Prop Dip 40 Main board — Parallax Forums
This one of my prop boards with prop plug and ribbon connectors for daughter boards
1024 x 768 - 210K
    Sweet. Has a good old school feel about it.
    I don't see any decoupling capacitors on there.
  • Cool.
    Do you have bypass caps for the Propeller power supply pins under the chip? You really want them, 0.1uF as close to the pins as you can.
  • Thanks for the comments guys. This is a board I use for prototyping I did forget the power pin caps. had to solder underneath JM . I call it sky wiring that trace forget while doing the artwork and then you have to solder that patch wire after the fact.
