LVDS signalling
cgracey
in Propeller 2
I am going to run some simulations tonight and try to get a rough handle on LVDS, just out of curiosity. That 5Gb/s could be achieved in 180nm is compelling.
I wonder if, perhaps, in the interior, things are maintained as single-ended signals, but then become differential signals for I/O.
Does anyone know if a strict baud rate is typical in LVDS signaling?
As usual, there is also another interesting publication from TI...
LVDS Owner’s Manual
ti.com/lit/ug/snla187/snla187.pdf
Simply a lot of everything about it...
Have you ever heard about it?
I think I understand what you are saying, but implementations are even simpler, with the parallel register snatching data right off the delay line taps. This means just a word clock. No time for bit clocks.
That's a great document. To run at these crazy speeds, the circuit topology must be very, very simple.
Look at page 15.... Answers are there
That comes down to special analog support, where instead of a VCO, the PLL analog signal varies the local supply voltage, to vary the delays.
Could be an Up/Down DAC ?
Yes, but using the gate propagation delay of the line taps can limit your speed in the end.
Here is a Chip I put together for National Semiconductor for Gig Ethernet .... It required a 25MHz crystal that was wound up internally by a factor of 10 to 250MHz .... Using the 4 twisted pairs (LVDS) on the Ethernet cable, the 250MHz achieved 1Gig speeds with a 4-stage ring oscillator as I described above. The process itself would only allow for 350MHz, so with 250MHz there was a good margin of overhead. In this case propagation delay of line taps would have been too slow.
https://www.artisantg.com/TestMeasurement/90233-1/National_Semiconductor_DP83865DVH_Gig_PHYTER_V_10_100_1000_Ethernet_Physical_Layer
Something interesting about that article you posted from TI ....
Page 7 Introduction:
"National Semiconductor’s LVDS Owner’s Manual, first published in spring 1997, has been the industry’s “go-to
design guide” over the last decade. The owner’s manual helped LVDS grow from the original IEEE 1596.3-1996
Standard for Low-Voltage Differential Signaling (LVDS) for Scalable Coherent Interface (SCI) into the workhorse
technology it is today."
... I was part of the high speed communications division at National Semiconductor before I started work at Parallax.
One of my mentor's wrote much of the content in that LVDS Owner’s Manual.
I don't understand any of this. I understand the concept of ordered differentials... but what is being transmitted? the differential from the last data?
The data is transmitted serially as a +/- signal pair. A differential detector (which is higher-voltage?) determines 0 or 1. The data move very fast.
To make this delay line tunable, you could current-starve those inverters and MAYBE get by using three inverters per bit period, pushing the phase-shift to 120 degrees, each. Then, you could tap off every third inverter to capture the data, inverting every other flop output to compensate for the 3/odd stages per bit.
There's still the matter of propelling this signal OUT of a pin pair. The CERN 5Gb/s circuit claims to use capacitively-coupled pre-emphasis on its output. Then, you must be able to make the differential input into an internal single-ended signal. I tried using the differential inverter topology from our VCO to make a data delay line, but even hotted up, the signal peters out within the delay line. The data delay line needs about the simplest topology possible, and that probably dictates single-ended inverters - that is, if it's going to handle 5Gb/s.
Hi Beau Schwabe
In fact, I was sure you would recognize it as an old friend of yours (the article).
Due to the way I've done my initial queries, the second edition was the first I'd found; the stylish "N", that unforgetable National Semiconductor logo, soon made me remember that, many times, you'd mentioned as having worked there.
Good to know that one of your mentors did such a great job. Certainly you had many good learning sessions with him.
Henrique
