Producing Boards. — Parallax Forums
Producing Boards.
m_fabio2m_fabio2 Posts: 49
edited 2004-12-22 00:48 in General Discussion
I'm using the LM34 in my company to measure room temperatures, and need to make a circuit board in order to mount. Something the size of a single gang box. What I am wondering whats the best way to make a circuit board. I see in IEEE magazine companies advertising services, such as www.PCB4u.com. I remeber using etching in college to make boards, but they always ended up needing more soldering than it was worth. Anyone have any suggestions ? I need to keep unit cost low. Thanks in advance.
  • steve_bsteve_b Posts: 1,563
    If you are only making a couple of these items then just go with a project board.
    Either a wire wrap board (perforated hole but no copper) or a project board (has copper traces or pads and must be "solder wired").
    You could use a couple of IC sockets and plug your LM34 in to that (if you expect to change it).
    I'd guess you might have a couple of caps on the board too....
    To note, there is a thread on this in the SANDBOX.
    Steve
    http://members.rogers.com/steve.brady
    http://www.geocities.com/paulsopenstage
