Just thinking to myself, after looking at all the objects on the object library page. Is there a way to tell how many cogs each object will require to run? Would a part time cog be a #.1?
Count the number of COGNEWs used, if a COGNEW calls non-ending code, it is a permanent cog. If the code returns, it is a temporary cog (spin code doesn't do an infinite loop, or asm does a COGID, COGSTOP). The total amount of permanent and temporary cogs running at any time must be 8 or fewer.
I suppose my question was more of a request than a question, and should have been directed towards the IT department [noparse]:([/noparse] But, from a designer's perspective, wouldn't it be easy to add a column to the chart, so you would be able to know offhand. OH, and I forgot the other thing, I'm lazy [noparse]:)[/noparse]
1+1=10
-Parsko
