VGA from P2 silicon
I just found an older VGA routine that was done for FPGA and made a couple of changes to get it running on silicon. Next thing I want to do is duplicate all this from TAQOZ.
'*  VGA 640 x 480 x 8bpp-lut  *
CON
  intensity	= 120	'0..128
  fclk		= 200_000_000.0
  fpix		= 25_000_000.0
  fset		= (fpix / fclk * 2.0) * float($4000_0000)
  vsync		=	4	'vsync pin (all FPGA boards now)
DAT		org
' Setup
	hubset	##%1_001011_0011000111_1111_11_00
	waitx	##20_000_000/100			'wait ~10ms for crystal+PLL to stabilize
	hubset	##%1_001011_0011000111_1111_11_11 	'now switch to PLL running at 200MHz
		rdfast	#0,##$1000-$400		'load .bmp palette into lut
		rep	@.end,#$100
		rflong	y
		shl	y,#8
		wrlut	y,x
		add	x,#1
.end
		rdfast	##640*480/64,##$1000	'set rdfast to wrap on bitmap
		setxfrq ##round(fset)		'set transfer frequency to 25MHz
		'the next 4 lines may be commented out to bypass level scaling
		setcy	##intensity << 24	'r	set colorspace for rgb
		setci	##intensity << 16	'g
		setcq	##intensity << 08	'b
		setcmod	#%01_0_000_0		'enable colorspace conversion
		wrpin	dacmode,#0		'enable dac modes in pins 0..3
		wrpin	dacmode,#1
		wrpin	dacmode,#2
		wrpin	dacmode,#3
		drvh	#0
		drvh	#1
		drvh	#2
		drvh	#3
' Field loop
field		mov	x,#33			'top blanks
		call	#blank
		mov     x,#480			'set visible lines
line		call	#hsync			'do horizontal sync
		xcont	m_rf,#0			'visible line
		djnz    x,#line           	'another line?
		mov	x,#10			'bottom blanks
		call	#blank
		drvnot	#vsync			'sync on
		mov	x,#2			'sync blanks
		call	#blank
		drvnot	#vsync			'sync off
                jmp     #field                  'loop
' Subroutines
blank		call	#hsync			'blank lines
		xcont	m_vi,#0
	_ret_	djnz	x,#blank
hsync		xcont	m_bs,#0			'horizontal sync
		xcont	m_sn,#1
	_ret_	xcont	m_bv,#0
' Initialized data
'			%AAAA_BBBB_FFF_DACxxDDDDDDDD_TT_MMMMM_0
dacmode		long	%0000_0000_000_1010000000000_01_00000_0
m_bs		long	$CF000000+16		'before sync
m_sn		long	$CF000000+96		'sync
m_bv		long	$CF000000+48		'before visible
m_vi		long	$CF000000+640		'visible
m_rf		long	$7F000000+640		'visible rlong 8bpp lut
x		res	1
y		res	1
' Bitmap
		orgh	$1000 - $436	'justify pixels at $1000, pallete at $1000-$400
		file	"bitmap2.bmp"	'640 x 480, 8pbb-lut
3579 x 2176 - 1M
2176 x 3442 - 1M
«134
  • jmgjmg Posts: 14,480
    Impressive.
    Does that need 200MHz SysCLK to work ?
    What SysCLK can that drop down to, and still work ok ? 25MHz ?
  • I’m not sure the feet are supposed to be blue
  • Yep
    All my P2 VGA stuff shows incorrect colors too on the real P2,
    Modulator bug related I assume?
  • ozpropdevozpropdev Posts: 2,708
    edited 2018-10-19 - 10:39:41
    @Peter
    Does your "adaptor" have the RGB grounds connected as well ?
  • Birds true colors
    353 x 525 - 60K
  • TonyB_TonyB_ Posts: 1,521
    edited 2018-10-19 - 11:11:17
    Is video streaming possible in the background, allowing you to run other instructions at the same time in the same cog?
  • Video can be interrupt driven.
  • cgraceycgracey Posts: 13,053
    edited 2018-10-19 - 13:12:13
    You've got your R/G/B wires mixed up. Try swapping them around.
    Pin %xxxx11 = Red
    Pin %xxxx10 = Green
    Pin %xxxx01 = Blue
  • Peter JakackiPeter Jakacki Posts: 9,628
    edited 2018-10-19 - 13:33:48
    cgracey wrote: »
    Pin %xxxx11 = Red
    Pin %xxxx10 = Green
    Pin %xxxx01 = Blue
    Oh yeah, that's better. To tell the truth I didn't even look at the colors at all, I was just happy to see it running :)
    btw - I can run the P2 at 25MHz and it still works
    CPUHZ		= 25_000_001
    CLKDIV		= 12
    CLKMUL		= CPUHZ/1000000
    CLKCFG		= 1<<24+(CLKDIV-1)<<18+(CLKMUL-1)<<8+%1111_11_00
    3349 x 2168 - 1M
  • VGA takes 5 pins: R, G, B, H, V.
    HDTV takes 3 pins: Y, Pb, Pr.
    Composite takes 1 pin: YIQ.
    I love that we have 2ns 75-ohm DACs on every pin.
    I'm thinking about how the Goertzel can be used to resolve time-of-flight for signals. Goertzel, fast low-Z DACs, oversampling, and CORDIC, all together, should make really interesting measurements possible. It may be possible to achieve micrometer-scale resolution for light and electrical phenomena.
  • I was just going to ask how fast the DACs can update. Sounds like can go at clock freq...
    250 MHz opens up a lot of resolutions: http://tinyvga.com/vga-timing
  • Only need 150 MHz for 1080p at 60 Hz...
  • Rayman wrote: »
    Yes, 148.5MHz, to be exact.
    With a 20MHz crystal, use the PLL to divide it by 40 to get 0.5MHz, then set the VCO multiplier to 297 and select undivided VCO output and you've got 148.5MHz.
  • RaymanRayman Posts: 11,283
    edited 2018-10-19 - 14:19:48
    I don't think it has to be exact...
    I was signaling 1080p with 80 MHz clock on P2V:
    https://forums.parallax.com/discussion/163719/how-to-do-1080p/p2
    TVs didn't care, but some monitors didn't like it...
  • It's amazing how good even 8-bit VGA graphics can look. I've got a tiger in my room!
    2872 x 2176 - 1M
  • That looks superb, Peter!
  • Yes, that looks great. Is that 640x480?
    CPUHZ		= 25_000_001
    CLKDIV		= 12
    Thanks - great ! With P2's power aspects, lowest possible functional MHz will be important. Lucky it has that wide-range PLL ;)
    cgracey wrote: »
    Certainly an interesting area. I revisited some time-of-flight work Bean did on P1 following a question in another thread.
    There, Bean changes the Counter-PLL faster than it can lock, in order to modulate the timing samples across a linear range.
    Multiple samples and some means to shift edges in a sub-ns manner looks to be useful for time-of-flight.
    P1 has multiple PLLs and async pins, not sure how to emulate those in P2 ? - possibly a DAC and LPF+external comparator (logic 1G14 schmitt should do) ?
    Or, a DAC could modulate the supply rail of a AHC14, or maybe a dual-supply translator like 74AVC1T45 ?
    edited 2018-10-19 - 20:06:33
    jmg wrote: »
    cgracey wrote: »
    It can be more subtle than that. The Goertzel accumulates SIN and COS sums, based on the ADC readings (+/-1) on every clock, which can be converted to polar coordinates. The super resolution comes from the angle reading. Imagine you are outputting a 20MHz reference sine wave and inputting the same on another pin's ADC, after the signal has traveled a bit. The longer you measure the input, the bigger the accumulations get, and the more precise the final angle reading becomes. The phase resolution can be in the millionths of a revolution, down into the femtoseconds. This will take some experimentation to develop, but we have all the needed parts in the chip.
    cgracey wrote: »
    Perhaps, tho I really doubt the ADC numbers we are seeing, are going to allow phase-extract at 20MHz.
    Be interesting to see what can be achieved with P2 silicon.
    cgracey wrote: »
    What is the step size error on the DACs ?
    Seems with a modest DAC generated slew, 5ns SysCLKs can give maybe 390ps~100ps region time resolve, using external buffer threshold.
    MOSFET drivers usually have schmitt buffers, so some sub-ns PWM could be possible in P2 ? (allows you to compete with the better TI/Microchip parts)
  • Why could we not extract phase at 20MHz? I haven't tried it, yet, but I don't see why we couldn't get near-32-bit phase resolution if we stared long enough.
    The DAC step size is 3.3V/256 = 12.9mV. Smart pin modes can toggle between two adjacent steps to push 16-bit resolution.
  • roglohrogloh Posts: 2,689
    edited 2018-10-19 - 22:52:53
    cgracey wrote: »
    For fewer than 5 pins and assuming your VGA monitor supports it I take it that P2 internal HW has nothing stopping it being implemented using SyncOnGreen (3 pins) or RGBS (4 pins) as well? The S signal being some form of composite sync, potentially also DAC driven at 0.7V pp like RGB, or a raw TTL level form.
    From when I looked at the P2 docs it seems like that should be perfectly doable but I'm currently laying out a board and only really want to wire 4 pins into VGA from the P2 if possible. I guess I should try to run a separate signal for the extra Vsync pin with a non-populated resistor just in case...
    rogloh wrote: »
    I think I read somewhere that most monitors accept composite sync fine, behaving like they internally XOR'd V,H lines before processing anyway.
  • Yeah I'm confident I have monitors that support a combined sync form (XOR), and also a composite sync signal at video levels. Just checking that P2 video generating HW etc would be able to do this too, ideally just from the DACs using 4 wire RGBS. I could always toggle the HSync pin independently at 3.3V I guess but it might be nice to have the 4th DAC channel do it already synchronously with the colour channels perhaps. Trying to avoid the 5th pin.
  • rogloh wrote: »
    This may really be more of a driver question rather than P2 HW. I guess I'm not familiar enough with any existing video drivers on P2 yet to have full confidence in what is possible there. May have to try to write one when I get a chip to play with.
    edited 2018-10-19 - 23:37:56
    SETCMOD D/# - is used to set up the video outputs.
    Bit 0 of D/# inverts the HSYNC signal. So, you would flip that bit at the beginning and end of your VSYNC period, HSYNC would be inverted for that duration. I didn't know that VGA monitors let you get away with that. That's great!!!
  • rogloh wrote: »
    rogloh wrote: »
    That could be arranged. I need to travel to at least Syd and Adl this coming week.
  • cgracey wrote: »
    Yeah this can be very handy to save 1 pin (or even 2 with RGB SyncOnGreen). I know my older Sony CRT monitors support sync like this, should really try the range of Dell/Samsung LCDs I have as well. I think they also are meant to work but best to try to be sure.
    https://en.wikipedia.org/wiki/Component_video_sync
  • Tubular wrote: »
    Thx, will let you know if I've got any time for one - still busy on this PCB design and component selection etc so a P2D2 right now might actually be a distraction and yet another context switch.
