Create ZigBee network using Arduino, Arduino Xbee Shield and Xbee
Hi all, i am beginner with this protocol and i try to learn it.
My ideas is to create a Mesh netowork using ZigBee protocol, where my end device detect temperature , send this to router and their send the data to my Coordinator.
My setting is this:
3 End-Device: Arduino UNO + Xbee Serie 2 + Arduino Xbee Shield
2 Router: Arduino UNO + Xbee Serie 2 + Arduino Xbee Shield
1 Coordinator: Arduino UNO + Xbee Serie 2 + Arduino Xbee Shield
Xbee Shield : Xbee Shield uk.rs-online.com/web/p/radio-frequency-development-kits/6961670/
Xbee USB board: USB it.rs-online.com/web/p/kit-di-sviluppo-per-radiofrequenza/7813099/
Xbee xb24-z7: Serie2 robot-italy.com/it/xbee-pro-serie-2-wire-antenna.html
So first step I try to create my coordinator, i put my XbeeShield on the Arduino and put Xbee in the XbeeShield.
I open XCTU program, but it dont recognize my Xbee, It see the Arduino in COM port, but it dont connect with Xbee.
So I try to flash Coordinator firmware using USB board and i perform this,so i change my Xbee but if i try to create an Router, when XCTU find the COM port, it delete the previous device because there are in the same COM port.
My question are 3:
1- There is a way to flash Xbee firmware with XCTU using Arduino+XbeeShield+Xbee ? maybe usign some sketch?
2- when I flash Coordinator firmware, my Zigbee network is created?
3- How can i set the value in XCTU software?
Thanks all for support
