A/D converter — Parallax Forums
A/D converter
ArchiverArchiver Posts: 46,084
edited 2002-07-10 15:54 in General Discussion
Hello,
Can someone help me find a good A/D converter. I am looking for one that can go
down to 1mV, and interfaces with the stamp.
AC
  • ArchiverArchiver Posts: 46,084
    edited 2002-07-09 01:05
    Ffor AC
    The TLC2543 is an excellent converter. Easy to program and has a 12-bit
    output. If you need programming help let me know. Samples are available
    from TI if you want to go to the trouble.
    Sid
    edited 2002-07-09 01:08
    How hard is it to program?
    AC
    --- In basicstamps@y..., Newzed@a... wrote:
    > Ffor AC
    > Sid
    edited 2002-07-09 01:11
    You need a Linear Tech LTC2400, a 24 bit chip, to get in the mv range. On
    their web site they have a BASIC Stamp connection example.
    Chuck
    edited 2002-07-09 01:14
    In a message dated 7/8/02 20:09:34 Eastern Daylight Time, aconti@s...
    writes:
    > AC
    Not hard. Here's a sample.
    Adread:
    low cs
    pause 10
    shiftout SDATA, clk, msbfirst, [noparse][[/noparse]ADch<<8\12]
    pause 10
    shiftin sdi, clk, msbpre, [noparse][[/noparse]result\12]
    high cs
    goto counter
    return
    I think it has 7 channels, and you have to address each channel. If you get
    one and are in need of help let me know off-line.
    Sid
    I'm using the AD7730 from analog devices with the BS2,it accepts low level
    signals directly from a transducer and outputs a serial digital word.A
    recommended layout is important for the PCB that houses the AD7730.
    Regards
    Mohamed Refky
    >From: "Anthony Conti" <aconti@s...>
    >Reply-To: basicstamps@yahoogroups.com
    >To: <basicstamps@yahoogroups.com>
    >Subject: [noparse][[/noparse]basicstamps] A/D converter
    >Date: Mon, 8 Jul 2002 19:37:33 -0400
    >Hello,
    >can go down to 1mV, and interfaces with the stamp.
    >Thanks
    >AC
    >To UNSUBSCRIBE, just send mail to:
    >from the same email address that you subscribed. Text in the Subject and
    >Body of the message will be ignored.
    >Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    _________________________________________________________________
    Join the world’s largest e-mail service with MSN Hotmail.
    http://www.hotmail.com
