Home brew demo Board — Parallax Forums
Mike CookMike Cook Posts: 829
edited 2006-05-24 15:32 in Propeller 1
I would like to go ahead and start constructing a home made demo board to use with the Propeller while I wait for the Propeller to ship. I am starting with the schematic posted here:
http://forums.parallax.com/attachment.php?attachmentid=41055
and will be adding the composite video out circuit as shown below:
For color composite video out you need three pins, three resistors, and an RCA jack:
A12 -----[noparse][[/noparse] 1.1k ]----*-----> composite out
A13 -----[noparse][[/noparse] 560 ]-----*
A14 -----[noparse][[/noparse] 270 ]-----+
I have a few questions for Parallax or anyone that presently has a demo board:
1. I am planning on using a 5MHz crystal, what type of crystal is needed for the Propeller? Load Capacitance: specified or series?
2. The resistors for the composite circuit, do they need to be 1% or will 5% due.
3. The pin out the composite circuit, is this the default for the TV.SPIN object.
«13
    edited 2006-04-02 03:46
    OK, I think I found the answer for my crystal question, posted here in Ken's *.PDF, last page:
    http://forums.parallax.com/showthread.php?p=572669
    Note that no external resistors or capacitors are required for crystals and resonators.
    OSCM1   OSCM0   XOUT Resistance   XIN/XOUT Capacitance   Frequency Range
      0       1        2000 Ohms             36pF              4MHz to 16MHz Crystal/Resonator
    So am I correct in assuming that I can use a crystal with a specified capacitance of 20pF as long as I don't exceed 36pF? This is the one I'm thinking about ordering:
    http://www.ecsxtal.com/pdf3/HC_49US.pdf
    http://www.mouser.com/index.cfm?handler=displayproduct&lstdispproductid=201077&e_categoryid=26&e_pcodeid=52003
  • Beau SchwabeBeau Schwabe Posts: 6,547
    edited 2006-04-02 04:11
    Mike,
    If you are interested in doing video, the cut of the crystal does matter.
    I will try to find out the difference and let you know.
    You can compensate for the crystal cut in software by adding an offset of 3000Hz to the actual
    crystal frequency you are using and specifying the '_xinfreq=' value in the IDE with that offset.
    Beau Schwabe
    IC Layout Engineer
    edited 2006-04-02 18:30
    Hopefully the schematic that Ken posted here:
    Here's what's left to do....
    1. USB2SER & 24LC256 will be here Tuesday April 4, 2006 + 2 types of 5 MHz xtals, (20pF and series)
    2. 3.3 volt PS works and I've electrically checked the board verses the schematic
    3. Need to add a +5VDC supply
    4. Mount this board to a chunk of LEXAN
    5. Add 2 RS 276-174 plastic proto boards
    6. Mount the Matrix Orbital LCD2041 serial display
    ·attachment.php?attachmentid=41077
    Post Edited (Mike Cook) : 4/2/2006 7:07:05 PM GMT
    1267 x 978 - 446K
    edited 2006-04-02 19:08
    Do you have pull-ups on the SDA and SCL lines of the 24LC256 (connect them to Vdd, not the RST line)? Even through the Propeller drives the SCL line when loading it's program, you may want to put a pull-up on this line to work with the I2C object I'm writing -- that can use those same pins.
    Jon Williams
    edited 2006-04-02 19:15
    Jon,
    No I do not have pull up's in the SDA & SCL lines, thought it was strange that they did not have these. I followed the schematic that Ken Gracey posted here:
    I usually use pull up's on AVRs, but I was just following the schematic that Ken Gracey posted.
    What you would you suggest 4.7K's?
    Is there a problem with the posted schematic?
    The schematic that·Ken Gracey posted seems to be the same·that was posted·on this forum and published in the April edition of Nuts & Volts.
    Post Edited (Mike Cook) : 4/2/2006 7:39:14 PM GMT
    edited 2006-04-02 19:40
    4.7k is fine. Our demo board has a pull-up on the SDA only because it drives the SCL pin -- but if you write an I2C object that doesn't do that you'll need the pull-up; it's cheap, you might as well do it. And please trust me that they should be connected to Vdd of the board's supply, not RST of the USB2SER (it won't hurt, it's just that when the USB2SER is gone, so is the voltage for your pull-up(s).
    Jon Williams
    edited 2006-04-02 19:45
    So if I am understanding you correctly I should·include the 10K between the SDA and the RST on the USB2SER·in the original schematic and add 4.7k's to SDA & SCL to VDD?
    Like this? 10k from USB2SER· to SDA (Propeller pin 38) is under the ZIF socket.
    ·attachment.php?attachmentid=41078
    Post Edited (Mike Cook) : 4/2/2006 8:04:17 PM GMT
    1151 x 884 - 358K
    edited 2006-04-02 20:04
    No; remove the 10K between RST and SDA. Connect SDA to 3.3v through a 4.7K (standard I2C pull-up); same for the SCL line. The schematic shown will only work if the USB2SER is plugged in -- should you test in stand-alone mode without the USB2SER (where the program is loaded from the EEPROM) it won't work because the SDA pull-up will have no power so you'll get nothing but zeros from the EE.
    Jon Williams
    edited 2006-04-02 20:10
    OK, deleting (cutting destroying the 10K between the USB2SER (RES)·to PIN 38 Propeller SDA)·as shown on the the propeller schematic posted here:
    SDA & SCL are now pulled up to +3.3 via a 4.7K resistor on each line.
    So what I gather form this conversation is that there is an ERROR in the original schematic as posted here:
    and in the April 2006 Nuts & Volts Atricle. The RES from the USB2SER should only go to PIN 11 of the propeller chip (RESn)·and NOT be connected via a 10K series resistor to pin 38 (Propeller SDA) for stand alone operation. Is there any harm in in including it?. Is it needed for programming the Propeller via the IDE?
    Thanks Jon!
    Post Edited (Mike Cook) : 4/2/2006 9:16:40 PM GMT
  • Brian RileyBrian Riley Posts: 626
    edited 2006-04-02 22:13
    What is the word on a crystal? What frequency do we want and what cut? I have a bunch here 2, 4, 8, 20, and 50 MHz series cut ~20pf ... can I use any of them? I have resonators at 4, 8, 20, and 50 MHz. any of them?
    cheers ... BBR
    cheers ... brian riley, n1bq, underhill center, vermont
    edited 2006-04-02 23:04
    Let me try again:·That circuit will work -- but only if you leave the USB2SER plugged in and connected to your computer.· Since the USB2SER is a programming device and won't always remain connected, using its RST line (normally high) to pull-up the SDA is not really a great idea.· I have sent a note to the person who drew the schematic to get it corrected in a manner that will work with or without the USB2SER.· Keep things simple, use your 3.3v supply for the SDA and SCL pull-ups.· The only thing that the USB2SER.RST line should connect to is the Propellers RSTn pin.· BTW, if you want a reset button on your board, connect a n.o. pushbutton between RESn and Vss.
    Mike Cook said...
    Thanks Jon!
    Jon Williams
    edited 2006-04-03 01:40
    OK, Understood, the posted schematic will work as long as the USB2SER stays connected.
    So my last changes to the curcuit of deleting the 10k between the USB2SER.RES to the Propeller.PIN38 (SDA) and adding the 4.7K pull ups to SDA and SCL on the 24LC256 to +3.3VDC·seem to be correct.
    With the USB2SER disconnected, what state should the Propeller PIN11 (RESn) be? Should it be left floating or tied to +3.3 VDC with a weak pull up such as a 10K·or 100K?
    I'll probably add the reset button to the circuit next.
    Thanks Jon,
    Post Edited (Mike Cook) : 4/3/2006 1:56:04 AM GMT
    edited 2006-04-03 02:41
    Brian,
    "What is the word on a crystal?"
    I still need to find out.... Only reason I bring this up, is that early on I was using a 10MHz out of a junk box, and
    the question came up with Chip as to why I was only seeing black and white on my TV monitor. He mentioned
    something about the crystal overtone messing with the synthesized color burst. I forget now if the crystal should
    be series cut or parallel cut. Perhaps Chip or Jeff can help to answer this question.
    Beau Schwabe
    IC Layout Engineer
  • cgraceycgracey Posts: 14,133
    edited 2006-04-03 04:14
    Hold on! This is not true. This works perfectly without the USB2SER plugged in. This was quite intentional and not a mistake. This is optimal for power consumption since during brown-outs, current is not going to be sourced into the EEPROM's SDA line when the EEPROM is potentially pulling it low.
    With·BOEn·wired low, the RESn pin will pull high via an internal 5k resistor·as long as·VDD is above ~2.6V. If VDD drops below this threshold, the RESn pin will pull low via the same 5k resistor and hold the Propeller in reset mode. Because the RESn input is a Schmitt trigger, there is no problem using it as a pull-up source for SDA, as long as an additional resistor is used. A 10k works fine.
    The USB2SER and the Propeller Clip have only·a low-pulsing NPN transistor connected to their reset·output, and no pull-up, at all. The Propeller is doing the pull-up internally.
    What Jon's mainly concerned about is being able to use the existing I2C·connection for other I2C peripherals, not just the 24LC256. For such an application, two separate resistors on SDA and SCL to VDD is the way to go. The one-resistor-to-RESn is a minimal approach when only the EEPROM is connected and you want to keep things simple and lowest-power.
    Of course, you could connect I2C devices to ANY of the Propeller's pins. Jon would like to not waste another 2 pins, though, since 28 and 29 are already being used for I2C.
    Jon Williams (Parallax) said...
    Chip Gracey
    Post Edited (Chip Gracey) : 4/3/2006 4:33:11 AM GMT
    edited 2006-04-03 12:28
    Thanks Chip for clearing this up.
    I'll put the 10K back in the circuit and leave the additional 4.7K pull ups in on the SDA & SCL lines so I can use the I2C bus for other I2C chips.
    edited 2006-04-03 14:21
    Well, you might as well·get rid of the 10k from·SDA to RESn·if you'll also have a 4.7k from SDA to VDD. I think for your case, 4.7k resistors from SDA and SCL to VDD would be optimal. The alternative would be to have, perhaps, 20k resistors from SDA and SCL to RESn, but that's getting to be fairly high-impedance (you don't want to over-load RESn, as it IS a reset input, though Schmitt triggered, with a 5k output impedance).
    Mike Cook said...
    Chip Gracey
    edited 2006-04-03 14:27
    Chip,
    Good timing! I was heating up the soldering iron! I'll leave the 10K out, I had not had a chance to install it yet.
    Thanks to ALL·for the help!
    edited 2006-04-03 14:37
    Sorry, Mike, I've been so focused on developing Spin objects that I hadn't explored all the details of the RESn and BOEn lines.
    Jon Williams
    edited 2006-04-03 14:42
    Jon,
    No problem at all! There's always going to be a few "bumps in the road" when working with a new chip. In fact if you look to the right of the 24LC256 chip, in the above post, I'll probably put a 4 pin header there so I easily can extend the I2C bus out to the bread board or elsewhere.
    Thanks Again,
  • Kaos KiddKaos Kidd Posts: 614
    edited 2006-04-03 14:47
    Mike:
    I'm enjoying watching you progress with your project. I was wondering if you could post pics of both the front and back when your done?
    Some of the newbies and people like myself might enjoy seeing it, and how simple it is to make.
    KK
    Just tossing my two bits worth into the bit bucket
    KK
  • Paul Sr.Paul Sr. Posts: 435
    edited 2006-04-03 15:30
    Chip Gracey said...
    Well, you might as well get rid of the 10k from SDA to RESn if you'll also have a 4.7k from SDA to VDD. I think for your case, 4.7k resistors from SDA and SCL to VDD would be optimal. The alternative would be to have, perhaps, 20k resistors from SDA and SCL to RESn, but that's getting to be fairly high-impedance (you don't want to over-load RESn, as it IS a reset input, though Schmitt triggered, with a 5k output impedance).
    Mike Cook said...
    Chip,
    Thanks for the great info. Will there be updates to the schematics previously posted [noparse][[/noparse]by Ken]?
    Paul
    Well, I put my order in this morning for two Propeller chips, allegedly to be shipped May 1st and a USB2SER to be shipped today along with some other items. And, since I had to order some other parts from Mouser so I added some 5 MHz computer crystals, a couple in 20pf and a couple series cut. I figure one of them should work and at under $0.50 each its not a big loss if I figured wrong. I will socket the crystal anyway, so I can change it easily. I will start building up a demo board this week, photos to follow.
    edited 2006-04-03 15:38
    Brian Riley said...
    How did you place the order? I have been on the Propeller page several times this AM and cannot find any way to place my order. I thought they were just not ready yet..
    edited 2006-04-03 15:52
    KK,
    I will, probably won't be until this weekend though. Back of the board is not real pretty but it passes all the electrical and continuity tests against the posted schematic. Only thing I need to verify is the pin out the USB2SER. It should be here Tuesday.
    This board will be mounted to a chunk of LEXAN along with two plastic bread boards from Radio Shack, plus some other goodies. Will be adding a 5 volt regulator to this board so I can also power +5VDC stuff from the main supply.
    Post Edited (Mike Cook) : 4/3/2006 4:11:56 PM GMT
    edited 2006-04-03 16:44
    Just ordered 4 of the little GEMs, on line! Have not got an order confirmation yet but I imagine the Parallax sales staff·and servers are working in maximum over drive this morning!
    edited 2006-04-03 16:50
    Mike..
    Thanks. I'm seriously considering building my own Dev board. From what I'm reading, it's not brain surgery, but close enuff, but your success and documentation is really the deciding issue for me. See, due to my lack of expierence, when I start using the board and got unexpected results, I would be hard pressed to figure out if it's the dev board, the project wiring or the code. THat's the biggest advantage of getting a dev board pre made... no buggies in the hardware. Another good thing with a quality dev board would be issues from poor construction (I'm sure I'de get a lot of things like that). But, all in all, I really considering making the board.
    Do you think you'll add the PS2 ports, and Video to yours? I'm doing a lot of thinking here because when you go to a custom dev package, the world opens up... real wide and fast...
    KK
    edited 2006-04-03 17:57
    pwssr said...
    I ordered via landline ... but if you go to the propeller page there is now a hotlink on the DIP chip that will take you to a standard part page with an 'add to cart' button. The page is
    www.parallax.com/detail.asp?product_id=p8x32a-d40
    Good luck.
    edited 2006-04-03 18:02
    Brian Riley said...
    pwssr said...
    Good luck.
    Yes, thanks - I made my purchase a while ago as soon as the link was activated.
    Paul
  • Rob7Rob7 Posts: 275
    edited 2006-04-03 21:39
    Mike,
    I have not had the time look at all the spec's yet on this chip. I have a question for you?
    Do you need to run an current limiting resistor at any of the I/O pins before the chip. I would like to assemble a proto board also.
    I am just thinking ahead.
    What crystal are you useing?
  • Ken GraceyKen Gracey Posts: 7,386
    edited 2006-04-03 21:47
    Rob,
    See this link for crystals: http://forums.parallax.com/forums/default.aspx?f=25&m=118638
    Of course, you could always use the internal clock if you don't want full speed.
