Code for multiple COGs in a single .spin file ?
in Propeller 1
I can write multiple pasm section and launch them into several cogs like this and it compiles, don't know if it runs yet:
Will this work?
How does the cognew() know how much code to load to the cogs?
Or does this result in each cog having all the code?
PUB Main cognew(@CODE1, 0) cognew(@CODE2, 1) ' 1st COG code DAT org 0 CODE1 ' code here var1 long 0 ' 2nd COG code org 0 CODE2 ' code here var2 long 0
Will this work?
COGNEW always loads 496 longs of code. If your code is shorter, it'll just load whatever comes after into the remaining registers.
