Proptool Library — Parallax Forums
Proptool Library
I've uninstalled the prop tool and reinstalled to a MyProgs folder to avoid windows ProgramFiles folder.
Now it won't recognize my new library folder.
I've read in other threads that it may be a registry problem: If so; Does anyone know how to go about that. ie: what to change?
Or am I barking the wrong tree?
    edited 2020-10-18 23:04
    HKEY_CURRENT_USER\Software\ParallaxInc\Propeller\1.3.2
    Check value: LibraryPaths
    Default value: C:\Program Files (x86)\Parallax Inc\Propeller Tool v1.3.2\Library\
    Change it to your path? No idea if this will work.
  • Will do. Thanks!
  • That did the trick, Thank you!
