How to wire a voltage regulator? — Parallax Forums
Armored CarsArmored Cars Posts: 172
edited 2004-11-09 01:31 in General Discussion
I need to know how to wire a 3v voltage reg, it is a small one, looks like·a transistor.· So far I havent had any luck.
    Well, without knowing the exact device, I can only guide you just so far...Assuming (This is a guess without knowing the device part #) it is like a standard 78L05, if you are holding the device with the flat side facing you, pins aimed down, then it should be as follows...
    Left leg should be Vin
    Middle leg should be GND
    Right leg should be Vout
    As Jon is always saying: "You should always have the datasheet handy for·any part you are using in a project."
    Knight Designs
    324 West Main Street
    P.O. Box 97
    Montour Falls, NY 14865
    (607) 535-6777
    Business Page:·· http://www.knightdesigns.com
    Personal Page:··· http://www.lightlink.com/dream/chris
    Designs Page:··· http://www.lightlink.com/dream/designs
