"GDB" style source level debugging for P2 C - a work in progress.
in Propeller 2
Demo of techniques for setting traps/breakpoints in C programs compiled under Flex GUI. Preliminary. Try it!!!
"Application" is a number base conversion program that can handle ridiculous input like 5661654161651461616541611 and convert to/from "any" base, such as base 2, base 16, decimal time, base 137 or whatever. See what happens when you enter 3.14159 when it asks for INTEGER input.
Now about those pesky primes or those billion digits of pi???? Hmmmmm.
dgately
Essentially adding something like this to your code will enable the creation of the needed trap variables and breakpoints.
_TRACE_DEBUG_(TRAP,0xdeadbeef)
_BREAK_DEBUG_("chartobase36(char c)",__LINE__,&TRAP);
( Entering terminal mode. Press Ctrl-] to exit. ) Type in a long integer: >111111111111111111111111111111111 33 bins filled: Enter base to convert from: >2 1 bins filled: Converting string with size 1 ... Iteration 1: bin value is 2, summation is 2. Enter base to convert to: >10 2 bins filled: Converting string with size 2 ... Iteration 1: bin value is 1, summation is 1. Iteration 2: bin value is 0, summation is 10. Converting from base 2 to base 10 ... Compressing to base 16: Converting from base 16 to base 100 ... Squaring the binfactor array: {(2),(56)} (base one-hundred) Squaring the binfactor array: {(6),(55),(36)} (base one-hundred) Squaring the binfactor array: {(42),(94),(96),(72),(96)} (base one-hundred) Expanding from base 100 to base 10: 8589934591 Type in a long integer: >86400 5 bins filled: Enter base to convert from: >10 2 bins filled: Converting string with size 2 ... Iteration 1: bin value is 1, summation is 1. Iteration 2: bin value is 0, summation is 10. Enter base to convert to: >60 2 bins filled: Converting string with size 2 ... Iteration 1: bin value is 6, summation is 6. Iteration 2: bin value is 0, summation is 60. Converting from base 10 to base 60 ... Compressing to base 100: Converting from base 100 to base 121 ... Squaring the binfactor array: {(82),(78)} (base one-hundred and twenty-one) Expanding from base 121 to base 11: Converting from base 11 to base 60 ... Squaring the binfactor array: {(2),(1)} (base sixty) Squaring the binfactor array: {(4),(4),(1)} (base sixty) 24:00:00 Type in a long integer: >3.14159 ***DEBUG BREAKPOINT REACHED*** Context = chartobase36(char c), Line number = 591 Address: 0000c158: Value: 2048 | 0x00000800 | ASCII ( Address: 0000c15c: Value: 1 | 0x00000001 | ASCII ! Address: 0000c160: Value: 0 | 0x00000000 | ASCII Address: 0000c164: Value: 3 | 0x00000003 | ASCII # Address: 0000c168: Value: 1 | 0x00000001 | ASCII ! Address: 0000c16c: Value: 7 | 0x00000007 | ASCII ' Address: 0000c170: Value: 49198 | 0x0000c02e | ASCII .@ Address: 0000c174: Value: -2147481888 | 0x800006e0 | ASCII `& Address: 0000c178: Value: -2147476664 | 0x80001b48 | ASCII H; Address: 0000c17c: Value: 0 | 0x00000000 | ASCII Address: 0000c180: Value: 49480 | 0x0000c148 | ASCII HA Address: 0000c184: Value: -2147478032 | 0x800015f0 | ASCII p5 Address: 0000c188: Value: 44799 | 0x0000aeff | ASCII . Address: 0000c18c: Value: 3 | 0x00000003 | ASCII # Address: 0000c190: Value: -559038737 | 0xdeadbeef | ASCII o>-^ Address: 0000c194: Value: -2147478052 | 0x800015dc | ASCII \5 Press ANY key to continue or ESC to DEBUG : :? 'a'=ASSEMBLE, 'b'=BREAKPOINTS(CLEAR/DISABLE/ENABLE/SET) 'c'=CPU (Info, Status, Change CPU Type), 'd'=DOWN 'e'=EVAL(expression), 'l'=LIST(disassembly), 'm'=MONITOR 'p'=PROCESS, 'r'=RUN/RESUME,'s'=STACK TRACE, 'u'=UP 'w'=WATCH VARIABLE, 'x'=EXAMINE, 'z'=ZAP, '?'=THIS MENU :l Dissassmeble (LIST) at? default = (*0000c194) = 800015dc: 800015dc: (f1049408) FLAGS=f CODE= 8 _add_ __I DEST=004a, SOURCE=0008 800015e0: (fb00a64a) FLAGS=f CODE= 88 _rdlong_ ___ DEST=0053, SOURCE=004a 800015e4: (f1849408) FLAGS=f CODE= 12 addsx __I DEST=004a, SOURCE=0008 800015e8: (f603f04a) FLAGS=f CODE= 48 _mov_ ___ DEST=01f8, SOURCE=004a 800015ec: (fdc00023) FLAGS=f CODE= 110 _calla_ ___ DEST=0000, SOURCE=0023 800015f0: (fd64002e) FLAGS=f CODE= 107 cogid/exit __I DEST=0000, SOURCE=002e 800015f4: (f604280d) FLAGS=f CODE= 48 _mov_ __I DEST=0014, SOURCE=000d 800015f8: (fdc00016) FLAGS=f CODE= 110 _calla_ ___ DEST=0000, SOURCE=0016 800015fc: (f6013e7f) FLAGS=f CODE= 48 _mov_ ___ DEST=009f, SOURCE=007f 80001600: (fb01409f) FLAGS=f CODE= 88 _rdlong_ ___ DEST=00a0, SOURCE=009f 80001604: (f1053e10) FLAGS=f CODE= 8 _add_ __I DEST=009f, SOURCE=0010 80001608: (fb01429f) FLAGS=f CODE= 88 _rdlong_ ___ DEST=00a1, SOURCE=009f 8000160c: (f1853e10) FLAGS=f CODE= 12 addsx __I DEST=009f, SOURCE=0010 80001610: (ff000003) FLAGS=f CODE= 120 GNU ___ DEST=0000, SOURCE=0003 80001614: (f60545ff) FLAGS=f CODE= 48 _mov_ __I DEST=00a2, SOURCE=01ff 80001618: (f60146a2) FLAGS=f CODE= 48 _mov_ ___ DEST=00a3, SOURCE=00a2 8000161c: (f0654602) FLAGS=f CODE= 3 sbr __I DEST=00a3, SOURCE=0002 80001620: (f10146a0) FLAGS=f CODE= 8 _add_ ___ DEST=00a3, SOURCE=00a0 80001624: (fb0948a3) FLAGS=f CODE= 88 _rdlong_ _Z_ DEST=00a4, SOURCE=00a3 80001628: (a1854401) FLAGS=a CODE= 12 addsx __I DEST=00a2, SOURCE=0001 8000162c: (ad9fffe8) FLAGS=a CODE= 108 _jmp_ CZI DEST=01ff, SOURCE=01e8 80001630: (f604fe00) FLAGS=f CODE= 48 _mov_ __I DEST=007f, SOURCE=0000 80001634: (fdd0298c) FLAGS=f CODE= 110 _calla_ C__ DEST=0014, SOURCE=018c 80001638: (f25d4432) FLAGS=f CODE= 18 cmps CZI DEST=00a2, SOURCE=0032 8000163c: (ed900054) FLAGS=e CODE= 108 _jmp_ C__ DEST=0000, SOURCE=0054 80001640: (f6018ca2) FLAGS=f CODE= 48 _mov_ ___ DEST=00c6, SOURCE=00a2 80001644: (f1058c32) FLAGS=f CODE= 8 _add_ __I DEST=00c6, SOURCE=0032 80001648: (f6058e32) FLAGS=f CODE= 48 _mov_ __I DEST=00c7, SOURCE=0032 8000164c: (fdc0003f) FLAGS=f CODE= 110 _calla_ ___ DEST=0000, SOURCE=003f 80001650: (f60148c6) FLAGS=f CODE= 48 _mov_ ___ DEST=00a4, SOURCE=00c6 80001654: (f6054a32) FLAGS=f CODE= 48 _mov_ __I DEST=00a5, SOURCE=0032 80001658: (f1814aa4) FLAGS=f CODE= 12 addsx ___ DEST=00a5, SOURCE=00a4 8000165c: (f25d4a01) FLAGS=f CODE= 18 cmps CZI DEST=00a5, SOURCE=0001 :r ***DEBUG BREAKPOINT REACHED*** Context = chartobase36(char c), Line number = 591 Address: 0000c158: Value: 2048 | 0x00000800 | ASCII ( Address: 0000c15c: Value: 1 | 0x00000001 | ASCII ! Address: 0000c160: Value: 0 | 0x00000000 | ASCII Address: 0000c164: Value: 3 | 0x00000003 | ASCII # Address: 0000c168: Value: 1 | 0x00000001 | ASCII ! Address: 0000c16c: Value: 7 | 0x00000007 | ASCII ' Address: 0000c170: Value: 49198 | 0x0000c02e | ASCII .@ Address: 0000c174: Value: -2147481888 | 0x800006e0 | ASCII `& Address: 0000c178: Value: -2147476624 | 0x80001b70 | ASCII p; Address: 0000c17c: Value: 0 | 0x00000000 | ASCII Address: 0000c180: Value: 49480 | 0x0000c148 | ASCII HA Address: 0000c184: Value: -1073736208 | 0xc00015f0 | ASCII p5 @ Address: 0000c188: Value: 44799 | 0x0000aeff | ASCII . Address: 0000c18c: Value: 3 | 0x00000003 | ASCII # Address: 0000c190: Value: -559038737 | 0xdeadbeef | ASCII o>-^ Address: 0000c194: Value: -2147478052 | 0x800015dc | ASCII \5 Press ANY key to continue or ESC to DEBUG :r :r 7 bins filled: Enter base to convert from: >10 2 bins filled: Converting string with size 2 ... Iteration 1: bin value is 1, summation is 1. Iteration 2: bin value is 0, summation is 10. Enter base to convert to: >16 2 bins filled: Converting string with size 2 ... Iteration 1: bin value is 1, summation is 1. Iteration 2: bin value is 6, summation is 16. Converting from base 10 to base 16 ... Compressing to base 100: Converting from base 100 to base 121 ... Squaring the binfactor array: {(82),(78)} (base one-hundred and twenty-one) Squaring the binfactor array: {(56),(54),(16),(34)} (base one-hundred and twenty-one) Expanding from base 121 to base 11: Converting from base 11 to base 16 ... Squaring the binfactor array: {(7),(9)} (base sixteen) Squaring the binfactor array: {(3),(9),(3),(1)} (base sixteen) 3291EF Type in a long integer: >
