1. Make sure that there is sufficient battery voltage available. Even better, connect to a suitable power supply.
2. Make sure that the BS2 is receiving adequate 5V
3. Make sure that your programming connection (USB or serial) is correctly hooked up.
4. Try downloading a simple program to your BS2 that consists of a DEBUG "Hello World!", CR
5. Test each output pin with a pair of LEDs (one for source, one for sink).
Follow a standard procedure:
If it passes all these tests, your BS2 is good.
SOON has come come and gone, but I would still love a good read up on this subject.
"A complex design is the sign of an inferior designer."
