Where are the Quickstart electrolytic caps? — Parallax Forums
lardomlardom Posts: 1,659
edited 2016-02-10 01:20 in Propeller 1
I've had five Q44 chips in a drawer for several years and I wanted to use them so I bought a couple Schmartboard modules to learn a little about smt soldering.
I use Quickstart boards all the time and never noticed. The Schmartboard module has four of them.
  • ErNaErNa Posts: 1,742
    If you are looking for the caps at power, those are just 100nF ceramic capacitors placed on each side of the chip
  • As best as I can tell from the schematic and the board, the Quickstart has no on-board electrolytics. There are two large, relatively speaking, SMD caps near the regulator just above the USB port that are 10 uF each
  • ErNa and Hal Albach, thanks. I see them now. Parallax has done an amazing job with the Quickstart.
  • Yup, large-valued multilayer ceramic caps are often cheaper and smaller than electrolytics, and they last longer. Plus they tend to have lower ESR. I use them in lieu of electrolytics whenever I can get by with it, assuming they'll play nice with whatever regulator I'm using.
