loop		'next command
    :match		incmod	x,dsize		wc	'word match, increment match counter
    	if_nc	jmp	@:word			'if more words to match, compare next word
    		mov	v2,dsize		'got string match
    		shl	v2,shift		'v1 = start of found data
    		add	v2,v1			'v2 = end of found data
    		jmp	@cmd_view3		'show found data
    ' Enter data
    cmd_enter3	call	@check_range		'adr.adr:, check range, w=words to fill, z=0
    cmd_enter2 if_z	shl	v1,shiftx		'adr:, handle exec mode
    		mov	enter,v1		'set enter address
    		and	enter,amask		'trim enter address (in case cmd_enter2)
    cmd_enter	call	@parse_data		':, parse data (preserves z)
    	if_z	mov	w,dsize			'if not fill, set w to data size
    	if_z	add	w,#1
    		setptrb	enter			'get pointer
    :loop		mov	value,inda++		'get word from string data
    		call	@wrxxxx			'store value in memory
    		djnz	w,@:loop		'loop until enter done
    		getptrb	enter			'update pointer
    ' Move data
    cmd_move	mov	y,x			'save ">"/"<"
    		call	@check_range		'check 1st address range, get number of words
    		call	@parse_hex		'get 2nd address
    		max	value,amask		'v1=1st, value=2nd, w=words, y=">"/"<"
    		and	value,amask
    		cmp	y,#"<"		wz	'if "<", swap v1 and value
    	if_z	mov	x,v1
    	if_z	mov	v1,value
    	if_z	mov	value,x			'v1=from, value=to, w=words
    		cmp	v1,value	wc	'if from < to, downward move
    	if_c	mov	x,w
    	if_c	shl	x,shift
    	if_c	add	v1,x
    	if_c	add	value,x
    	if_c	xor	rdxxxx,#%001_111110	'modify 'rdxxxx value,--ptra'
    	if_c	xor	wrxxxx,#%001_111110	'modify 'wrxxxx value,--ptrb'
    		setptra	v1			'set pointers
    		setptrb	value
    :loop		call	@rdxxxx			'move data
    		call	@wrxxxx
    		djnz	w,@:loop
    	if_c	xor	rdxxxx,#%001_111110	'restore 'rdxxxx value,ptra++'
    	if_c	xor	wrxxxx,#%001_111110	'restore 'wrxxxx value,ptrb++'
    ' Checksum
    cmd_checksum	call	@check_range		'check range
    		setptra	v1			'sum bytes/words/longs
    :loop		call	@rdxxxx
    		add	y,value
    		djnz	w,@:loop
    		mov	value,y			'print sum
    		mov	x,#8
    		call	@tx_hex
    		jmp	@cmd_next_crlf		'next command
    ' Watch
    cmd_watchp	mov	y,#1			'pin#, set pin mode
    		mov	v2,#1		wz	'set single hex digit, z=0
    cmd_watch if_z	shl	v1,shiftx		'adr@, handle exec mode
    	  if_z	mov	v2,wsize		'set hex size by word size
    	  if_z	shl	v2,#1
    		call	@rdxxxp			'get initial value
    :loop		mov	w,value			'preserve value
    		mov	x,v2			'set hex size
    		call	@tx_hex			'print value
    		serouta	#" "			'print space
    :wait		call	@rx_check		'if key hit, exit
    	if_nz	jmp	@cmd_next_crlf
    		call	@rdxxxp			'get current value
    		cmp	value,w		wz	'if same, check again
    	if_z	jmp	@:wait
    		jmp	@:loop			'new value, loop
    rdxxxp		setptra	v1			'if not pin mode, read memory
    		jz	y,@rdxxxx
    		getp	v1		wc	'read pin
    	if_nc	mov	value,#0
    	if_c	mov	value,#1
    		ret
    ' Clkset
    cmd_clkset	locptra	@hitspace		'print hit-space message
    		call	@tx_string
    		passtxa				'wait for tx done
    		clkset	v1			'set clk
    		thalt	space,#1		'wait for recalibrating space
    		call	@rx_chr			'throw away garbage character
    ' Start cog
    cmd_cogrun	mov	x,#1		wz	'z=0
    cmd_cogrunx	call	@parse_hex		'z=1, get program address (preserves z)
    	if_nz	cogrun	value,v1		'start in cog
    	if_z	cogrunx	value,v1		'start in hub
    ' Stop cog
    ' Quit
    cmd_quit	cogid	v1			'quit
    cmd_cogstop	cogstop	v1			'stop cog
    ' Map
    cmd_map		mov	y,#7			'ready for 7..0
    cmd_map_loop	serouta	#" "			'print space
    		cogid	x			'get cog id
    		cogid	y		wc	'get cog y status
    cmd_map_c	cmp	x,y		wz
    	if_nc	mov	x,#"0"			'get 0/1/M chr
    	if_c	mov	x,#"1"
    	if_z	mov	x,#"M"
    		serouta	x			'print chr
    		sub	y,#1		wc
    	if_nc	jmp	@cmd_map_loop		'loop until done
    ' Pin writes setp/clrp/notp/offp
    ' Pin read
    cmd_setp	mov	x,#$AB		wz	'setp, z=0
    cmd_clrp if_z	mov	x,#$AA		wz	'clrp, z=0
    cmd_notp if_z	mov	x,#$A9		wz	'notp, z=0
    cmd_offp if_z	mov	x,#$A8		wz	'offp, z=0
    cmd_getp if_z	mov	x,#$88			'getp, z=1
    		sets	pinop,x			'set pin opcode
    pinx		mov	pin,v1			'if hex, get pin (d = pin/w)
    pinop		getp	pin		wc	'becomes setp/clrp/notp/offp/getp
    	if_z	jmp	@cmd_map_c		'if getp, show pin value
    ' Pin configuration
    cmd_cfgp	call	@parse_hex		'get configuration
    		decod5	x,v1		wz,wc	'get pin mask
    		setbz	:i,#25			'set pin port
    		setbc	:i,#24
    :i if_nz_or_nc	cfgpins	x,value,#0		'configure pin if $00..$5F
    ' Setdacs
    cmd_setdacs	setdacs	v1			'set all four dacs with 8-bit values
    ' Help
    cmd_help	locptra	@help			'print help message
    		call	@tx_string
    ' Self-modifying code
    rdxxxx		rdbyte	value,ptra++		'rdbyte/rdword/rdlong
    		ret
    wrxxxx		wrbyte	value,ptrb++		'wrbyte/wrword/wrlong
    		ret
    rdstring	rdbyte	x,ptra++	wz,wc	'read string byte
    		ret
    hublimit	long	$0003FFFF		'hub memory limit
    '* Cog Serial Receiver Task *
    rx_task		serina	rx_data			'wait for character
    		wrauxr	rx_data,rx_head		'store byte at head
    		incmod	rx_head,#$7F		'inc head
    		jmp	@rx_task		'wait for next byte
    '* Cog Baud Detector Task *
    baud_task	notb	ctra,#8		wc	'if 1,0 sample set, c=0 (bit8 is not used by ctra)
    		notb	ctra,#5			'toggle state to measure ($20 -> 10000001001 -> 1, 6x 0, 1x 1, 2x 0, 1)
    		setctra	ctra			'ctra measures rx pin states
    	if_nc	mov	limh,buf0		'if 1,0 sample set,
    	if_nc	shr	limh,#4			'..make window from 1st 0 (6x if $20)
    	if_nc	neg	liml,limh
    	if_nc	add	limh,buf0
    	if_nc	add	liml,buf0
    	if_nc	mov	comp,buf1		'if 1,0 sample set,
    	if_nc	mul	comp,#6			'..normalize 2nd 1 (1x if $20) to 6x
    	if_nc	cmpr	comp,limh	wc	'..check if within window
    	if_nc	cmp	comp,liml	wc
    	if_nc	mov	comp,buf2		'if 1,0 sample set,
    	if_nc	mul	comp,#3			'..normalize 2nd 0 (2x if $20) to 6x
    	if_nc	add	buf0,buf2		'if $20,
    	if_nc	shr	buf0,#3			'..compute period from 6x 0 and 2x 0
    	if_nc	setsera	sera,buf0		'..(re)initialize serial
    	if_nc	mov	space,#0		'..flag $20
    		mov	buf0,buf1		'scroll sample buffer
    		mov	buf1,buf2
    :wait		getcosa	buf2			'wait for next sample
    		jnz	buf2,@baud_task
    		jmp	@:wait
    '* Cog Variables *
    reserves
    v		res	1			'main task
    w		res	1
    x		res	1
    y		res	1
    v1		res	1
    v2		res	1
    value		res	1
    view		res	1
    enter		res	1
    pin		res	1
    dsize		res	1
    shiftx		res	1
    wsize		res	1
    shift		res	1
    amask		res	1
    data		res	datasize
    rx_data		res	1			'serial receiver task
    rx_head		res	1
    rx_tail		res	1
    ctra		res	1			'baud detector task
    sera		res	1
    buf0		res	1
    buf1		res	1
    buf2		res	1
    limh		res	1
    liml		res	1
    comp		res	1
    space		res	1
    '* Hub Subroutines *
    		orgh
    ' Vector branch
    vector		rdbyte	w,ptra++	wz	'get jump address
    	if_z	ret				'if 0, no match found, return
    		rdbyte	y,ptra++		'get target
    		xor	y,x		wz	'compare to x
    	if_nz	jmp	@vector			'if no match, loop
    		jmp	w			'match found, jump, y=0, z=1
    ' Check address range (v1..v2)
    check_range	max	v1,amask		'trim v1
    		and	v1,amask
    		max	v2,amask		'trim v2
    		and	v2,amask
    		cmp	v2,v1		wc	'make sure v2 => v1
    	if_c	jmp	@cmd_error
    		mov	w,v2			'get number of words
    		sub	w,v1
    		shr	w,shift
    		add	w,#1		wz	'z=0
    		ret
    ' Set rdxxxx/wrxxxx and others by word size
    set_size	test	wsize,#%010	wc	'set rdxxxx/wrxxxx by word size
    		setbc	rdxxxx,#26
    		setbc	wrxxxx,#24
    		test	wsize,#%100	wc
    		setbc	rdxxxx,#27
    		setbc	wrxxxx,#25
    		mov	shift,wsize		'set shift by word size
    		shr	shift,#1
    		neg	amask,wsize		'set amask by word size
    		and	amask,hublimit
    		and	view,amask		'trim view
    		ret
    ' Input line
    rx_line		setptrx	#0			'point to start of line
    		serouta	#">"			'show prompt
    		call	@rx_chr			'get first chr
    		cmp	x,#"'"		wz	'check for repeat
    	if_nz	jmp	@:first			'if not repeat, first chr
    :show		rdaux	x,ptrx++	wz	'repeat, show line
    	if_nz	serouta	x
    	if_nz	jmp	@:show
    		jmp	@:done
    :back		chkptrx			wz	'backspace, line empty? if not,
    	if_nz	serouta	x			'..print backspace
    	if_nz	serouta	#" "			'..print space
    	if_nz	subptrx	#1			'..back up
    :loop		call	@rx_chr			'get next chr
    :first		cmp	x,#13		wz	'cr?
    	if_z	jmp	@:cr
    		cmp	x,#8		wz	'backspace?
    	if_nz	cmp	x,#127		wz
    	if_z	jmp	@:back
    		cmp	x,#" "		wc	'invisible chr?
    	if_nc	cmpr	x,#"~"		wc
    	if_c	jmp	@:loop
    		wraux	x,ptrx++		'visible chr, append to line
    		chkptrx			wc	'overflow?
    	if_c	subptrx	#1			'if overflow, back up
    	if_c	serouta	#7			'..and output bell
    	if_nc	serouta	x			'if not overflow, print chr
    		jmp	@:loop
    :cr		wraux	#0,ptrx			'cr, end line with 0
    :done		setptrx	#0			'point to start of line
    tx_crlf		serouta	#$0D			'print cr/lf
    		serouta	#$0A
    		ret
    ' Parse hex/text data
    parse_data	mov	v,#0			'reset data count
    		setinda	#data			'point to string data
    :hex		call	@parse_next		'hex loop, check hex
    	if_nz	call	@enter_data		'if hex, enter value
    		cmp	x,#" "		wz	'check for space (more hex)
    	if_z	jmp	@:hex			'if more hex, loop
    		cmp	x,#"'"		wz	'not hex, "'"?
    	if_nz	jmp	@:done			'if not "'", done
    :text		rdaux	x,++ptrx		'text loop, get and point to next chr
    		cmp	x,#"'"		wz	'check for "'"
    	if_z	jmp	@:hex			'if "'", back to hex
    		jz	x,@:done		'if eol, done
    		mov	value,x			'text chr
    		call	@enter_data		'enter chr
    		jmp	@:text			'loop
    :done		sub	v,#1		wc	'get data count
    	if_nc	mov	dsize,v			'if 0, reuse old data
    		cirinda	dsize,#data		'form circular buffer
    		ret			wz	'restore z
    enter_data	incmod	v,#datasize	wc	'check if data limit exceeded
    	if_c	jmp	@cmd_error		'if data limit exceeded, error
    		mov	inda++,value		'store value in data
    		ret
    ' Parse hex
    parse_hex	call	@parse_next		'try to parse hex
    	if_z	jmp	@cmd_error		'if no hex, error
    		ret			wz	'restore z
    ' Parse line (@ptrx), z=0 if hex (value)
    parse_next	addptrx	#1			'advance to next chr
    parse		mov	value,#0	wz	'z=1
    		call	@skip_spaces		'skip any spaces (preserve z)
    :loop		rdaux	x,ptrx++		'get chr
    		chkhex	x		wc	'check hex
    	if_c	rolnib	value,x			'if hex, append nibble and loop
    	if_c	cmp	x,#16		wz	'z=0
    	if_c	jmp	@:loop
    		subptrx	#1			'repoint to non-hex chr
    		call	@skip_spaces		'skip any post-hex spaces (preserves z)
    	if_c	rdaux	x,--ptrx		'if hex, back up to space chr
    		chklet	x			'make alpha chr uppercase
    		ret
    ' Skip spaces (@ptrx)
    skip_spaces	rdaux	x,ptrx++		'skip space chr(s)
    		cmp	x,#" "		wz
    	if_z	jmp	@skip_spaces
    		subptrx	#1			'back up to non-space chr
    		ret			wz	'restore z
    ' Print range (v1..v2)
    tx_range1	mov	v1,view			'view..view + v2
    tx_range2	and	v2,amask		'v1..v1 + v2
    		add	v2,v1
    tx_range	call	@check_range		'check range
    		mov	view,v1			'set address
    :line		mov	value,view		'print address
    		shr	value,shiftx		'handle exec mode
    		mov	x,shiftx		'4 digits in exec mode
    		shr	x,#1
    		subr	x,#5			'5 digits in other modes
    		call	@tx_hex
    		serouta	#"-"			'print "- "
    		serouta	#" "
    		mov	x,wsize			'get number of words on line
    		rev	x,#32-5
    		mov	v1,w
    		max	v1,x
    		mov	v2,v1			'get number of ascii bytes on line
    		shl	v2,shift
    		sub	w,v1			'update number of words left
    		setptra	view			'print hex words
    :hex		call	@rdxxxx
    		mov	x,wsize
    		shl	x,#1
    		call	@tx_hex
    		serouta	#" "
    		djnz	v1,@:hex
    		serouta	#" "			'print "  '"
    		serouta	#" "
    		serouta	#"'"
    		setptra	view			'print ascii bytes
    :ascii		rdbyte	x,ptra++
    		cmp	x,#" "		wc	'visible chr?
    	if_c	mov	x,#"."			'substitute "." for non-visible chrs
    		serouta	x
    		djnz	v2,@:ascii
    		getptra	view			'update address
    		serouta	#"'"			'print "'"
    		call	@rx_check		'check key hit
    	if_z	jnz	w,@:line		'if no key hit and more words left, print another line
    		ret
    ' Print string (@ptra)
    tx_string	call	@rdstring		'read string byte
    	if_z	ret				'if 0, done
    	if_c	notb	rdstring,#8		'if substring, toggle ptra/ptrb
    	if_c	locptrb	@db			'ptrb points to substring
    	if_c	addptrb	x
    	if_c	jmp	@tx_string		'start substring or resume string
    		cmp	x,#"`"		wz	'long tab?
    	if_z	subr	y,#32-16
    	if_nz	cmp	x,#"~"		wz	'short tab?
    	if_z	add	y,#16
    :tab	if_z	serouta	#" "
    	if_z	djnz	y,@:tab
    	if_z	serouta	#"-"
    	if_z	serouta	#" "
    	if_z	jmp	@tx_string
    		cmp	x,#13		wz	'cr?
    	if_z	call	@tx_crlf
    	if_z	mov	y,#0
    	if_nz	serouta	x			'other?
    	if_nz	add	y,#1
    		jmp	@tx_string
    ' Print hex (value,x)
    tx_hex		shl	x,#2			'position first nibble
    		ror	value,x
    		shr	x,#2
    :loop		getnib	v,value,#7		'print nibbles
    		cmp	v,#$A		wc	'alpha or numeric?
    	if_c	add	v,#"0"			'numeric
    	if_nc	add	v,#"A"-$A		'alpha
    		serouta	v
    		rol	value,#4
    		djnz	x,@:loop
    		ret
    ' Receive chr (x)
    rx_chr		call	@rx_check		'wait for rx chr
    	if_z	jmp	@rx_chr
    		ret
    ' Check receiver, z=0 if chr (x)
    rx_check	cmp	rx_head,rx_tail	wz
    	if_nz	rdauxr	x,rx_tail
    	if_nz	incmod	rx_tail,#$7F
    		ret
    '* Hub Data *
    db
    branch1		long
    		byte	cmd_new,	0
    		byte	cmd_new,	";"
    		byte	cmd_byte,	"Y"
    		byte	cmd_word,	"W"
    		byte	cmd_long,	"N"
    		byte	cmd_exec,	"X"
    		byte	cmd_viewp,	"."
    		byte	cmd_search,	"/"
    		byte	cmd_enter,	":"
    		byte	cmd_map,	"M"
    		byte	cmd_setp,	"H"
    		byte	cmd_clrp,	"L"
    		byte	cmd_notp,	"T"
    		byte	cmd_offp,	"Z"
    		byte	cmd_getp,	"R"
    		byte	cmd_quit,	"Q"
    		byte	cmd_help,	"?"
    		byte	0
    branch2		long
    		byte	cmd_view2,	0
    		byte	cmd_view2,	" "
    		byte	cmd_range,	"."
    		byte	cmd_search2,	"/"
    		byte	cmd_enter2,	":"
    		byte	cmd_watch,	"@"
    		byte	cmd_clkset,	"*"
    		byte	cmd_cogrun,	"+"
    		byte	cmd_cogrunx,	"-"
    		byte	cmd_cogstop,	"!"
    		byte	cmd_setp,	"H"
    		byte	cmd_clrp,	"L"
    		byte	cmd_notp,	"T"
    		byte	cmd_offp,	"Z"
    		byte	cmd_getp,	"R"
    		byte	cmd_watchp,	"#"
    		byte	cmd_cfgp,	"|"
    		byte	cmd_setdacs,	"\"
    		byte	0
    branch3		long
    		byte	cmd_view3,	0
    		byte	cmd_view3,	" "
    		byte	cmd_search3,	"/"
    		byte	cmd_enter3,	":"
    		byte	cmd_move,	">"
    		byte	cmd_move,	"<"
    		byte	cmd_checksum,	"^"
    		byte	0
    error		long
    		byte	"? - Help",13,7,0
    hitspace	long
    		byte	"Hit SPACE ",0
    hello		long
    		byte	13,13,"=== Propeller 2.0 Monitor ===",13,13,0
    sub0		byte	" -",13,$80		'@sub0-@db must be >= $80
    sub1		byte	"{adr{.adr}}",$80
    sub2		byte	"{dat{ dat}}",$80
    sub3		byte	"adr",$80
    sub4		byte	"pin",$80
    sub5		byte	"dat",$80
    sub6		byte	"`Watch",13,$80
    sub7		byte	"`Set ",$80
    help		long
    		byte	13,		"~HUB",@sub0-@db
    		byte	@sub1-@db,					"`View",13
    		byte	@sub1-@db,"/",@sub2-@db,			"`Search",13
    		byte	@sub1-@db,":",@sub2-@db,			"`Enter",13
    		byte	@sub3-@db,".",@sub3-@db,"[</>]",@sub3-@db,	"`Move",13
    		byte	@sub3-@db,".",@sub3-@db,"^",			"`Checksum",13
    		byte	@sub3-@db,"@",					@sub6-@db
    		byte	"[Y/W/N/X]",					"`Byte/Word/Long/Exec",13
    		byte			"~COGS",@sub0-@db
    		byte	"cog[+/-]",@sub3-@db,				"`Start in Cog/Hub",13
    		byte	"cog!",						"`Stop",13
    		byte	"M",						"`Map",13
    		byte			"~PINS",@sub0-@db
    		byte	"{",@sub4-@db,"}[H/L/T/Z/R]",			"`High/Low/Toggle/Float/Read",13
    		byte	@sub4-@db,"#",					@sub6-@db
    		byte	@sub4-@db,"|",@sub5-@db,			@sub7-@db,"CFG",13
    		byte	@sub5-@db,"\",					@sub7-@db,"DACs",13
    		byte			"~MISC",@sub0-@db
    		byte	@sub5-@db,"*",					@sub7-@db,"CLK",13
    		byte	"'",						"`Repeat",13
    		byte	"Q",						"`Quit",13,0
    Here's what it looks like when it comes up. It also shows eXec mode:
                    - HUB -
    {adr{.adr}}                     - View
    {adr{.adr}}/{dat{ dat}}         - Search
    {adr{.adr}}:{dat{ dat}}         - Enter
    adr.adr[</>]adr                 - Move
    adr.adr^                        - Checksum
    adr@                            - Watch
    [Y/W/N/X]                       - Byte/Word/Long/Exec
                    - COGS -
    cog[+/-]adr                     - Start in Cog/Hub
    cog!                            - Stop
    M                               - Map
                    - PINS -
    {pin}[H/L/T/Z/R]                - High/Low/Toggle/Float/Read
    pin#                            - Watch
    pin|dat                         - Set CFG
    dat\                            - Set DACs
                    - MISC -
    dat*                            - Set CLK
    '                               - Repeat
    Q                               - Quit
    >x
    >0.
    0000- 706F7250 20302E32 FE7C0280 FE7C0081   'Prop2.0 ..|...|.'
    0004- FAC03FC5 407CE0FA FEBCBC00 FEBCBC00   '.?....|@........'
    0008- 507CBC01 B57CBC1F 387CD001 FE280C34   '..|P..|...|84.(.'
    000C- FEBCBA00 F6FCB626 FCFD001A 403CEA74   '....&.......t.<@'
    0010- FCFD0018 503CEA74 347CEA01 FCFD0015   '....t.<P..|4....'
    0014- B57CBE01 FC65001E B4FCBEB2 3A7CBE01   '..|...e.......|:'
    0018- AD7CE1FB 407CE102 B77CE008 4068BE8F   '..|...|@..|...h@'
    001C- B57CBE01 FCFD0011 FE7CB4AA FCFD000F   '..|.......|.....'
    0020- FE7CB4AF FCFD000D FE7CB4AB FCFD000B   '..|.......|.....'
    0024- B4FCBEB2 3A7CBE01 AD7CE1F4 FC7D0017   '......|:..|...}.'
    0028- FCFD0006 FE3CE804 FCFD0004 FE3CE822   '......<.....".<.'
    002C- B6BCE875 FE3C0188 FE3CE604 503CE65C   'u.....<...<.\.<P'
    0030- FEFCB68F 127C5800 FE0C0188 407CE004   '.....X|.......|@'
    0034- FE7CB2AB FE7CB0AA FAC007C4 FE7CB2AA   '..|...|.......|.'
    0038- BEFCE001 33CCBA01 FE7CAEAC FE7CB0AB   '.......3..|...|.'
    003C- FE7CB0AA AD7CE1F7 FC3C0380 867CE009   '..|...|...<...|.'
    edited 2014-03-19 23:38
    Cluso99 wrote: »
    This feature is really important to Tubular.
  • jazzedjazzed Posts: 11,803
    RossH wrote: »
    I support David's efforts in SpinWrap, but he would acknowledge that this is not an optimal way to integrate PASM objects (as opposed to Spin objects).
    It is too slow for some purposes, costs an unnecessary cog, and some unnecessary Hub RAM space. I'm not claiming Catalina's method is optimal, but it does everything SpinWrap does, and much more (e.g. locking, cog management etc).
    And it is more efficient in both cog usage and hub ram usage.
    Ross.
    Except that you can't call a Spin function directly from C right? Maybe you've added that recently?
    I get the limitations of SpinWrap. I'm sure that whatever you do with your product is good within your definition.
    edited 2014-03-19 23:42
    I believe he has a DE2. I will give him a quick phone call to verify.
    Postedit: I have left a msg, so sent an email too.
    edited 2014-03-19 23:51
    Cluso99 wrote: »
    Great! I just got a good compile for the DE0-Nano with the waveform output in the CTR. It was a little slow in Fmax, though, so I'm changing the fitter seed value and trying again. I think we'll get a faster one this time (or next) and we'll have images for both boards.
    edited 2014-03-19 23:53
    '*        Version 0.5                *
    CON        datasize = 128
    DAT        orgh    ($52C)>>2
    '* Cog Entry *
            setinda    #reserves
            mov    inda++,#0
            ror    x,#10
            setd    sera,x
            shr    x,#32-8
            sets    sera,x
            setp    sera            'tx high
            settask    #%%1010
            settask    #%%1210
            call    @set_size
    '* Cog Main Task *
            jmp    @message
            call    @set_size
    ' View data
            call    @tx_range1
            jmp    @cmd_new
            call    @tx_range1
            jmp    @cmd_next
            call    @tx_range2
            jmp    @cmd_loop
            mov    v2,v1
            jmp    @cmd_loop
    ' Search
            jmp    @cmd_search2x
            and    view,amask
    ' Enter data
        if_z    add    w,#1
    ' Move data
            and    value,amask
        if_z    mov    x,v1
        if_z    mov    v1,value
        if_c    mov    x,w
        if_c    shl    x,shift
        if_c    add    v1,x
        if_c    add    value,x
            setptrb    value
            call    @wrxxxx
            djnz    w,@:loop
    ' Checksum
    :loop        call    @rdxxxx
            add    y,value
            djnz    w,@:loop
            mov    x,#8
            call    @tx_hex
    ' Watch
          if_z    shl    v2,#1
        if_z    jmp    @:wait
            jz    y,@rdxxxx
        if_nc    mov    value,#0
        if_c    mov    value,#1
            ret
    ' Clkset
            call    @tx_string
            clkset    v1            'set clk
    ' Start cog
    ' Stop cog
    ' Quit
    ' Map
            cogid    x            'get cog id
        if_c    mov    x,#"1"
        if_z    mov    x,#"M"
            sub    y,#1        wc
    ' Pin read
    ' Pin configuration
            setbc    :i,#24
    ' Setdacs
    ' Help
            call    @tx_string
            ret
            ret
            ret
        if_nc    neg    liml,limh
        if_nc    add    limh,buf0
        if_nc    add    liml,buf0
            mov    buf1,buf2
            jnz    buf2,@baud_task
            jmp    @:wait
    '* Cog Variables *
    reserves
    v        res    1            'main task
    w        res    1
    x        res    1
    y        res    1
    v1        res    1
    v2        res    1
    value        res    1
    view        res    1
    enter        res    1
    pin        res    1
    dsize        res    1
    shiftx        res    1
    wsize        res    1
    shift        res    1
    amask        res    1
    data        res    datasize
    rx_head        res    1
    rx_tail        res    1
    sera        res    1
    buf0        res    1
    buf1        res    1
    buf2        res    1
    limh        res    1
    liml        res    1
    comp        res    1
    space        res    1
            orgh
    ' Vector branch
            and    v1,amask
            and    v2,amask
        if_c    jmp    @cmd_error
            sub    w,v1
            shr    w,shift
            add    w,#1        wz    'z=0
            ret
            setbc    rdxxxx,#26
            setbc    wrxxxx,#24
            test    wsize,#%100    wc
            setbc    rdxxxx,#27
            setbc    wrxxxx,#25
            shr    shift,#1
            and    amask,hublimit
            ret
    ' Input line
        if_nz    serouta    x
        if_nz    jmp    @:show
            jmp    @:done
        if_z    jmp    @:cr
        if_nz    cmp    x,#127        wz
        if_z    jmp    @:back
        if_c    jmp    @:loop
            jmp    @:loop
            serouta    #$0A
            ret
            jmp    @:text            'loop
            ret            wz    'restore z
            ret
    ' Parse hex
            ret            wz    'restore z
        if_c    jmp    @:loop
            ret
            cmp    x,#" "        wz
            ret            wz    'restore z
            add    v2,v1
            shr    x,#1
            call    @tx_hex
            serouta    #" "
            rev    x,#32-5
            mov    v1,w
            max    v1,x
            shl    v2,shift
    :hex        call    @rdxxxx
            mov    x,wsize
            shl    x,#1
            call    @tx_hex
            serouta    #" "
            djnz    v1,@:hex
            serouta    #" "
            serouta    #"'"
            serouta    x
            djnz    v2,@:ascii
            ret
        if_c    addptrb    x
        if_z    subr    y,#32-16
        if_z    add    y,#16
        if_z    djnz    y,@:tab
        if_z    serouta    #"-"
        if_z    serouta    #" "
        if_z    jmp    @tx_string
            cmp    x,#13        wz    'cr?
        if_z    call    @tx_crlf
        if_z    mov    y,#0
        if_nz    add    y,#1
            jmp    @tx_string
            ror    value,x
            shr    x,#2
            serouta    v
            rol    value,#4
            djnz    x,@:loop
            ret
    ' Receive chr (x)
        if_z    jmp    @rx_chr
            ret
            ret
    '* Hub Data *
    db
    branch1        long
            byte    cmd_new,    0
            byte    cmd_new,    ";"
            byte    cmd_byte,    "Y"
            byte    cmd_word,    "W"
            byte    cmd_long,    "N"
            byte    cmd_exec,    "X"
            byte    cmd_viewp,    "."
            byte    cmd_enter,    ":"
            byte    cmd_map,    "M"
            byte    cmd_setp,    "H"
            byte    cmd_clrp,    "L"
            byte    cmd_notp,    "T"
            byte    cmd_offp,    "Z"
            byte    cmd_getp,    "R"
            byte    cmd_quit,    "Q"
            byte    cmd_help,    "?"
            byte    0
    branch2        long
            byte    cmd_view2,    0
            byte    cmd_view2,    " "
            byte    cmd_range,    "."
            byte    cmd_watch,    "@"
            byte    cmd_setp,    "H"
            byte    cmd_clrp,    "L"
            byte    cmd_notp,    "T"
            byte    cmd_offp,    "Z"
            byte    cmd_getp,    "R"
            byte    cmd_cfgp,    "|"
            byte    0
    branch3        long
            byte    cmd_view3,    0
            byte    cmd_view3,    " "
            byte    cmd_move,    ">"
            byte    cmd_move,    "<"
            byte    0
    error        long
    hitspace    long
            byte    "Hit SPACE ",0
    hello        long
    sub3        byte    "adr",$80
    sub4        byte    "pin",$80
    sub5        byte    "dat",$80
    help        long
            byte    "M",                        "`Map",13
                    - HUB -
    {adr{.adr}}                     - View
    adr.adr^                        - Checksum
    adr@                            - Watch
                    - COGS -
    cog!                            - Stop
    M                               - Map
                    - PINS -
    pin#                            - Watch
    pin|dat                         - Set CFG
    dat\                            - Set DACs
                    - MISC -
    dat*                            - Set CLK
    '                               - Repeat
    Q                               - Quit
    >x
    >0.
    Chip,
    Is there any chance that the Monitor can remain at a fixed address rather than changing in each release ?
  • potatoheadpotatohead Posts: 10,253
    edited 2014-03-19 23:56
    Personally, I would rather it change where warranted. It's been through some very significant revisions.
    edited 2014-03-20 00:07
    Cluso99 wrote: »
    Chip,
    Once we get an actual chip out, I would make it stay in the same place if we had a revision, but for now, it's fluid.
    edited 2014-03-20 00:08
    Chip,
    Any chance you could post the instruction opcodes (from the bottom of your docs) ?
    edited 2014-03-20 00:18
    Cluso99 wrote: »
    Chip,
    I'll put it together right now and post it soon.
  • TubularTubular Posts: 4,621
    edited 2014-03-20 00:21
    Cluso99 wrote: »
    Hi Ray. Thanks for checking in, sorry was in the middle of cooking tea and given how much we need to catch up on it surely would have burnt!
    Yes I have a DE2 for development but am using DE0's plugged into a custom motherboard currently, as I have found to my amazement all the essentials can be made to fit (just) into a single cog. The hardware task slicing is brilliant. Hub execution will take it a whole lot further.
    If CTRA waveform gen can be included, great, if not I will either craft a soft DDS with R2R DAC, can probably use existing dac pins, or migrate asap to parallax's Altera board.
  • RossHRossH Posts: 5,345
    edited 2014-03-20 00:46
    jazzed wrote: »
    Yes, with SpinWrap - which supports Catalina. Do you expect me to do everything myself? :lol:
    jazzed wrote: »
    And also according to this definition from Heater - you know ... the one that triggered this discussion?
    Ross.
    edited 2014-03-20 00:48
    Wow, the Rom Monitor is interesting using the new instructions such as
    locptra @somewhere
    Some of the hubexec routines such as rx_line (input line), tx_crlf, tx_string, tx_hex, rx_chr should all be usable from other programs :)
    edited 2014-03-20 02:08
    Cluso99 wrote: »
    locptra @somewhere
    Yes, we need to determine if our addressing instructions are adequate. There are some things the assembler must do to help out, too. For now, when doing absolute hub branches, use #address>>2, instead of #address.
    edited 2014-03-20 02:16
    RossH wrote: »
    That's great, Ken. Any news on the Spin2 compiler progress? I have heard there was one, but I have not seen much discussion about it in the forums.
    Ross.
    So ... no Spin2 compiler yet then?
    Ross.
    edited 2014-03-20 02:18
    UPDATED 3/24/2014
    --- Fixed LOCBASE/LOCBYTE/LOCWORD/LOCLONG/LOCINST bug ---
    Okay. Here is the intermediate release. Its documentation will be getting updated over the next few days. So, at first, you are on your own, needing to infer things from the instruction list in Prop2_Docs.txt, which IS accurate. Of course, you can ask any questions here on the forum and I'll answer them.
    The DE0-Nano FPGA configuration lacks the following, in order to make one cog fit:
    CTRB - 2nd counter (CTRA is complete, including waveform output)
    SERB - 2nd serial port
    CORDIC - qsincos/qarctan/qrotate/qlog/qexp
    PIX - texture mapping, pixel blending
    Here's the file:
    Terasic_Prop2_Emulation_2014_03_24.zip
    Here's the new instruction set:
    ZCDS (for D column: W=write, M=modify, R=read, L=read/immediate)
    ZCWS		0000000 ZC I CCCC DDDDDDDDD SSSSSSSSS		RDBYTE	D,S/PTRA/PTRB		(waits for hub)
    ZCWS		0000001 ZC I CCCC DDDDDDDDD SSSSSSSSS		RDBYTEC	D,S/PTRA/PTRB		(waits for hub if dcache miss)
    ZCWS		0000010 ZC I CCCC DDDDDDDDD SSSSSSSSS		RDWORD	D,S/PTRA/PTRB		(waits for hub)
    ZCWS		0000011 ZC I CCCC DDDDDDDDD SSSSSSSSS		RDWORDC	D,S/PTRA/PTRB		(waits for hub if dcache miss)
    ZCWS		0000100 ZC I CCCC DDDDDDDDD SSSSSSSSS		RDLONG	D,S/PTRA/PTRB		(waits for hub)
    ZCWS		0000101 ZC I CCCC DDDDDDDDD SSSSSSSSS		RDLONGC	D,S/PTRA/PTRB		(waits for hub if dcache miss)
    ZCWS		0000110 ZC I CCCC DDDDDDDDD SSSSSSSSS		RDAUX	D,S/#0..$FF/PTRX/PTRY
    ZCWS		0000111 ZC I CCCC DDDDDDDDD SSSSSSSSS		RDAUXR	D,S/#0..$FF/PTRX/PTRY
    ZCMS		0001000 ZC I CCCC DDDDDDDDD SSSSSSSSS		ISOB	D,S/#
    ZCMS		0001001 ZC I CCCC DDDDDDDDD SSSSSSSSS		NOTB	D,S/#
    ZCMS		0001010 ZC I CCCC DDDDDDDDD SSSSSSSSS		CLRB	D,S/#
    ZCMS		0001011 ZC I CCCC DDDDDDDDD SSSSSSSSS		SETB	D,S/#
    ZCMS		0001100 ZC I CCCC DDDDDDDDD SSSSSSSSS		SETBC	D,S/#
    ZCMS		0001101 ZC I CCCC DDDDDDDDD SSSSSSSSS		SETBNC	D,S/#
    ZCMS		0001110 ZC I CCCC DDDDDDDDD SSSSSSSSS		SETBZ	D,S/#
    ZCMS		0001111 ZC I CCCC DDDDDDDDD SSSSSSSSS		SETBNZ	D,S/#
    ZCMS		0010000 ZC I CCCC DDDDDDDDD SSSSSSSSS		ANDN	D,S/#
    ZCMS		0010001 ZC I CCCC DDDDDDDDD SSSSSSSSS		AND	D,S/#
    ZCMS		0010010 ZC I CCCC DDDDDDDDD SSSSSSSSS		OR	D,S/#
    ZCMS		0010011 ZC I CCCC DDDDDDDDD SSSSSSSSS		XOR	D,S/#
    ZCMS		0010100 ZC I CCCC DDDDDDDDD SSSSSSSSS		MUXC	D,S/#
    ZCMS		0010101 ZC I CCCC DDDDDDDDD SSSSSSSSS		MUXNC	D,S/#
    ZCMS		0010110 ZC I CCCC DDDDDDDDD SSSSSSSSS		MUXZ	D,S/#
    ZCMS		0010111 ZC I CCCC DDDDDDDDD SSSSSSSSS		MUXNZ	D,S/#
    ZCMS		0011000 ZC I CCCC DDDDDDDDD SSSSSSSSS		ROR	D,S/#
    ZCMS		0011001 ZC I CCCC DDDDDDDDD SSSSSSSSS		ROL	D,S/#
    ZCMS		0011010 ZC I CCCC DDDDDDDDD SSSSSSSSS		SHR	D,S/#
    ZCMS		0011011 ZC I CCCC DDDDDDDDD SSSSSSSSS		SHL	D,S/#
    ZCMS		0011100 ZC I CCCC DDDDDDDDD SSSSSSSSS		RCR	D,S/#
    ZCMS		0011101 ZC I CCCC DDDDDDDDD SSSSSSSSS		RCL	D,S/#
    ZCMS		0011110 ZC I CCCC DDDDDDDDD SSSSSSSSS		SAR	D,S/#
    ZCMS		0011111 ZC I CCCC DDDDDDDDD SSSSSSSSS		REV	D,S/#
    ZCWS		0100000 ZC I CCCC DDDDDDDDD SSSSSSSSS		MOV	D,S/#
    ZCWS		0100001 ZC I CCCC DDDDDDDDD SSSSSSSSS		NOT	D,S/#
    ZCWS		0100010 ZC I CCCC DDDDDDDDD SSSSSSSSS		ABS	D,S/#
    ZCWS		0100011 ZC I CCCC DDDDDDDDD SSSSSSSSS		NEG	D,S/#
    ZCWS		0100100 ZC I CCCC DDDDDDDDD SSSSSSSSS		NEGC	D,S/#
    ZCWS		0100101 ZC I CCCC DDDDDDDDD SSSSSSSSS		NEGNC	D,S/#
    ZCWS		0100110 ZC I CCCC DDDDDDDDD SSSSSSSSS		NEGZ	D,S/#
    ZCWS		0100111 ZC I CCCC DDDDDDDDD SSSSSSSSS		NEGNZ	D,S/#
    ZCMS		0101000 ZC I CCCC DDDDDDDDD SSSSSSSSS		ADD	D,S/#
    ZCMS		0101001 ZC I CCCC DDDDDDDDD SSSSSSSSS		SUB	D,S/#
    ZCMS		0101010 ZC I CCCC DDDDDDDDD SSSSSSSSS		ADDX	D,S/#
    ZCMS		0101011 ZC I CCCC DDDDDDDDD SSSSSSSSS		SUBX	D,S/#
    ZCMS		0101100 ZC I CCCC DDDDDDDDD SSSSSSSSS		ADDS	D,S/#
    ZCMS		0101101 ZC I CCCC DDDDDDDDD SSSSSSSSS		SUBS	D,S/#
    ZCMS		0101110 ZC I CCCC DDDDDDDDD SSSSSSSSS		ADDSX	D,S/#
    ZCMS		0101111 ZC I CCCC DDDDDDDDD SSSSSSSSS		SUBSX	D,S/#
    ZCMS		0110000 ZC I CCCC DDDDDDDDD SSSSSSSSS		SUMC	D,S/#
    ZCMS		0110001 ZC I CCCC DDDDDDDDD SSSSSSSSS		SUMNC	D,S/#
    ZCMS		0110010 ZC I CCCC DDDDDDDDD SSSSSSSSS		SUMZ	D,S/#
    ZCMS		0110011 ZC I CCCC DDDDDDDDD SSSSSSSSS		SUMNZ	D,S/#
    ZCMS		0110100 ZC I CCCC DDDDDDDDD SSSSSSSSS		MIN	D,S/#
    ZCMS		0110101 ZC I CCCC DDDDDDDDD SSSSSSSSS		MAX	D,S/#
    ZCMS		0110110 ZC I CCCC DDDDDDDDD SSSSSSSSS		MINS	D,S/#
    ZCMS		0110111 ZC I CCCC DDDDDDDDD SSSSSSSSS		MAXS	D,S/#
    ZCMS		0111000 ZC I CCCC DDDDDDDDD SSSSSSSSS		ADDABS	D,S/#
    ZCMS		0111001 ZC I CCCC DDDDDDDDD SSSSSSSSS		SUBABS	D,S/#
    ZCMS		0111010 ZC I CCCC DDDDDDDDD SSSSSSSSS		INCMOD	D,S/#
    ZCMS		0111011 ZC I CCCC DDDDDDDDD SSSSSSSSS		DECMOD	D,S/#
    ZCMS		0111100 ZC I CCCC DDDDDDDDD SSSSSSSSS		CMPSUB	D,S/#
    ZCMS		0111101 ZC I CCCC DDDDDDDDD SSSSSSSSS		SUBR	D,S/#
    ZCMS		0111110 ZC I CCCC DDDDDDDDD SSSSSSSSS		MUL	D,S/#			(takes two clocks)
    ZCMS		0111111 ZC I CCCC DDDDDDDDD SSSSSSSSS		SCL	D,S/#			(takes two clocks)
    ZCWS		1000000 ZC I CCCC DDDDDDDDD SSSSSSSSS		DECOD2	D,S/#
    ZCWS		1000001 ZC I CCCC DDDDDDDDD SSSSSSSSS		DECOD3	D,S/#
    ZCWS		1000010 ZC I CCCC DDDDDDDDD SSSSSSSSS		DECOD4	D,S/#
    ZCWS		1000011 ZC I CCCC DDDDDDDDD SSSSSSSSS		DECOD5	D,S/#
    Z-WS		1000100 Z0 I CCCC DDDDDDDDD SSSSSSSSS		BLSIZE	D,S/#
    Z-WS		1000100 Z1 I CCCC DDDDDDDDD SSSSSSSSS		BLMASK	D,S/#
    Z-WS		1000101 Z0 I CCCC DDDDDDDDD SSSSSSSSS		ONECNT	D,S/#			(takes two clocks)
    Z-WS		1000101 Z1 I CCCC DDDDDDDDD SSSSSSSSS		ZERCNT	D,S/#			(takes two clocks)
    ZCWS		1000110 0C I CCCC DDDDDDDDD SSSSSSSSS		TOPONE	D,S/#			(takes two clocks)
    ZCWS		1000110 1C I CCCC DDDDDDDDD SSSSSSSSS		TOPZER	D,S/#			(takes two clocks)
    ZCWS		1000111 0C I CCCC DDDDDDDDD SSSSSSSSS		BOTONE	D,S/#			(takes two clocks)
    ZCWS		1000111 1C I CCCC DDDDDDDDD SSSSSSSSS		BOTZER	D,S/#			(takes two clocks)
    --MS		10010nn n0 I CCCC DDDDDDDDD SSSSSSSSS		GETNIB	D,S/#,#0..7
    --MS		10010nn n1 I CCCC DDDDDDDDD SSSSSSSSS		SETNIB	D,S/#,#0..7
    --MS		1001100 n0 I CCCC DDDDDDDDD SSSSSSSSS		GETWORD	D,S/#,#0..1
    --MS		1001100 n1 I CCCC DDDDDDDDD SSSSSSSSS		SETWORD	D,S/#,#0..1
    --MS		1001101 00 I CCCC DDDDDDDDD SSSSSSSSS		ROLNIB	D,S/#
    --MS		1001101 01 I CCCC DDDDDDDDD SSSSSSSSS		ROLBYTE	D,S/#
    --MS		1001101 10 I CCCC DDDDDDDDD SSSSSSSSS		ROLWORD	D,S/#
    --MS		1001101 11 I CCCC DDDDDDDDD SSSSSSSSS		SETS	D,S/#
    --MS		1001110 00 I CCCC DDDDDDDDD SSSSSSSSS		SETD	D,S/#
    --MS		1001110 01 I CCCC DDDDDDDDD SSSSSSSSS		SETCOND	D,S/#
    --MS		1001110 10 I CCCC DDDDDDDDD SSSSSSSSS		SETINST	D,S/#
    --MS		1001110 11 I CCCC DDDDDDDDD SSSSSSSSS		THALT	D,S/#
    -CMS		1001111 0C I CCCC DDDDDDDDD SSSSSSSSS		WAITCNT	D,S/#			(waits for CNT, +CNTX if WC)
    --MS		1001111 10 I CCCC DDDDDDDDD SSSSSSSSS		<empty>	D,S/#
    --RS		1001111 11 I CCCC DDDDDDDDD SSSSSSSSS		PICKZC	D,S/#			(always writes Z/C)
    --MS		101000n n0 I CCCC DDDDDDDDD SSSSSSSSS		GETBYTE	D,S/#,#0..3
    --MS		101000n n1 I CCCC DDDDDDDDD SSSSSSSSS		SETBYTE	D,S/#,#0..3
    --WS		1010010 00 I CCCC DDDDDDDDD SSSSSSSSS		SETBYTS	D,S/#
    --MS		1010010 01 I CCCC DDDDDDDDD SSSSSSSSS		MOVBYTS	D,S/#			(move bytes in D, S = %11_10_01_00 = D same)
    --MS		1010010 10 I CCCC DDDDDDDDD SSSSSSSSS		PACKRGB	D,S/#			(S 8:8:8 -> D 5:5:5 << 16 | D >> 16)
    --WS		1010010 11 I CCCC DDDDDDDDD SSSSSSSSS		UNPKRGB	D,S/#			(S 5:5:5 -> D 8:8:8)
    --MS		1010011 00 I CCCC DDDDDDDDD SSSSSSSSS		ADDPIX	D,S/#			(takes two clocks)
    --MS		1010011 01 I CCCC DDDDDDDDD SSSSSSSSS		MULPIX	D,S/#			(takes two clocks)
    --MS		1010011 10 I CCCC DDDDDDDDD SSSSSSSSS		BLNPIX	D,S/#			(takes two clocks)
    --MS		1010011 11 I CCCC DDDDDDDDD SSSSSSSSS		MIXPIX	D,S/#			(takes two clocks)
    ZCMS		1010100 ZC I CCCC DDDDDDDDD SSSSSSSSS		JMPSW	D,S/@
    ZCMS		1010101 ZC I CCCC DDDDDDDDD SSSSSSSSS		JMPSWD	D,S/@
    --MS		1010110 00 I CCCC DDDDDDDDD SSSSSSSSS		DJZ	D,S/@
    --MS		1010110 01 I CCCC DDDDDDDDD SSSSSSSSS		DJZD	D,S/@
    --MS		1010110 10 I CCCC DDDDDDDDD SSSSSSSSS		DJNZ	D,S/@
    --MS		1010110 11 I CCCC DDDDDDDDD SSSSSSSSS		DJNZD	D,S/@
    --RS		1010111 00 I CCCC DDDDDDDDD SSSSSSSSS		JZ	D,S/@
    --RS		1010111 01 I CCCC DDDDDDDDD SSSSSSSSS		JZD	D,S/@
    --RS		1010111 10 I CCCC DDDDDDDDD SSSSSSSSS		JNZ	D,S/@
    --RS		1010111 11 I CCCC DDDDDDDDD SSSSSSSSS		JNZD	D,S/@
    ZCRS		1011000 ZC I CCCC DDDDDDDDD SSSSSSSSS		TESTB	D,S/#
    ZCRS		1011001 ZC I CCCC DDDDDDDDD SSSSSSSSS		TESTN	D,S/#
    ZCRS		1011010 ZC I CCCC DDDDDDDDD SSSSSSSSS		TEST	D,S/#
    ZCRS		1011011 ZC I CCCC DDDDDDDDD SSSSSSSSS		CMP	D,S/#
    ZCRS		1011100 ZC I CCCC DDDDDDDDD SSSSSSSSS		CMPX	D,S/#
    ZCRS		1011101 ZC I CCCC DDDDDDDDD SSSSSSSSS		CMPS	D,S/#
    ZCRS		1011110 ZC I CCCC DDDDDDDDD SSSSSSSSS		CMPSX	D,S/#
    ZCRS		1011111 ZC I CCCC DDDDDDDDD SSSSSSSSS		CMPR	D,S/#
    -CRS		110000n nC I CCCC DDDDDDDDD SSSSSSSSS		WAITPEQ	D,S/#,#0..3		(waits for pins, plus CNT if WC)
    -CRS		110001n nC I CCCC DDDDDDDDD SSSSSSSSS		WAITPNE	D,S/#,#0..3		(waits for pins, plus CNT if WC)
    ---S		110010n nn I CCCC nnnnnnnnn SSSSSSSSS		WAITVID	#0..$DFF,S/#		(waits for vid if single-task, loops if multi-task)
    --RS		1100101 11 I CCCC DDDDDDDDD SSSSSSSSS		WAITVID	D,S/#			(waits for vid if single-task, loops if multi-task)
    --LS		1100110 0L I CCCC DDDDDDDDD SSSSSSSSS		WRBYTE	D/#,S/PTRA/PTRB		(waits for hub)
    --LS		1100110 1L I CCCC DDDDDDDDD SSSSSSSSS		WRWORD	D/#,S/PTRA/PTRB		(waits for hub)
    --LS		1100111 0L I CCCC DDDDDDDDD SSSSSSSSS		WRLONG	D/#,S/PTRA/PTRB		(waits for hub)
    --LS		1100111 1L I CCCC DDDDDDDDD SSSSSSSSS		WRWIDEM	D/#,S/PTRA/PTRB		(waits for hub) D = write mask, where 1 bits mean 'don't-write'
    --LS		1100111 11 I CCCC 000000000 SSSSSSSSS		WRWIDE	S/PTRA/PTRB		(waits for hub) D = constant $00000000, so all bytes written
    --LS		1101000 0L I CCCC DDDDDDDDD SSSSSSSSS		WRAUX	D/#,S/#0..$FF/PTRX/PTRY
    --LS		1101000 1L I CCCC DDDDDDDDD SSSSSSSSS		WRAUXR	D/#,S/#0..$FF/PTRX/PTRY
    --LS		1101001 0L I CCCC DDDDDDDDD SSSSSSSSS		SETACCA	D/#,S/#
    --LS		1101001 1L I CCCC DDDDDDDDD SSSSSSSSS		SETACCB	D/#,S/#
    --LS		1101010 0L I CCCC DDDDDDDDD SSSSSSSSS		MACA	D/#,S/#
    --LS		1101010 1L I CCCC DDDDDDDDD SSSSSSSSS		MACB	D/#,S/#
    --LS		1101011 0L I CCCC DDDDDDDDD SSSSSSSSS		MUL32	D/#,S/#
    --LS		1101011 1L I CCCC DDDDDDDDD SSSSSSSSS		MUL32U	D/#,S/#
    --LS		1101100 0L I CCCC DDDDDDDDD SSSSSSSSS		DIV32	D/#,S/#
    --LS		1101100 1L I CCCC DDDDDDDDD SSSSSSSSS		DIV32U	D/#,S/#
    --LS		1101101 0L I CCCC DDDDDDDDD SSSSSSSSS		DIV64	D/#,S/#
    --LS		1101101 1L I CCCC DDDDDDDDD SSSSSSSSS		DIV64U	D/#,S/#
    --LS		1101110 0L I CCCC DDDDDDDDD SSSSSSSSS		SQRT64	D/#,S/#
    --LS		1101110 1L I CCCC DDDDDDDDD SSSSSSSSS		QSINCOS	D/#,S/#
    --LS		1101111 0L I CCCC DDDDDDDDD SSSSSSSSS		QARCTAN	D/#,S/#
    --LS		1101111 1L I CCCC DDDDDDDDD SSSSSSSSS		QROTATE	D/#,S/#
    --LS		111000n nL I CCCC DDDDDDDDD SSSSSSSSS		CFGPINS	D/#,S/#,#0..2		(waits for alt)
    --LS		1110001 1L I CCCC DDDDDDDDD SSSSSSSSS		SETMAP	D/#,S/#
    --LS		1110010 0L I CCCC DDDDDDDDD SSSSSSSSS		SETSERA	D/#,S/#			(config,baud)
    --LS		1110010 1L I CCCC DDDDDDDDD SSSSSSSSS		SETSERB	D/#,S/#			(config,baud)
    --LS		1110011 0L I CCCC DDDDDDDDD SSSSSSSSS		SETCTRS	D/#,S/#			(ctrb,ctra)
    --LS		1110011 1L I CCCC DDDDDDDDD SSSSSSSSS		SETWAVS	D/#,S/#			(ctrb,ctra)
    --LS		1110100 0L I CCCC DDDDDDDDD SSSSSSSSS		SETFRQS	D/#,S/#			(ctrb,ctra)
    --LS		1110100 1L I CCCC DDDDDDDDD SSSSSSSSS		SETPHSS	D/#,S/#			(ctrb,ctra)
    --LS		1110101 0L I CCCC DDDDDDDDD SSSSSSSSS		ADDPHSS	D/#,S/#			(ctrb,ctra)
    --LS		1110101 1L I CCCC DDDDDDDDD SSSSSSSSS		SUBPHSS	D/#,S/#			(ctrb,ctra)
    --LS		1110110 0L I CCCC DDDDDDDDD SSSSSSSSS		SETXFR	D/#,S/#
    --LS		1110110 1L I CCCC DDDDDDDDD SSSSSSSSS		SETMIX	D/#,S/#
    --LS		1110111 0L I CCCC DDDDDDDDD SSSSSSSSS		COGRUN	D/#,S/#			(waits for hub)
    --LS		1110111 1L I CCCC DDDDDDDDD SSSSSSSSS		COGRUNX	D/#,S/#			(waits for hub)
    --LS		1111000 0L I CCCC DDDDDDDDD SSSSSSSSS		FRAC	D/#,S/#
    --LS		1111000 1L I CCCC DDDDDDDDD SSSSSSSSS		LODINDS	D/#,S/#
    --LS		1111001 0L I CCCC DDDDDDDDD SSSSSSSSS		CIRINDA	D/#,S/#
    --LS		1111001 1L I CCCC DDDDDDDDD SSSSSSSSS		CIRINDB	D/#,S/#
    --LS		1111010 0L I CCCC DDDDDDDDD SSSSSSSSS		JP	D/#,S/@			(takes two clocks)
    --LS		1111010 1L I CCCC DDDDDDDDD SSSSSSSSS		JPD	D/#,S/@			(takes two clocks)
    --LS		1111011 0L I CCCC DDDDDDDDD SSSSSSSSS		JNP	D/#,S/@			(takes two clocks)
    --LS		1111011 1L I CCCC DDDDDDDDD SSSSSSSSS		JNPD	D/#,S/@			(takes two clocks)
    --WS		1111100 00 I CCCC DDDDDDDDD SSSSSSSSS		LOCBASE	D,S/@			(if S:        S<<2, if @S:        (P+@S)<<2)
    --MS		1111100 01 I CCCC DDDDDDDDD SSSSSSSSS		LOCBYTE	D,S/@			(if S: D<<0 + S<<2, if @S: D<<0 + (P+@S)<<2)
    --MS		1111100 10 I CCCC DDDDDDDDD SSSSSSSSS		LOCWORD	D,S/@			(if S: D<<1 + S<<2, if @S: D<<1 + (P+@S)<<2)
    --MS		1111100 11 I CCCC DDDDDDDDD SSSSSSSSS		LOCLONG	D,S/@			(if S: D<<2 + S<<2, if @S: D<<2 + (P+@S)<<2)
    --W-		1111101 00 0 CCCC DDDDDDDDD sssssssss		LOCINST	D,@s			(P+s)
    --R-		1111101 00 1 CCCC DDDDDDDDD sssssssss		JMPLIST	D,@s			(jump to P+s+D)
    ----		1111101 01 0 BBAA ddddddddd sssssssss		FIXINDA #d,#s / FIXINDB #d,#s / FIXINDS #d,#s / SETINDA #s / SETINDB #d / SETINDS #d,#s
    ----		1111101 01 1 nnnn nnnnnnnnn nnniiiiii		REPS	#1..$10000,#1..64
    ----		1111101 10 n nnnn nnnnnnnnn nnnnnnnnn		AUGS	#23bits			(appends n to upper bits of next immediate S)
    ----		1111101 11 n nnnn nnnnnnnnn nnnnnnnnn		AUGD	#23bits			(appends n to upper bits of next immediate D)
    ----		1111110 00 0 CCCC 00 nnnnnnnnnnnnnnnn		LOCPTRA	#abs
    ----		1111110 00 0 CCCC 01 nnnnnnnnnnnnnnnn		LOCPTRA	@rel
    ----		1111110 00 0 CCCC 10 nnnnnnnnnnnnnnnn		LOCPTRB	#abs
    ----		1111110 00 0 CCCC 11 nnnnnnnnnnnnnnnn		LOCPTRB	@rel
    ----		1111110 00 1 CCCC 00 nnnnnnnnnnnnnnnn		JMP	#abs
    ----		1111110 00 1 CCCC 01 nnnnnnnnnnnnnnnn		JMP	@rel
    ----		1111110 00 1 CCCC 10 nnnnnnnnnnnnnnnn		JMPD	#abs
    ----		1111110 00 1 CCCC 11 nnnnnnnnnnnnnnnn		JMPD	@rel
    ---- wr0	1111110 01 0 CCCC 00 nnnnnnnnnnnnnnnn		LINK	#abs			(jump, write {%00000000000000,Z,C,P} to $000)
    ---- wr0	1111110 01 0 CCCC 01 nnnnnnnnnnnnnnnn		LINK	@rel
    ---- wr0	1111110 01 0 CCCC 10 nnnnnnnnnnnnnnnn		LINKD	#abs
    ---- wr0	1111110 01 0 CCCC 11 nnnnnnnnnnnnnnnn		LINKD	@rel
    ----		1111110 01 1 CCCC 00 nnnnnnnnnnnnnnnn		CALL	#abs
    ----		1111110 01 1 CCCC 01 nnnnnnnnnnnnnnnn		CALL	@rel
    ----		1111110 01 1 CCCC 10 nnnnnnnnnnnnnnnn		CALLD	#abs
    ----		1111110 01 1 CCCC 11 nnnnnnnnnnnnnnnn		CALLD	@rel
    ----		1111110 10 0 CCCC 00 nnnnnnnnnnnnnnnn		CALLA	#abs
    ----		1111110 10 0 CCCC 01 nnnnnnnnnnnnnnnn		CALLA	@rel
    ----		1111110 10 0 CCCC 10 nnnnnnnnnnnnnnnn		CALLAD	#abs
    ----		1111110 10 0 CCCC 11 nnnnnnnnnnnnnnnn		CALLAD	@rel
    ----		1111110 10 1 CCCC 00 nnnnnnnnnnnnnnnn		CALLB	#abs
    ----		1111110 10 1 CCCC 01 nnnnnnnnnnnnnnnn		CALLB	@rel
    ----		1111110 10 1 CCCC 10 nnnnnnnnnnnnnnnn		CALLBD	#abs
    ----		1111110 10 1 CCCC 11 nnnnnnnnnnnnnnnn		CALLBD	@rel
    ----		1111110 11 0 CCCC 00 nnnnnnnnnnnnnnnn		CALLX	#abs
    ----		1111110 11 0 CCCC 01 nnnnnnnnnnnnnnnn		CALLX	@rel
    ----		1111110 11 0 CCCC 10 nnnnnnnnnnnnnnnn		CALLXD	#abs
    ----		1111110 11 0 CCCC 11 nnnnnnnnnnnnnnnn		CALLXD	@rel
    ----		1111110 11 1 CCCC 00 nnnnnnnnnnnnnnnn		CALLY	#abs
    ----		1111110 11 1 CCCC 01 nnnnnnnnnnnnnnnn		CALLY	@rel
    ----		1111110 11 1 CCCC 10 nnnnnnnnnnnnnnnn		CALLYD	#abs
    ----		1111110 11 1 CCCC 11 nnnnnnnnnnnnnnnn		CALLYD	@rel
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000000000		COGID	D			(waits for hub) (doesn't write D if WC)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000000001		TASKID	D
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000000010		LOCKNEW	D			(waits for hub)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000000011		GETLFSR	D
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000000100		GETCNT	D
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000000101		GETCNTX	D
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000000110		GETACAL	D			(waits for mac)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000000111		GETACAH	D			(waits for mac)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000001000		GETACBL	D			(waits for mac)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000001001		GETACBH	D			(waits for mac)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000001010		GETPTRA	D
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000001011		GETPTRB	D
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000001100		GETPTRX	D
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000001101		GETPTRY	D
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000001110		SERINA	D			(waits for rx if single-task, loops if multi-task, releases if WC)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000001111		SERINB	D			(waits for rx if single-task, loops if multi-task, releases if WC)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000010000		GETMULL	D			(waits for mul if single-task, loops if multi-task)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000010001		GETMULH	D			(waits for mul if single-task, loops if multi-task)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000010010		GETDIVQ	D			(waits for div if single-task, loops if multi-task)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000010011		GETDIVR	D			(waits for div if single-task, loops if multi-task)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000010100		GETSQRT	D			(waits for sqrt if single-task, loops if multi-task)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000010101		GETQX	D			(waits for cordic if single-task, loops if multi-task)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000010110		GETQY	D			(waits for cordic if single-task, loops if multi-task)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000010111		GETQZ	D			(waits for cordic if single-task, loops if multi-task)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000011000		GETPHSA	D
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000011001		GETPHZA	D			(clears phsa)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000011010		GETCOSA	D
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000011011		GETSINA	D
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000011100		GETPHSB	D
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000011101		GETPHZB	D			(clears phsb)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000011110		GETCOSB	D
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000011111		GETSINB	D
    ZCM-		1111111 ZC 0 CCCC DDDDDDDDD 000100000		PUSHZC	D
    ZCM-		1111111 ZC 0 CCCC DDDDDDDDD 000100001		POPZC	D
    ZCM-		1111111 ZC 0 CCCC DDDDDDDDD 000100010		SUBCNT	D			(subtracts D from CNT, then CNTX if same thread)
    ZCM-		1111111 ZC 0 CCCC DDDDDDDDD 000100011		GETPIX	D			(takes 3 clocks, needs 3 clocks in prior two stages, condition only gates writes)
    ZCM-		1111111 ZC 0 CCCC DDDDDDDDD 000100100		BINBCD	D
    ZCM-		1111111 ZC 0 CCCC DDDDDDDDD 000100101		BCDBIN	D
    ZCM-		1111111 ZC 0 CCCC DDDDDDDDD 000100110		BINGRY	D
    ZCM-		1111111 ZC 0 CCCC DDDDDDDDD 000100111		GRYBIN	D			(takes two clocks)
    ZCM-		1111111 ZC 0 CCCC DDDDDDDDD 000101000		ESWAP4	D
    ZCM-		1111111 ZC 0 CCCC DDDDDDDDD 000101001		ESWAP8	D
    ZCM-		1111111 ZC 0 CCCC DDDDDDDDD 000101010		SEUSSF	D
    ZCM-		1111111 ZC 0 CCCC DDDDDDDDD 000101011		SEUSSR	D
    ZCM-		1111111 ZC 0 CCCC DDDDDDDDD 000101100		SPLITB	D			(also MERGEN)
    ZCM-		1111111 ZC 0 CCCC DDDDDDDDD 000101101		MERGEB	D			(also SPLITN)
    ZCM-		1111111 ZC 0 CCCC DDDDDDDDD 000101110		SPLITW	D
    ZCM-		1111111 ZC 0 CCCC DDDDDDDDD 000101111		MERGEW	D
    ZCM-		1111111 ZC 0 CCCC DDDDDDDDD 000110000		CHKDEC	D			(if decimal, makes nibble, c=1)
    ZCM-		1111111 ZC 0 CCCC DDDDDDDDD 000110001		CHKHEX	D			(if hexadecimal, makes nibble, c=1)
    ZCM-		1111111 ZC 0 CCCC DDDDDDDDD 000110010		CHKLET	D			(if letter/"_", makes uppercase, c=1)
    ZCM-		1111111 ZC 0 CCCC DDDDDDDDD 000110011		CHKSYM	D			(if letter/"_"/numeral, makes uppercase, c=1)
    ZCM-		1111111 ZC 0 CCCC DDDDDDDDD 000110100		INCD	D			(D += $200)
    ZCM-		1111111 ZC 0 CCCC DDDDDDDDD 000110101		DECD	D			(D -= $200)
    ZCM-		1111111 ZC 0 CCCC DDDDDDDDD 000110110		INCDS	D			(D += $201)
    ZCM-		1111111 ZC 0 CCCC DDDDDDDDD 000110111		DECDS	D			(D -= $201)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000111000		POPT0	D			(pops from task 0's 4-level stack)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000111001		POPT1	D			(pops from task 1's 4-level stack)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000111010		POPT2	D			(pops from task 2's 4-level stack)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000111011		POPT3	D			(pops from task 3's 4-level stack)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000111100		POP	D			(pops from task's 4-level stack)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000111101		<empty>	D
    ZCM-		1111111 ZC 0 CCCC DDDDDDDDD 000111110		INCPAT	D			(takes four clocks)
    ZCM-		1111111 ZC 0 CCCC DDDDDDDDD 000111111		DECPAT	D			(takes four clocks)
    --L-		1111111 00 L CCCC DDDDDDDDD 001iiiiii		REPD	D/#1..512,#1..64	(REPD $1FF,#1..64 = infinite repeat, can use REPD #i)
    --L-		1111111 00 L CCCC DDDDDDDDD 010000000		CLKSET	D/#			(waits for hub)
    --L-		1111111 00 L CCCC DDDDDDDDD 010000001		COGSTOP	D/#			(waits for hub)
    -CL-		1111111 0C L CCCC DDDDDDDDD 010000010		LOCKSET	D/#			(waits for hub)
    -CL-		1111111 0C L CCCC DDDDDDDDD 010000011		LOCKCLR	D/#			(waits for hub)
    --L-		1111111 00 L CCCC DDDDDDDDD 010000100		LOCKRET	D/#			(waits for hub)
    --L-		1111111 00 L CCCC DDDDDDDDD 010000101		RDWIDE	D/PTRA/PTRB		(waits for hub)
    --L-		1111111 00 L CCCC DDDDDDDDD 010000110		RDWIDEC	D/PTRA/PTRB		(waits for hub if dcache miss)
    --L-		1111111 00 L CCCC DDDDDDDDD 010000111		RDWIDEQ	D/PTRA/PTRB		(waits for hub, doesn't affect dcache address/valid, waits 3 extra clocks)
    ZCL-		1111111 ZC L CCCC DDDDDDDDD 010001000		GETP	D/#			(pin into !Z/C via WZ/WC)
    ZCL-		1111111 ZC L CCCC DDDDDDDDD 010001001		GETNP	D/#			(pin into Z/!C via WZ/WC)
    -CL-		1111111 0C L CCCC DDDDDDDDD 010001010		SEROUTA	D/#			(waits for tx if single-task, loops if multi-task, releases if WC)
    -CL-		1111111 0C L CCCC DDDDDDDDD 010001011		SEROUTB	D/#			(waits for tx if single-task, loops if multi-task, releases if WC)
    -CL-		1111111 0C L CCCC DDDDDDDDD 010001100		CMPCNT	D/#			(subtracts D from CNT, then CNTX if same thread)
    -CL-		1111111 0C L CCCC DDDDDDDDD 010001101		WAITPX	D/#			(waits for any edge, +CNT if WC)
    -CL-		1111111 0C L CCCC DDDDDDDDD 010001110		WAITPR	D/#			(waits for pos edge, +CNT if WC)
    -CL-		1111111 0C L CCCC DDDDDDDDD 010001111		WAITPF	D/#			(waits for neg edge, +CNT if WC)
    --L- wrD	1111111 ZC L CCCC DDDDDDDDD 010010000		COGNEW	D/#			(waits for hub)
    --L- wrD	1111111 ZC L CCCC DDDDDDDDD 010010001		COGNEWX	D/#			(waits for hub)
    --L-		1111111 00 L CCCC DDDDDDDDD 010010010		SETXCH	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010010011		SETTASK	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010010100		SETRACE	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010010101		SARACCA	D/#			(waits for mac)
    --L-		1111111 00 L CCCC DDDDDDDDD 010010110		SARACCB	D/#			(waits for mac)
    --L-		1111111 00 L CCCC DDDDDDDDD 010010111		SARACCS	D/#			(waits for mac)
    --L-		1111111 00 L CCCC DDDDDDDDD 010011000		SETPTRA	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010011001		SETPTRB	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010011010		ADDPTRA	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010011011		ADDPTRB	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010011100		SUBPTRA	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010011101		SUBPTRB	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010011110		SETWIDE	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010011111		SETWIDZ	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010100000		SETPTRX	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010100001		SETPTRY	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010100010		ADDPTRX	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010100011		ADDPTRY	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010100100		SUBPTRX	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010100101		SUBPTRY	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010100110		PASSCNT	D/#			(takes two clocks, loops if (CNT - D) msb set)
    --L-		1111111 00 L CCCC DDDDDDDDD 010100111		WAIT	D/#			(waits 1+ clocks, 0 same as 1)
    --L-		1111111 00 L CCCC DDDDDDDDD 010101000		OFFP	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010101001		NOTP	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010101010		CLRP	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010101011		SETP	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010101100		SETPC	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010101101		SETPNC	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010101110		SETPZ	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010101111		SETPNZ	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010110000		DIV64D	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010110001		SQRT32	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010110010		QLOG	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010110011		QEXP	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010110100		SETQI	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010110101		SETQZ	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010110110		CFGDACS	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010110111		SETDACS	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010111000		CFGDAC0	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010111001		CFGDAC1	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010111010		CFGDAC2	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010111011		CFGDAC3	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010111100		SETDAC0	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010111101		SETDAC1	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010111110		SETDAC2	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010111111		SETDAC3	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011000000		SETCTRA	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011000001		SETWAVA	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011000010		SETFRQA	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011000011		SETPHSA	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011000100		ADDPHSA	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011000101		SUBPHSA	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011000110		SETVID	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011000111		SETVIDY	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011001000		SETCTRB	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011001001		SETWAVB	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011001010		SETFRQB	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011001011		SETPHSB	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011001100		ADDPHSB	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011001101		SUBPHSB	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011001110		SETVIDI	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011001111		SETVIDQ	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011010000		SETPIX	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011010001		SETPIXZ	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011010010		SETPIXU	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011010011		SETPIXV	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011010100		SETPIXA	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011010101		SETPIXR	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011010110		SETPIXG	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011010111		SETPIXB	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011011000		SETPORA	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011011001		SETPORB	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011011010		SETPORC	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011011011		SETPORD	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011011100		RDWIDEA	D/#1..512
    --L-		1111111 00 L CCCC DDDDDDDDD 011011101		RDWIDEB	D/#1..512
    --L-		1111111 00 L CCCC DDDDDDDDD 011011110		WRWIDEA	D/#1..512
    --L-		1111111 00 L CCCC DDDDDDDDD 011011111		WRWIDEB	D/#1..512
    --L-		1111111 00 L CCCC DDDDDDDDD 011100x00		TARGOFF	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011100001		TARG	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011100010		TARGP	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011100011		TARGN	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011100101		TARGX	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011100110		TARGPX	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011100111		TARGNX	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011101000		JMPT0	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011101001		JMPT1	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011101010		JMPT2	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011101011		JMPT3	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011101100		PUSHT0	D/#			(pushes into task 0's 4-level stack)
    --L-		1111111 00 L CCCC DDDDDDDDD 011101101		PUSHT1	D/#			(pushes into task 1's 4-level stack)
    --L-		1111111 00 L CCCC DDDDDDDDD 011101110		PUSHT2	D/#			(pushes into task 2's 4-level stack)
    --L-		1111111 00 L CCCC DDDDDDDDD 011101111		PUSHT3	D/#			(pushes into task 3's 4-level stack)
    --L-		1111111 00 L CCCC DDDDDDDDD 011110000		PUSH	D/#			(pushes into task's 4-level stack)
    --L-		1111111 ZC L CCCC DDDDDDDDD 011110001		SETZC	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011110010		SETLFSR	D/#
    --R-		1111111 00 x CCCC DDDDDDDDD 100000000		LOCPTRA	D			(PTRA = {D[15:0],%00})	(D[31:30] into Z/C via WZ/WC for LOCPTRA..CALLYD D)
    --R-		1111111 00 x CCCC DDDDDDDDD 100000001		LOCPTRB	D			(PTRB = {D[15:0],%00})
    --R-		1111111 ZC x CCCC DDDDDDDDD 100000010		JMP	D
    --R-		1111111 ZC x CCCC DDDDDDDDD 100000011		JMPD	D
    --R- wr0	1111111 ZC x CCCC DDDDDDDDD 100000100		LINK	D			(jump, write {Z,C,%00000000000000,P} to $000)
    --R- wr0	1111111 ZC x CCCC DDDDDDDDD 100000101		LINKD	D
    --R-		1111111 ZC x CCCC DDDDDDDDD 100000110		CALL	D
    --R-		1111111 ZC x CCCC DDDDDDDDD 100000111		CALLD	D
    --R-		1111111 ZC x CCCC DDDDDDDDD 100001000		CALLA	D
    --R-		1111111 ZC x CCCC DDDDDDDDD 100001001		CALLAD	D
    --R-		1111111 ZC x CCCC DDDDDDDDD 100001010		CALLB	D
    --R-		1111111 ZC x CCCC DDDDDDDDD 100001011		CALLBD	D
    --R-		1111111 ZC x CCCC DDDDDDDDD 100001100		CALLX	D
    --R-		1111111 ZC x CCCC DDDDDDDDD 100001101		CALLXD	D
    --R-		1111111 ZC x CCCC DDDDDDDDD 100001110		CALLY	D
    --R-		1111111 ZC x CCCC DDDDDDDDD 100001111		CALLYD	D
    --R-		1111111 00 x CCCC DDDDDDDDD 100010000		LODINDA	D
    --R-		1111111 00 x CCCC DDDDDDDDD 100010001		LODINDB	D
    ZC--		1111111 ZC x CCCC xxxxxxxxx 110000000		RETA
    ZC--		1111111 ZC x CCCC xxxxxxxxx 110000001		RETAD
    ZC--		1111111 ZC x CCCC xxxxxxxxx 110000010		RETB
    ZC--		1111111 ZC x CCCC xxxxxxxxx 110000011		RETBD
    ZC--		1111111 ZC x CCCC xxxxxxxxx 110000100		RETX
    ZC--		1111111 ZC x CCCC xxxxxxxxx 110000101		RETXD
    ZC--		1111111 ZC x CCCC xxxxxxxxx 110000110		RETY
    ZC--		1111111 ZC x CCCC xxxxxxxxx 110000111		RETYD
    ZC--		1111111 ZC x CCCC xxxxxxxxx 110001000		RET
    ZC--		1111111 ZC x CCCC xxxxxxxxx 110001001		RETD
    ZC--		1111111 ZC x CCCC xxxxxxxxx 110001010		POLCTRA				(ctra-rollover into !Z/C)
    ZC--		1111111 ZC x CCCC xxxxxxxxx 110001011		POLCTRB				(ctra-rollover into !Z/C)
    ZC--		1111111 ZC x CCCC xxxxxxxxx 110001100		POLVID				(vid-ready into !Z/C)
    ----		1111111 00 x CCCC xxxxxxxxx 110001101		CAPCTRA
    ----		1111111 00 x CCCC xxxxxxxxx 110001110		CAPCTRB
    ----		1111111 00 x CCCC xxxxxxxxx 110001111		CAPCTRS
    ----		1111111 00 x CCCC xxxxxxxxx 110010000		SETPIXW
    ----		1111111 00 x CCCC xxxxxxxxx 110010001		CLRACCA
    ----		1111111 00 x CCCC xxxxxxxxx 110010010		CLRACCB
    ----		1111111 00 x CCCC xxxxxxxxx 110010011		CLRACCS
    ZC--		1111111 ZC x CCCC xxxxxxxxx 110010100		CHKPTRX
    ZC--		1111111 ZC x CCCC xxxxxxxxx 110010101		CHKPTRY
    ----		1111111 00 x CCCC xxxxxxxxx 110010110		SYNCTRA				(waits for ctra if single-task, loops if multi-task))
    ----		1111111 00 x CCCC xxxxxxxxx 110010111		SYNCTRB				(waits for ctrb if single-task, loops if multi-task))
    ----		1111111 00 x CCCC xxxxxxxxx 110011000		DCACHEX
    ----		1111111 00 x CCCC xxxxxxxxx 110011001		ICACHEX
    ----		1111111 00 x CCCC xxxxxxxxx 110011010		ICACHEP
    ----		1111111 00 x CCCC xxxxxxxxx 110011011		ICACHEN
    ----		1111111 00 x 0000 xxxxxxxxx 110011100		TLOCK
    ----		1111111 00 x 0000 xxxxxxxxx 110011101		TFREE
    ----		1111111 00 x 0000 xxxxxxxxx 110011110		LOADT3
    ----		1111111 00 x 0000 xxxxxxxxx 110011111		SAVET3
    ----		1111111 00 x 0000 xxxxxxxxx 110100x00		TARGOFF
    ----		1111111 00 x 0000 xxxxxxxxx 110100001		TARG
    ----		1111111 00 x 0000 xxxxxxxxx 110100010		TARGP
    ----		1111111 00 x 0000 xxxxxxxxx 110100011		TARGN
    ----		1111111 00 x 0000 xxxxxxxxx 110100101		TARGX
    ----		1111111 00 x 0000 xxxxxxxxx 110100110		TARGPX
    ----		1111111 00 x 0000 xxxxxxxxx 110100111		TARGNX
    ----		1111111 00 x 0000 xxxxxxxxx 110101000		PASSTXA
    ----		1111111 00 x 0000 xxxxxxxxx 110101001		PASSTXB
    ----		0000000 00 0 0000 000000000 000000000		NOP
    x = don't care, use 0
    Z	effect
    0	<none>
    1	wz
    C	effect
    0	<none>
    1	wc
    L	DDDDDDDDD	destination operand
    0/na	DDDDDDDDD	register
    1	#DDDDDDDDD	immediate, zero-extended
    I	SSSSSSSSS	source operand
    0/na	SSSSSSSSS	register
    1	#SSSSSSSSS	immediate, zero-extended
    CCCC	condition	(easier-to-read list)
    0000	never		1111	if_always	(default)
    0001	nc  &  nz	1100	if_c				if_b	if_x1
    0010	nc  &  z	0011	if_nc				if_ae	if_x0
    0011	nc		1010	if_z				if_e	if_1x
    0100	 c  &  nz	0101	if_nz				if_ne	if_0x
    0101	nz		1000	if_c_and_z	if_z_and_c		if_11
    0110	 c  <> z	0100	if_c_and_nz	if_nz_and_c		if_01
    0111	nc  |  nz	0010	if_nc_and_z	if_z_and_nc		if_10
    1000	 c  &  z	0001	if_nc_and_nz	if_nz_and_nc	if_a	if_00
    1001	 c  =  z	1110	if_c_or_z	if_z_or_c	if_be	if_not_00
    1010	 z		1101	if_c_or_nz	if_nz_or_c		if_not_10
    1011	nc  |  z	1011	if_nc_or_z	if_z_or_nc		if_not_01
    1100	 c		0111	if_nc_or_nz	if_nz_or_nc		if_not_11
    1101	 c  |  nz	1001	if_c_eq_z	if_z_eq_c		if_same
    1110	 c  |  z	0110	if_c_ne_z	if_z_ne_c		if_diff
    1111	always		0000	if_never
    CCCC	inda/indb - CCCC=1111 after stage 2 of pipeline if inda/indb used (indx=inda/indb)
    xx00	source indx
    xx01	source indx++
    xx10	source indx--
    xx11	source ++indx
    00xx	destination indx
    01xx	destination indx++
    10xx	destination indx--
    11xx	destination ++indx
    There are actually 12 other instructions which are aliases of certain cases of the main instructions:
    SWITCH
    SWITCHD
    MERGEN D/#
    SPLITN D/#
    PUSHA D/#
    PUSHB D/#
    PUSHX D/#
    PUSHY D/#
    POPA D/#
    POPB D/#
    POPX D/#
    POPY D/#
    You can imagine what they are, but these will be getting documented, too.
    This, Heater, brings the total instruction count to 459.
    edited 2014-03-20 02:37
    Thanks Chip,
    Time to play... :):):)
  • BaggersBaggers Posts: 3,019
    edited 2014-03-20 03:05
    Cheers Chip, I know what I'll be doing tonight :D
    edited 2014-03-20 03:22
    Chip,
    I'm cool with that. My brain exploded about two hundred pages back in this thread, I can't count that far any more:)
    edited 2014-03-20 03:25
    Dear {your employer},
    {Your name} is not feeling well today. It appears to be contagious and I suggest he/she stay home to work out any bugs that are found.
    Sincerely,
    Dr. Parallax II
    Feel free to use it if needed.
    edited 2014-03-20 03:42
    mindrobots,
    Thank you. A most generous offer. I'm sure I will arrive at a subset of instructions that I can hold in my sponge brain :)
    edited 2014-03-20 03:56
    Heater. wrote: »
    mindrobots,
    Remember, they're just friends that you haven't met yet. They all want to help you. Some are even waiting to do things that you'd be embarrassed to ask for, like convert English characters to upper-case, or tell you if you have a decimal digit, or not. And SEUSSF/SEUSSR are there to entertain you, should the need arise.
    edited 2014-03-20 04:24
    Heater. wrote: »
    mindrobots,
    You're quite welcome but this was more an offer to those that might be feeling a bit 'off' at work today and need some time at home to take care of the new release.
    Chip, I like the 'new friends' approach, my only problem is I'm really bad with names (both people and instructions) so most of my time is spent with "that guy looks familiar..dang, what was his name?"
    Now, the little tease about SEUSSF/SEUSSR has made me curious!
  • ozpropdevozpropdev Posts: 2,791
    edited 2014-03-20 04:40
    SEUSSF D - Seeds random pattern generator. After 32 iterations original value is returned.
    Pass # 1  SEUSSF D D=$1234_5678 returns D=$1874_6EDB
    Pass # 2  SEUSSF D D=$1874_6EDB returns D=$7A7C_61F3
    Pass # 3  SEUSSF D D=$7A7C_61F3 returns D=$4D54_61A7
    Pass # 4  SEUSSF D D=$4D54_61A7 returns D=$6542_21B0
    Pass # 5  SEUSSF D D=$6542_21B0 returns D=$6D47_BD00
    Pass # 6  SEUSSF D D=$6D47_BD00 returns D=$27EE_9908
    Pass # 7  SEUSSF D D=$27EE_9908 returns D=$86CE_BC4E
    Pass # 8  SEUSSF D D=$86CE_BC4E returns D=$96BA_BD7D
    Pass # 9  SEUSSF D D=$96BA_BD7D returns D=$8EB3_775F
    Pass #10  SEUSSF D D=$8EB3_775F returns D=$883B_13FB
    Pass #11  SEUSSF D D=$883B_13FB returns D=$6815_127F
    Pass #12  SEUSSF D D=$6815_127F returns D=$3850_0229
    Pass #13  SEUSSF D D=$3850_0229 returns D=$3045_6041
    Pass #14  SEUSSF D D=$3045_6041 returns D=$355C_C5C1
    Pass #15  SEUSSF D D=$355C_C5C1 returns D=$65FE_64C4
    Pass #16  SEUSSF D D=$65FE_64C4 returns D=$F57A_3D86
    Pass #17  SEUSSF D D=$F57A_3D86 returns D=$672B_7D2E
    Pass #18  SEUSSF D D=$672B_7D2E returns D=$0663_9FAE
    Pass #19  SEUSSF D D=$0663_9FAE returns D=$42E3_9C7B
    Pass #20  SEUSSF D D=$42E3_9C7B returns D=$9EF5_943B
    Pass #21  SEUSSF D D=$9EF5_943B returns D=$9CA6_407B
    Pass #22  SEUSSF D D=$9CA6_407B returns D=$BC16_F2F3
    Pass #23  SEUSSF D D=$BC16_F2F3 returns D=$7996_73E9
    Pass #24  SEUSSF D D=$7996_73E9 returns D=$E054_7388
    Pass #25  SEUSSF D D=$E054_7388 returns D=$600C_2D89
    Pass #26  SEUSSF D D=$600C_2D89 returns D=$666C_A705
    Pass #27  SEUSSF D D=$666C_A705 returns D=$01EA_A507
    Pass #28  SEUSSF D D=$01EA_A507 returns D=$A5E9_B576
    Pass #29  SEUSSF D D=$A5E9_B576 returns D=$ADB3_8D6E
    Pass #30  SEUSSF D D=$ADB3_8D6E returns D=$A6B3_1A62
    Pass #31  SEUSSF D D=$A6B3_1A62 returns D=$9317_1E6B
    Pass #32  SEUSSF D D=$9317_1E6B returns D=$1234_5678
  • SapiehaSapieha Posts: 2,964
    edited 2014-03-20 04:41
    Hi Chip.
    I have one question?
    Can't PNut cut filling 0000000 in bin file to first ORGH position --->
    That will give simpler make separately loaded modules.
    edited 2014-03-20 04:57
    re: Terasic_Prop2_Emulation_2014_03_20.zip
    Thanks! for the update
    My USB blaster is working away. :cool:
    edited 2014-03-20 05:01
    ozpropdev wrote: »
    Party pooper!! :lol:
    Thanks! I was going to do the same thing with your handy dandy tool!
    edited 2014-03-20 05:03
    mindrobots,
    Sorry, yes, now I'm with you. You know, I not feeling so good myself, perhaps I should go home and take some Parallaxetamol.
    edited 2014-03-20 05:10
    Heater. wrote: »
    mindrobots,
    Be careful, it kind of sneaks up on you in 459 different ways. Next thing you know, you have pre-emptive threads! You don't want coworkers to see that!
