Basic Stamp alarm
MacGeek117MacGeek117 Posts: 727
edited August 2005 in Robotics Vote Up0Vote Down
I'm working on an alarm using the BS2. It will sense a beam of IR across a doorway
and if that beam is broken, the BS2 will emit a 4000 Hz tone for 1 second.
So many projects, so little time.
  • 17 Comments sorted by Date Added Votes
  • MacGeek117MacGeek117 Posts: 727
    edited January 2005 Vote Up0Vote Down
    Note: you MUST read the text.
    bugg
    You might consider using the PIN definition to make the program easier to update or incorporate into other projects.
    Jon Williams
    Dallas, TX· USA
    Thank you, Jon!
    Guys, I made a revised version of the original software.
    The Tx is a 74LS04 osillator circuit.
    edited March 2005 Vote Up0Vote Down
    OK, I did it again. It works beter now!
    bugg
    Boe-bot: $229
    Toddler: $249
    Learning Google is your friend: priceless
  • The_N3rdThe_N3rd Posts: 34
    edited June 2005 Vote Up0Vote Down
    I tried the same thing, except that I used a laser pointer running off of a AC/DC power supply, and a·photoresistor to detect if the beam was interrupted.· When it· was it set off an alarm that didn’t turn off.·
    tongue.gif··
    the NERD, Kelie B.
    · If electricty comes from electrons, does morality come from morons?
    Thats the point! Just press the reset button.
    bugg
    Boe-bot: $229
    Toddler: $249
  • andy11667andy11667 Posts: 26
    edited July 2005 Vote Up0Vote Down
    i would like to do this can i do it with the boe bot board of education
    Yes you can.
    bugg
    Boe-bot: $229
    Toddler: $249
  • christian_hahn13christian_hahn13 Posts: 30
    edited August 2005 Vote Up0Vote Down
    I had actually tried this once, but instead of using a tube to focus the IR led I used an old camera lens.blush.gif
    I have posted a schematic of the project.
    bugg
    Boe-bot: $229
    Toddler: $249
    2160 x 1660 - 23K
  • RobbyRobby Posts: 5
    Hi gyes.This is my first time in this forum.I found it excellent.I am from greece .So ,my english are not very good.I would like to ask if we can use 2 ir leds in alarm.What do you think?THen the alarm will be better .in addition i have a circuit than can make the piezospeaker stronger.
    559 x 435 - 60K
  • Tronic (Greece)Tronic (Greece) Posts: 130
    Robby, you can use up to 7 IR pairs (LEDS - DETECTORS) or up to 15 simple photointerupters detectors to armor all over your place if you like!!
    The only problem I see is all the wiring along the house making your wife go crazy!!! lol.gif
  • Beau SchwabeBeau Schwabe Posts: 6,243
    Robby,
    If you want to increase the volume of a "raw piezo" (i.e no internal piezo circuitry), then
    see my reply in the "Stamps in Class" section several months ago about amplifying a piezo speaker.
    http://forums.parallax.com/showthread.php?p=464410
    [url=mailto:bschwabe@parallax.com]Beau Schwabe[/url]
    IC Layout Engineer
    Beau Schwabe -- Metallurgical Machine Design and Development Engineer
    ෴My Message෴www.Kit-Start.com - bschwabe@Kit-Start.com ෴෴ www.BScircuitDesigns.com - icbeau@bscircuitdesigns.com ෴෴
    "If nobody questions your dreams, then perhaps you're not dreaming big enough" - me
    I hadnt thought of this.we can put more than 2 ir leds.so ,thanks for the help on amplifying.In addition we can put a microphone and other sensors.the only thing we've to do is·to make the suitable programm.
    DONT REST UNTIL YOU BEAT THE BEST
    I have also posted a SX version.
    bugg
    Boe-bot: $229
    Toddler: $249
    2160 x 1660 - 25K
