TIA - An interactive inline assembler for TAQOZ — Parallax Forums
Peter JakackiPeter Jakacki Posts: 10,193
edited 2021-08-07 20:24 in Forth
I have been putting off writing an assembler for ages, mainly because I didn't have a clue about many of the new P2 instructions. One of the other reasons I put it off was because I wanted the assembler to work with the same syntax as PASM does. However, I decided that any assembler is better than no assembler, and so I started the back-end of the assembler in Forth fashion. I still have a bit to go but I also have done the bulk of the back-end already and in non-surprising TAQOZ fashion, the code only takes around 1kB with another 2kB for the lexicon. So now I can start coding assembler in interactively with TAQOZ from the P2. Later on I will add a front-end that processes files in PASM fashion but ends up passing it to the back-end.
Here's a quick sample of a fast Fibonacci and how it looks with the listing when it is typed/pasted in, and then I test it interactively and compare results and timings with the pure Forth version "fibo". Then I have a listing produce by p2asm to show how it produces the same code.
Fast fibo in TIA:
code ffibo ( n -- f )
	x # 0 mov,
	y # 1 mov,
	a a FOR,
	  y x add,
	  z x mov,
	  x y mov,
	  y z mov,
	a NEXT,
_ret_ 	a x mov,
	end,
Pasting that in produces this output:
TAQOZ# code ffibo ( <condition> <dest> <#> <src> <effects>  instr, )                             ( n -- f )
062AC: F604_1600                 x # 0 mov,
062B0: F604_1801                 y # 1 mov,
                                 a a FOR,
062B4: F100_180B                   y x add,
062B8: F600_1A0B                   z x mov,
062BC: F600_160C                   x y mov,
062C0: F600_180D                   y z mov,
062C4: FB6C_45FB                 a NEXT,
062C8: 0600_440B            _ret_        a x mov,
                                 end, ok
Testing this in the terminal along with the standard fibo version:
TAQOZ# 46 ffibo . --- 1836311903  ok
TAQOZ# 46 fibo . --- 1836311903  ok
TAQOZ# 46 LAP ffibo LAP .LAP --- 1,184 cycles= 4,736ns @250MHz ok
TAQOZ# 46 LAP fibo LAP .LAP --- 3,296 cycles= 13,184ns @250MHz ok
and finally the listing that p2asm produces with the equivalent code:
01418              ffibo '( n -- f ) fast fibo - a = tos '
01418     f6041600 	mov	x,#0
0141c     f6041801 	mov	y,#1
01420     f100180b .l0	add	y,x
01424     f6001a0b 	mov	z,x
01428     f600160c 	mov	x,y
0142c     f600180d 	mov	y,z
01430     fb6c45fb 	djnz	a,#.l0
01434     0600440b _ret_	mov	a,x
P.S. Yes, I am getting P2D2 boards together and tested. This is my break away from it all.
«134
  • cgraceycgracey Posts: 14,297
    Nice, Peter!
  • ErNaErNa Posts: 1,851
    Peter, please give us a chance to follow you by bringing out the P2D2! I'll try my best to free you from production of additional hardware, if only we have your deep thought of how it has to be!
  • One of the advantages of this assembler is that it is inherently extensible and powerful macros can be created with a single line of Forth code. The FOR, NEXT, were very simple "macros" indeed.
    @ErNa - I agree that I'd rather not assemble these boards myself, but I lucked out with my friend who hasn't been available, but nonetheless I am close to finishing and testing the boards.
    It's just that I outsourced a project the P1 can't do, but P2 will and as long as I have no throw in hardware module I can not control the design process and the architecture, as the way is not so important but the outcome. But I would very much like to have the P2 do the job due to many facts, definitely I don't rely on C++ ;-)
    Like many others I like to program Forth in any language ;-)
  • I filled in practically all of the opcodes although there are a few I need to refine but I added in a simple front-end to process regular assembler syntax. I'm using predefined labels at present but I can easily convert symbols that start in column 1 as labels and use these. This is the ffibo from earlier on.
    TAQOZ# code ffibo
    06DB2: F604_1600                mov     x,#0
    06DB6: F604_1801                mov     y,#1
    06DBA: F100_180B        .l0     add     y,x
    06DBE: F600_1A0B                mov     z,x
    06DC2: F600_160C                mov     x,y
    06DC6: F600_180D                mov     y,z
    06DCA: FB6C_45FB                djnz    a,#l0
    06DCE: F600_440B         _ret_  mov     a,x
                                    end ---  ok
    Testing:
    edited 2020-02-28 07:55
    I was thinking about single pass forward references with conventional labels for interactive use and I came up with a simple scheme. When a label has not yet been defined it will simply save the current PC and use that for the instruction also. Once the label is defined, it resolves the reference depending upon the type. Of course in an interactive session in the listing it can't go back and relist the forward references but I might be able to add something to indicate that it has resolved these. Nonetheless it works well.
    Here is an even faster fibo that avoids the register swap each iteration and alternates between registers.
    TAQOZ# code ffibo2
    06DD0: F604_1600                mov     x,#0
    06DD4: F604_1801                mov     y,#1
    06DD8: F100_180B        .l0     add     y,x
    06DDC: FB6C_45FF                djnz    a,#l2
    06DE0: F600_440C         _ret_  mov     a,y
    06DE4: F100_160C        .l2     add     x,y
    06DE8: FB6C_45FB                djnz    a,#l0
    06DEC: F600_440B         _ret_  mov     a,x
                                    end ---  ok
    (EDIT: actually I just found a bug that crept in - with the previous post also - see if you can spot it)
    Checking that the forward reference was resolved:
    TAQOZ# $6DDC @ .l --- $FB6C_4401 ok
    and of course testing it:
    TAQOZ# 46 ffibo2 . --- 1836311903  ok
    TAQOZ# 46 LAP ffibo2 LAP .LAP --- 1,000 cycles= 4,000ns @250MHz ok
  • I was thinking about single pass forward references with conventional labels for interactive use and I came up with a simple scheme. When a label has not yet been defined it will simply save the current PC and use that for the instruction also. Once the label is defined, it resolves the reference depending upon the type. Of course in an interactive session in the listing it can't go back and relist the forward references but I might be able to add something to indicate that it has resolved these. Nonetheless it works well.
    TAQOZ# code ffibo2
                                    end ---  ok
    The dots are missing from the jump targets: #l0 instead of #.l0
  • @AJL - True, but not really a "bug", more of a temporary implementation and I will add some extras to handle labels smoothly.
    Hint: Check instruction encoding. If you are used to reading P2 machine code, then it should be glaringly obvious without having to know the exact code :)
  • _ret_ instructions should be 0xxx_xxxx.
    edited 2020-02-28 15:34
    TonyB_ wrote: »
    Correct! ( the first 4-bit filed is the conditional execution field and since "never" is a fairly useless condition, this was instead leveraged to specify a return after the current instruction. )
    The bug was due to new line evaluation routine that wasn't converting case, and in this "case" the _ret_ wasn't being found in the dictionary because it was a _RET_, and my current default during testing was to skip that evaluation failure. All that the new version really does is defer execution of the instructions until the end of the line, and also filter and substitute certain characters so that it can be evaluated as a standard Forth expression.
    This btw, is the correct output (I removed the need for the dot for local labels)
    TAQOZ# code ffibo2
    06E52: F604_1600                mov     x,#0
    06E56: F604_1801                mov     y,#1
    06E5A: F100_180B        l0      add     y,x
    06E5E: FB6C_45FF                djnz    a,#l2
    06E62: 0600_440C         _ret_  mov     a,y
    06E66: F100_160C        l2      add     x,y
    06E6A: FB6C_45FB                djnz    a,#l0
    06E6E: 0600_440B         _ret_  mov     a,x
                                    end ---  ok
    edited 2020-03-01 06:45
    Taking a break on a Sunday afternoon and while testing TIA I decided to create an automatic AUGS and/or AUGD instead of forcing it with the ##. If the source and/or destination is out of range it will augment it automatically. I think TIA would make a great tool for learning P2 assembly code since you can interact with it and debug it from the TAQOZ shell very easily, as seen in the previous examples.
    Do we really need to use a ## or is that some limitation of PNut?
    Here's a quick check:
    TAQOZ# code augment
    06EA2: F604_4400                mov     a,#0
    06EA6: F604_4464                mov     a,#100
    06EAA: F604_45FF                mov     a,#511
    06EAE: FF00_0001                mov     a,#512
    06EB2: F604_4400
    06EB6: FF1D_CD65                mov     a,#1_000_000_000
    06EBA: F604_4400
    06EBE: FF7F_FFFF                mov     a,#-1
    06EC2: F604_45FF
    06EC6: FCDC_0408                rep     #2,#8
    06ECA: 0000_0000                nop
    06ECE: 0000_0000                nop
    06ED2: FF1D_CD65                rep     #2,#1_000_000_000
    06ED6: FCDC_0400
    06EDA: 0000_0000                nop
    06EDE: 0000_0000                nop
    06EE2: FD64_002D                ret
                            end ---  ok
    TAQOZ# code wrhub
    06EE8: FF00_0001                mov     a,#1000
    06EEC: F604_45E8
    06EF0: FFFF_FFFF                wrlong  #-1,#$80
    06EF4: FC6F_FE80
    06EF8: FF00_0080                wrlong  #-1,#$1_0000
    06EFC: FFFF_FFFF
    06F00: FC6F_FE00
    06F04: FD64_002D                ret
                            end ---  ok
    BTW, this code here is not meant to be a working example, simply checking the assembler.
    edited 2020-03-01 07:13
    We don't need it in PNut, but I like to have it so I know for sure how long my code is and how long it takes to execute.
    edited 2020-03-01 09:08
    cgracey wrote: »
    I would think that once we have an immediate operand, then we already know what size it is, although I guess with symbols that might mean it doesn't need an augs and thus reduces the code size. But I think the fact that PNut does not produce a line by line listing is a far greater disadvantage than the forced ##. I agree that having it is good when you want to force it, but not having to use it is also good.
    My preference is to leave ## and report an error otherwise. It’s just like reporting a warning for the missing # in jump instructions.
    @ Peter: ... --- ... -.-. .... . -.-. -.- -.-- --- ..- .-. .--. --
  • My preference is to always have the option, this and that is always than this and not that.
    So I wrote a check routine for combined augs and augd in the one operation. It starts to look ugly when you want to write a 32-bit immediate value to a 20-bit hub address. Onlyt takes 16 bytes to do it! :)
    I know this is an extreme example, but actually it's good to know that you can do it.
    TAQOZ# code wrhub
    06EA2: FF00_0080                wrlong  #$12345678,#$1_0000
    06EA6: FF89_1A2B
    06EAA: FC6C_F000
    06EAE: FD64_002D                ret
                            end ---  ok
    TAQOZ# wrhub ---  ok
    TAQOZ# $10000 QD ---
    0001_0000: 78 56 34 12  00 00 00 00  00 00 00 00  00 00 00 00     'xV4.............'
    0001_0010: 00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00     '................' ok
  • ErNa wrote: »
    For others who don't read morse code:
    sos check your pm
    edited 2020-03-10 04:14
    While I wait to pickup assembled P2D2 modules tomorrow, I knew that the IJNZ instruction could be useful, but I have only just used it now in optimizing a routine that finds the length of an ASCII string that is terminated by a null or >$7F.
    So I punch in this piece of code into TIA
    code LEN ( string -- len )
    	rdfast  #0,a
            mov     a,#0
    .l0	rfbyte  x wcz			' read a byte
     {c|z}	ret				' terminate if zero or > $7F'
     	ijnz	a,#l0
    	end
    and get it to assemble correctly:
    TAQOZ# code LEN ( string -- len )
    07006 FC78_0022         rdfast  #0,a
    0700A F604_4400         mov     a,#0
    0700E FD78_1610 .l0     rfbyte  x wcz                   ' read a byte
    07012 ED64_002D  {c|z}  ret                             ' terminate if zero or > $7F'
    07016 FB8C_45FD         ijnz    a,#l0
                            end ---  ok
    So it saves an instruction and would never not branch in reality, plus the wcz in the rfbyte is handy for testing the msb as a terminator as well. I have the normal conditionals such as if_c_or_z but I also have shorter less verbose variants like {c|z}.
    But of course this won't work in hubexec mode since it uses rdfast, so I construct and assemble a loader that copies the code to a spare area in the TAQOZ kernel cog called COGMOD and run it. (Like the old RUNMOD in Tachyon).
    TAQOZ# AT COGMOD         := _COGMOD ---  ok
    TAQOZ#  ---  ok
     ---  ok-- Define a new routine that can load COGMOD memory from hub
    TAQOZ# code LOADMOD ( src len -- )
    07022 FD60_4428         setq    a
    07026 FB03_C223         rdlong  _COGMOD,b               'read longs into cog'
    0702A FD64_002D         ret
                            end ---  ok
    TAQOZ#  ---  ok
     ---  ok-- load code into free COGMOD memory
    TAQOZ# AT LEN 2+ 5 LOADMOD ---  ok
    Then test the LEN code that has been loaded into the COGMOD area:
    TAQOZ# " HELLO WORLD!" LAP COGMOD LAP . SPACE .LAP --- 12  129 cycles= 645ns @200MHz ok
    Then test the speed of LOADMOD itself:
    TAQOZ# AT LEN 2+ 5 LAP LOADMOD LAP .LAP --- 113 cycles= 565ns @200MHz ok
    So while I am getting these P2D2s out I am having fun with testing whatifs with assembly code. I even tested a fast SD virtual memory address translator that checks if the 4GB virtual address is buffered and returns with the hub address in less than 1us if it is, so that it can be read/written etc. Of course, if it is not buffered it needs to flush and read in the relevant sector, before returning with the address.
  • roglohrogloh Posts: 6,274
    edited 2020-03-10 04:23
    Interesting use of the fifo when checking the string length, it should be nice and fast. I wonder if you could make the ijnz use if_nz_and_nc to tighten your loop further, like this:
                      rdfast   #0, a
                      mov      a,#0
    loop              rfbyte   x wcz
       if_nz_and_nc   ijnz     a, #loop
                      ret
  • rogloh wrote: »
                      rdfast   #0, a
                      mov      a,#0
    loop              rfbyte   x wcz
                      ret
    Good idea, so I tried it:
    0703A FC78_0022         rdfast   #0, a
    0703E F604_4400         mov      a,#0
    07042 FD78_1610 .l0     rfbyte   x wcz
    07046 1B8C_45FE {nc&nz} ijnz     a, #l0
    0704A FD64_002D         ret
                            end ---  ok
    TAQOZ#  ---  ok
    TAQOZ#  ---  ok
    TAQOZ# " HELLO WORLD!" COGMOD . --- 12  ok
    TAQOZ# " HELLO WORLD!" LAP COGMOD LAP .LAP --- 105 cycles= 525ns @200MHz ok
    The optimized code that took 129 cycles before now takes 105!
  • Nice.
  • So I updated the kernel LEN$ word with this routine and tried it out by filling a buffer area:
    TAQOZ# BUFFERS $400 'A' FILL ---  ok
    TAQOZ# 0 BUFFERS $200 + C! ---  ok
    TAQOZ# BUFFERS LEN$ . --- 512  ok
    TAQOZ# BUFFERS LAP LEN$ LAP .LAP --- 3,105 cycles= 15,525ns @200MHz ok
    TAQOZ# 15525 512 / . --- 30  ok
    30ns or 6 clocks per character aint bad.
    edited 2020-03-10 06:37
    Another even faster way to speed it up to just 4 clocks per character scanned is if you use the execution timing to determine the string length with something like this perhaps, if I have the offsets & scaling correct:
                      rdfast   #0, a
                      getct    b
                      rep      #2, #0 ' loop 2 next instructions forever until we branch out
                      rfbyte   x wcz
       if_z_or_c      jmp      #exit  ' leave loop
    exit              getct    a
                      sub      a, b
                      sub      a, #10   ' also account for overhead clocks
                      shr      a, #2   ' a now contains the valid string length before char==0 or > 127
                      ret
    loop:
       check P2D2 available
       ijnz ease
       jmp loop
    ease:
    edited 2020-03-10 20:50
    rogloh wrote: »
                      rdfast   #0, a
                      getct    b
                      rfbyte   x wcz
    exit              getct    a
                      sub      a, b
                      ret
    I was trying yesterday to figure out how to make it go faster, and I got to thinking about REP and a conditional JMP out, but it never occurred to me to use the system counter. I couldn't do better than 6 clocks. Yours is a pretty surprising idea. You'd have to STALLI before and ALLOWI after if interrupts were occurring.
  • ElectrodudeElectrodude Posts: 1,686
    edited 2020-03-12 03:57
    Using GETPTR instead of GETCT should shave off two instructions, and it doesn't require STALLI and ALLOWI:
                      rdfast   #0, a
                      rfbyte   x wcz
    exit              getptr   b
                      sub      b, a
                      sub      b, #1 ' don't count trailing null byte
                      ret
  • Wow, I like that even more. I'd forgotten about being able to reading back the fifo position.
    rogloh wrote: »
    Yes, that's the best way, so far.
    edited 2020-03-12 05:32
    Maybe some unrolling could speed it up if you know you are mainly working with strings above a reasonable minimum size. This scans 4 bytes in 10 clocks, but also delays the output slightly for 3 of the 4 cases. Another way to think about it is that execution time is quantized to the next long boundary.
                      rdfast   #0, a
                      rep      #5, #0 ' loop 5 next instructions forever until we branch out
                      rfbyte   x wcz
       if_nc_and_nz   rfbyte   x wcz
    exit              getptr   b
                      sub      b, a
                      ret
    Update:
    Using 4 bytes per loop is faster or equivalent than without unrolling for all string lengths > 1 byte in size. Shortening to 3 bytes per loop is faster or equivalent for all string lengths that are not zero, and isn't too much of a performance hit (2.66 clocks per byte vs 2.5 clocks per byte on average). You could unroll further to approach the best 2 clocks per byte scanned, but it becomes diminishing returns and the short string performance gets punished more for each byte you add to the loop (plus it burns more COGRAM).
  • evanhevanh Posts: 17,129
    edited 2020-03-12 05:35
    Be aware that a relative branch as the last instruction of a REP block has an undocumented branch offset applied. In this case, because the destination is the following instruction, the offset will create one extra pass through the REP block.
    Therefore an extra RFBYTE has been executed and the GETPTR returns +1 more than it would otherwise. ie: Using a JMP #\exit will be a different outcome for GETPTR.
    PS: And the CZ flags, as well as "x", will reflect the subsequent FIFO byte read too.
