3.5mm bullet connectors
I have been looking for a "real" supplier that carries the "standard" 3.5mm female bullet connectors. Perhaps I don't know how to look, and mouser or digikey carry them. I need to have some special purpose esc's assembled, and can't seem to find anything.
Like these -
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=10255
http://www.focalprice.com/YO262Y/10PCS_35MM_GoldPlated_Bullet_Banana_Plug_Motor_ESC_Connector_Gold.html?utm_source=CS&utm_medium=GM_US&utm_campaign=CS_GM_US_YO262Y&gclid=CMjs4vjMnbYCFcw7Mgod2F0AOQ#.UVNEdaVwp34
Like these -
Many pilots of drones using this 3.5 connectors think that with motor vibrations they may produce bad contacts and crashes.
Also they solder directly the ESC to motors : it seems that this inproved flight security ?
http://www.te.com/catalog/products/en?q=shur-plug
They require crimp tools, but they can be done with universal tools or soldering
I guess there is some small shop in Mainland China where a guy sits at a machine lathe and turns these out one by one. There are alternative means of connection for high power, but the bullet connector is prefered for R/C airplanes as it is of minimal weight.
Do you really have to comply with 3.5mm female bullet connectors, or would you consider alternatives? Automotive connectors are easily available for equally high amperage.
So this is more than a mere parts sourcing problem.
I do realize that you goal may to be to support all sorts of motors with whatever the 3.5mm male connector is as provide. It seems that if you do find a product, you are going to have to both install the female connectors and provide the male connectors for a good customer relations solution.
I suppose that regular female ones with a hole for wire could easily be adapted. You just have to provide a small hunk of large gage copper wire.. say 10, 12, or 14 gage that is used in house wiring. First solder it to the female connector, and then flush to the board... finally trim.
