Basic Stamp Microprocessor programming help!!
I am working on a project with the circuit of a parallax boebot, I am trying to figure out how to program the microprocessor to turn on when it gets turned on from a 555 timer and turn off when it's not getting a signal. Im not sure of where to start with the program
  • By turn on and turn off do you mean to actually turn on/off the power to the to the microcontroller, or do you mean to have it stop running the program when it is not getting the signal?
    In science there is no authority. There is only experiment.
    Life is unpredictable. Eat dessert first.
  • blackout123,
    Rarely are microcontrollers turned on and off, and using a signal to control a microcontroller is very common.
    What are your signal rates and what do you need done during that time?
    Also are you using a BS2 or another microcontroller?
