eMMC vs HyperFlash
Rayman
Must have been hiding under a rock, but just discovered this eMMC stuff.
If I have it right, it's similar to SPI mode uSD, but with 8-bit bus and high speed.
Maybe I ignored it before due to BGA and lots of balls.
But, when I see it now, only a few of the balls are actually used.
All in all, not much different from HyperFlash.
But, memory size is much bigger with eMMC.
So, why use HyperFlash?
Maybe writing is faster? Just lower cost and size?
https://www.globenewswire.com/news-release/2019/03/19/1757410/0/en/ISSI-HyperFlash-memory-has-successfully-been-designed-into-the-NXP-i-MX-RT106A-MCU-based-solution-for-AVS-Alexa-Voice-Service.html
They mention putting HyperRam on the same bus as HyperFlash…
Guess HyperBus can be faster than eMMC and physical size is smaller.
Think I'm supposed to buy the JEDEC standard for $327: https://www.jedec.org/standards-documents/docs/jesd84-b51
Let's say I do that... Can I post code based on that standard? I thought this was open...
Ok, think I found Linux code for eMMC:
https://github.com/torvalds/linux/tree/master/drivers/mmc/core
Found some better looking code (and MIT license) here:
https://github.com/starlino/sdEmmc/blob/master/sdEmmc_cmd.c
Usage looks almost exactly like uSD, except can set 8-bit bus width...
eMMC drivers exist for linux, its used in the beaglebone for instance. Its basically an MMC card
in BGA package AFAICT.
http://www.jeju-semi.com/Products/OctaRAM
https://www.autonomousvehicletech.com/articles/204-jscs-octaram-and-mxics-octaflash-combined
http://www.macronix.com/en-us/products/NOR-Flash/Pages/OctaFlash.aspx#3V
Digikey lists Octaflash
MX25LM51245G $7.32/1k for 512Mb
MX66LM1G45GXDI00 $14.69 for 1Gb
In DTR mode, the Octa- DQS signal, looks the same as the HyperRAM RWDS signal ?
P/N: SDINBDG4-8G
Also, there is an adapter allowing to plug the module into a micro SD card slot (I guess not in 8bit mode though).
Might be useful at least for the first tests, hope it helps.
Most of the datasheets don't have it.
This one did though.
Looks really easy to route as most balls are not internally connected.
https://www.linkedin.com/pulse/emmc-implementation-ignacio-diz-castro
I was wondering about that strange "DS" pin in the pinout image Rayman posted and it thankfully seems it can be ignored unless you want to operate in the new high speed HS400 mode according to him. If the protocol is simply MMC which is reasonably well documented online, it might be possible to just experiment with one without buying the official specs and see how it behaves, assuming you build a board (or get some other pre-loaded version on some other PCB board). I know some Raspi clones like Rock Pi, Rock 64 etc use/provide cheap breakouts for eMMC using a simpler connector so it might be good to start with that.
Just saw that this is the memory chips inside iPhones...
https://www.cypress.com/news/cypress-hyperbus-memory-interface-instant-applications-incorporated-jedec-xspi-electrical
cross point memory had an X, let's confuddle the suits and investors, and put an 'x' in our new name as well.
But, searching for xSPI is not easy, hard to find what kind of xSPI devices might exist...
Good if you're trying to execute from memory...
They must be stacking inside...
But then, it occurred to me that I should take another look at what I can just buy...
Found some nice ones here: https://ameridroid.com/products/emmc-5-1-module-blank
But, they have a connector that is hard to come by...
Then, found this one (see attached). Much easier connector. And, it's on Amazon...
Ordered today... Should get one Saturday!
https://www.amazon.com/eMMC-Module-8GB-NanoPi-M4/dp/B07JVMSHBX/ref=mp_s_a_1_1?dchild=1&keywords=B07JVMSHBX&qid=1589501589&sr=8-1
youyeetoo eMMC Module - 16GB
I couldn’t find a 8 gb one when I looked...
Just wished they’d picked an easier to find connector...
You can get the .4 mm pitch connectors on eBay from overseas but who knows when they’d get here...
The .1 inch 1.27 mm pitch connector version is much nicer although I do wish for a usb3 adapter for that one.
Sure, not as fresh as a brand new unit, after pulling, but in the US, at least...
The price tag seems right, at least to me, for a unit you can put your hands on, without having to be affraid, waiting for an unknown arrival date.
https://ameridroid.com/products/emmc-adapter
Dana Microsystems, Inc. - Sales
Av. Lazaro Cardenas #3454
Col. Jardines Chapalita
Guadalajara, Jal., C.P. 44520, Mexico
sales@danamicro.com
https://danamicro.com/
I didn't contacted them, thus I'm unsure for any minimum quantities/order totals that could apply, but they are closer than any other China parts provider.
I'm also unsure of brand, perhaps LS Electronic Components (separated from LG in 2005) or any other suitable alternative.
Hope it helps.
