Raspberry Pi + RoboPi (propeller based) Elf gets a camera and streams MJPEG! — Parallax Forums
Bill HenningBill Henning Posts: 6,445
edited 2015-06-07 18:45 in Robotics
Robots are a lot of fun.
Robots that stream video over WiFi are even more fun!
http://www.mikronauts.com/robot-zoo/elf-2wd-pi-robot/
Today I’ve updated my Elf Raspberry Pi based robot’s build log with instructions on:
adding a Raspberry Pi Camera
adding MJPG-Streamer so Elf streams what he sees over WiFi
adding a ramdisk for MJPG-Streamer so it won’t wear out the SD card
I hope you enjoy the Elf blog, and please feel free to ask any questions!
  • WhitWhit Posts: 4,191
    edited 2015-06-01 08:41
    Fantastic stuff Bill! Thanks for keeping us up on all you are doing..
    edited 2015-06-01 09:39
    Thanks Whit!
    Next I will get h.264 streaming working for higher resolution and frame rates... then I will add a compass to RoboPi on Elf, so that I can navigate better.
    Wifey does not know yet, but I am sorely tempted by lidar modules...
    Whit wrote: »
    edited 2015-06-01 12:18
    Don't know if you saw or remember this thread - erco is always on the hunt for a great deal - might check with him - sounds almost like a bargain - if you say it fast...
    http://forums.parallax.com/showthread.php/156627-400-360-Degree-Laser-Scanner
    Other good links there too...
    edited 2015-06-01 17:14
    That is a nice scanner... now how do I get it past wifey?
    Hmm... maybe a subtle hint suggesting it as a Christmas present...
    Whit wrote: »
    edited 2015-06-01 20:17
    Subtle? I leave a detailed list...
    Father's Day, Groundhog's Day, Thanksgiving.. Whatever it takes! And check with erco again - he probably has a source on a cheaper one now!
    Good luck!
    edited 2015-06-02 12:55
    LOL!!!
    Thank you, that is a great idea.
    Whit wrote: »
    Good luck!
    After some dead ends, I got h.264 streaming working following a nice simple blog article by Martin.
    1296x972 @ 24fps
    High latency though (2 sec)
    http://www.mikronauts.com/robot-zoo/elf-2wd-pi-robot/7/
    Now I need to reduce the latency...
