Neat Little Dual Motor Controller — Parallax Forums
ercoerco Posts: 20,263
This thing wasn't easy to get, but it fills a real need IMO. Drives 2 small DC motors (1.3A max/channel) using servo type pulses. Effectively makes continuous rotation servos out of plain old DC motors.
  • I'll have to repost this one:
    Yup, a neat new toy and a solution in search of the right problem. Almost like a pair of micro HB-25s. Not too shabby for $1.71, huh?
  • Thanks Erco,
    I was experimenting with a STEM demonstration 3axis gimbal controller using continuous servos, but I found all the servo gearing made the them "sticky" and very tricky to control accurately.
    DC motors will obviously be much more responsive, and I should be able to get much more accurate control.
    Really? Which servos? The CR servos I have been using have all worked quite well, except the FS90R, ironically by the same company which makes this controller board.
    FYI PDF attached AOK
  • erco wrote: »
    I love the descriptions on Alibaba/Aliexpress:
    Material: Wood
    Function: Light & Sound
    For: children,kids
    That is a seriously cool find, though. Curiosity got the best of me and I was able to find a chassis kit on Amazon that claims to use this device (although it is not clearly shown in the pictures.
    edited 2016-09-03 15:41
    Yes that's their mc-002 kit shown briefly at
    I think these are neat, I may buy a small quota after some more testing, if anyone is interested. The mfr only ships via DHL so it's a minimum $10 shipping charge.
    I ordered ten more, so I'll soon have ~5 for sale if anyone wants one to play with. ~$4 shipped. PM me.
    Finally had a minute to build this motor driver into a self-contained module. Battery box+PIC controller+motor driver combo slaps on the top of any small differential steered chassis (two gearmotors). Made quick work of a figure 8 on this cute little round chassis, also from Feetech. I think this module will come in handy for future bot development.
    1763 x 1403 - 401K
    Another Feetech chassis with this controller slapped on.
  • Erco
    Was C1 attached to the controller when it left Ca or did USPS detach it?
    Jim
  • Does your hat trick count since it was not based on a Parallax controller?
    Jim
    RS_Jim wrote: »
    Erco
    Jim
    Oh no! Did they machine sort it? Sorry to hear that. Do you need a polarity check to solder a new one on?
  • It broke the solder joint at the board. The pins are bent in such a way as to make the reattach obvious. I hope solder wick works. Holes don't appear to be through the board.
    Jim
  • Surgery was a success, patient is healed and I was successful running 2 robotic gear motors from the shack. Using Duane's QuickStart board servo tester I had wheels turning! Next step, run QS off 5 volt USB power pack and motors off of 6 NIMH batteries.
    Jim
    Excellent report, soldier! I'm having fun with the little module I built around this controller board. Slap some kinda bot together and post in Figure 8. I'm alone and outta control over there. You won't believe what's coming next...
  • WhitWhit Posts: 4,194
    Nice work folks - looks like some good fun. That figure 8 should be added the the gallery erco!
    Whit wrote: »
    Way ahead of you, Padre!
