UltraSonic Drive to vaporize liquid — Parallax Forums
edited 2000-08-24 01:05 in General Discussion
Hi
I was wondering if anyone has info on an ultrasonic drive circuit to generate
high power ultrasonic pulses to vaporize liquid?
Also any info on ultrasonic crystal or element construction would be great.
Jon
    edited 2000-08-23 00:24
    Jon,
    I saw some water vaporizers at a craft store recently. Seems they're used
    to make fog for fountains. The whole assembly goes for less than $40 and
    looks like only two cubic inches or so...
    generate
    Mike Hardwick, for Decade Engineering -- <http://www.decadenet.com>
    Manufacturer of the famous BOB-II Serial Video Text Display Module!
    edited 2000-08-23 01:16
    At 03:06 PM 8/22/00 EDT, you wrote:
    >Hi
    generate
    I believe this is how 'cool air' household humidifiers work ie. Bionaire.
    It would likely be pretty simple to salvage the elelment from one of these...
    HTH, Duncan
    edited 2000-08-23 14:57
    My local electronics shop sells 40Khz ultrasonic transducers for $5.00 but I
    have know idea how to drive one. I too would like to vaporize small volumes
    of water.
    I would be more than happy to send one to you if you like. Maybe you'll be
    able to get it to work.
    Matthew
    To: <basicstamps@egroups.com>
    Sent: Tuesday, August 22, 2000 12:06 PM
    Subject: [noparse][[/noparse]basicstamps] UltraSonic Drive to vaporize liquid
    > Hi
    generate
    great.
    > Thanks
    > Jon
    edited 2000-08-23 16:03
    just beware high powered ultra sonic has a tendency to powder your bones and
    gall stones
    phxsys3@a... wrote:
    > Hi
    > Thanks
    > Jon
    edited 2000-08-23 17:26
    You can look at flea markets or drug stores for nebulizers or cold (not
    steam) humidifiers. The piezo element operates at high frequencies, in the
    mhz range. Here is a company that manufactures OEM nebulizer modules:
    http://www.americanpiezo.com/html/nebulizers.html
    -- Tracy Allen
    Electronically Monitored Ecosystems
    http://www.emesystems.com
    edited 2000-08-24 00:31
    Even lower-powered ultrasonic cleaners can interact with fluids of the inner
    ear, leading to a weird spaced-out feeling lasting for several hours.
    Dennis
    From: willem [noparse][[/noparse]mailto:willem]On Behalf Of will koopman
    Sent: Wednesday, August 23, 2000 8:03 AM
    To: basicstamps@egroups.com
    Subject: Re: [noparse][[/noparse]basicstamps] UltraSonic Drive to vaporize liquid
    gall stones
    phxsys3@a... wrote:
    > Hi
    generate
    great.
    > Thanks
    > Jon
    COOL can save on bar tabs
    > Dennis
    > gall stones
    > phxsys3@a... wrote:
    > > Hi
    > generate
    > great.
    > > Thanks
    > > Jon
