A/D converter
Hello,
Can someone help me find a good A/D converter. I am looking for one that can go
down to 1mV, and interfaces with the stamp.
AC
  • 6 Comments sorted by Date Added Votes
    edited July 2002 Vote Up0Vote Down
    Ffor AC
    The TLC2543 is an excellent converter. Easy to program and has a 12-bit
    output. If you need programming help let me know. Samples are available
    from TI if you want to go to the trouble.
    Sid
    How hard is it to program?
    AC
    --- In basicstamps@y..., Newzed@a... wrote:
    > Ffor AC
    > Sid
    You need a Linear Tech LTC2400, a 24 bit chip, to get in the mv range. On
    their web site they have a BASIC Stamp connection example.
    Chuck
    In a message dated 7/8/02 20:09:34 Eastern Daylight Time, aconti@s...
    writes:
    > AC
    Not hard. Here's a sample.
    Adread:
    low cs
    pause 10
    shiftout SDATA, clk, msbfirst, [noparse][[/noparse]ADch<<8\12]
    pause 10
    shiftin sdi, clk, msbpre, [noparse][[/noparse]result\12]
    high cs
    goto counter
    return
    I think it has 7 channels, and you have to address each channel. If you get
    one and are in need of help let me know off-line.
    Sid
    I'm using the AD7730 from analog devices with the BS2,it accepts low level
    signals directly from a transducer and outputs a serial digital word.A
    recommended layout is important for the PCB that houses the AD7730.
    Regards
    Mohamed Refky
    >From: "Anthony Conti" <aconti@s...>
    >Reply-To: basicstamps@yahoogroups.com
    >To: <basicstamps@yahoogroups.com>
    >Subject: [noparse][[/noparse]basicstamps] A/D converter
    >Date: Mon, 8 Jul 2002 19:37:33 -0400
    >Hello,
    >can go down to 1mV, and interfaces with the stamp.
    >Thanks
    >AC
    >from the same email address that you subscribed. Text in the Subject and
    >Body of the message will be ignored.
    >Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    _________________________________________________________________
    Join the world’s largest e-mail service with MSN Hotmail.
    http://www.hotmail.com
