waveforms detections
bluejay
Does anybody know how to display waveforms on the screen terminal such as square waves from a 555 timer instead of one's and zeros?
The simple program displays digits of one's and zeros. Thanks in advance.
' {$STAMP BS2}
' {$PBASIC 2.5}
'input ex1
'Syntax: COUNT Pin, Duration, Variable
'Syntax: PULSIN Pin, State, Variable
box PIN 4
result VAR Nib
DO
COUNT CR, box,result
'DEBUG ? box
DEBUG BIN box
'PAUSE 100
'PULSIN box,1,result
'DEBUG HOME,"input= ",DEC box
LOOP
__ __| |__COUNT CR, box,result
but the proper syntax is
COUNT pin, duration, variable
If box is your pin number, and you want to count for 1 second, then it would be
COUNT box, 1000, result.
If the rate of change is relatively slow, the display of a multi-level result can be made to scroll down the screen.
DO result = result+1 // 10 ' result cycles from 0 to 9 and back to zero, ' or result could be from your COUNT or an ADC DEBUG CR, REP "*"\result ' prints a line of that many stars PAUSE 32 ' slow it down a bit LOOP
