ECC memory
Rayman
in Propeller 2
Was just thinking about how my PC uptime increased rather dramatically when I switched to ECC memory.
I can go for months without rebooting now...
At the same time, my P1 based systems seem immune to bit flips on similar timescales...
I'm curious as to how this can be. I think P2 and P1 RAM is not ECC in any kind of way...
Anyway, maybe this is another idea for P3, ECC RAM. Or, maybe it's not an issue?
I don't think I've ever observed an error related to a bad bit in RAM....
I think it may the combination of low memory count and high memory size (physical volume) that makes it so you don't see soft errors in microcontrollers...
https://www.st.com/content/ccc/resource/technical/document/application_note/15/54/c4/5d/90/ed/4f/ce/DM00220769.pdf/files/DM00220769.pdf/jcr:content/translations/en.DM00220769.pdf
If it really matters, I guess make a twin copy of every variable and make sure they are identical before doing anything...
Still, I think ECC would ease minds...
Ok, that seems right. Thanks.
BTW: What does 6T mean? Is this the area of the cell?
Number of transistors. Two weak inverters (two transistors each) in a loop, plus two more transistors to access the state (read or forced override) makes six transistors.
Schematic here
