FTDI Driver problems with Windows 7 64-bit (Also, uninstalling drivers/COM entries) — Parallax Forums
Chris SavageChris Savage Parallax EngineeringPosts: 14,406
edited 2012-10-26 11:16 in General Discussion
Hello Everyone,
I have noticed something with the FTDI Drivers and Windows 7 64-bit that became more prevalent at the Propeller Expo. I haven't noticed this with other versions of Windows, however it may be a problem with newer drivers. So if you have had any issues with your Propeller not being detected when using the USB interface please read below.
When installing the FTDI Driver, either via the included driver in the Propeller Tool or BASIC Stamp IDE, or when running the CDM Installer from FTDI you should see the following command (DOS-like) box pop-up during the driver installation. If you do not, then the drivers were not installed.
(CLICK FOR LARGER VIEW)
I have seen where the driver setup had to be run at least twice to get this to appear and most assume that if they've run the driver and accepted the box asking for permission to make changes to the system that everything is good. That is not necessarily the case. If you did not see this box then download the latest driver from the ftdi website at the following link:
http://www.ftdichip.com/Drivers/VCP.htm
In the row for Windows in the comments column are the words setup executable, which is a link to download the setup installer. This is the preferred method for installing this driver. When running the driver, if you do not see the command window above re-run it. If after three tries you still have not seen it you may have another issue such as insufficient permissions, anti-virus software or even malware preventing the install.
If you need to clean a previous install of the FTDI driver from your system and/or clear any COM Ports aded to the registry then you should obtain the CDM Uninstaller from the following link:
http://www.ftdichip.com/Support/Utilities/CDMUninstaller_v1.4.zip
Extract the contents of this ZIP file into a folder on your desktop or elsewhere and run the CDMuninstallerGUI.exe file.
You should see the following dialogue box which already has the FT232R Product/Vendor IDs in the box.
Click the "Add" button to add this Product/Vendor ID to the list of devices to remove. Optionally you can check the "Generate log file" checkbox for a record of what operations were performed and which COM Port entries were removed. Now press the "Remove Devices" button. Once completed you should restart your computer so that the O/S can clean things up. You should then be ready to re-install your drivers as listed above.
I hope this helps. Sometimes driver installations don't go as planned and the reasons may not be anything we can diagnose and/or help with. However this guide covers those we can help with. Take care!
888 x 588 - 106K
327 x 301 - 24K
327 x 301 - 26K
    edited 2012-04-18 10:26
    I know Parallax has standardized on the FTDI USB to serial solution. But over in the Pololu forum David Grayson implied that more usb to serial solutions would work if Parallax implemented a work around to the Windows built in virtual COM port driver bug. Here's what David said
    "The main problem was that there was a bug in the Windows USB-to-serial driver usbser.sys and the Parallax software didn't implement a workaround for it. Specifically, if the software changes the value of the RTS control line for the virtual COM port, the driver doesn't actually send that new value to the Wixel right away. Instead it waits until the next time DTR is changed by the software. This causes the "loopback" detection feature of the BASIC Stamp Editor program to fail. I know there is some workaround to this because the problem doesn't happen if you control the COM port's RTS line using the .NET SerialPort class, but to implement that workaround would require changing the Parallax software. There might have been some other issue with the Send Break command, but we don't remember."
    I asked him why the FTDI based cables didn't have this problem and he said the FTDI chips have their own driver, ftdibus.sys, so they don't use usbser.sys and are not subject to its bugs. Basically has Parallax ever tried the work around? Being able to use the built in virtual COM port driver could be handy.
    edited 2012-04-18 11:21
    Martin,
    With a couple of exceptions we're using the stock FTDI driver as it is. The problem I am seeing involves installation of the driver, not what you described. As for the loopback issue, while I have not seen this, loopback is not required for the IDE to program the BASIC Stamp, however echo is. So as long as the IDE detects echo you can program a BASIC Stamp.
    I do find it interesting that he mentions the bug and our lack of a workaround, but then says this doesn't affect the FTDI cables, which we're using the same driver. Not sure if I missed something in that.
    edited 2012-04-18 11:41
    Basically using the FTDI USB to serial uses the FTDI version of the virtual COM port driver, not the Microsoft built in usbser.sys which has a known bug. So the Parallax IDE doesn't encounter the Microsoft bug and is working around it by using the FTDI driver. But this has a downside that when someone tries to use a different USB to serial cable or solution they may encounter the bug and get a "stamp not found error".
    This wouldn't be so bad if all microcontrollers suffered equally, but the Arduino IDE does implement the work around and works with more USB to serial options. Specifically wireless ones that plug directly into the Tx, Rx, and reset lines. So I'm just mentioning this because you'll see the "stamp not found" error threads on the forum and Stamp users are limited to the Flash Fly for wireless programming.
    edited 2012-04-18 12:18
    No problem, I just wanted to be clear on the problem so users are aware of what this particular post was about (no confusion). Thanks for the feedback. I was not aware of the issue you described.
  • jk1jk1 Posts: 4
    edited 2012-10-23 14:25
    I've got the Parallax PDB using the BS2 chip and am also unable to connect it to the USB port on my Windows 7 64 bit laptop despite running the ftdi executable. I get the window stating that driver installation has succesfully completed. But the usb connection to the PDB remains unaccessible. I also tried running the uninstaller, rebooting the laptop, and reinstalling the ftdi executable with no success. When I insert the usb cable into the laptop (with the other end connected to the PDB
    board), I get an error message from windows stating - USB DEVICE NOT RECOGNIZED, one of the usb devices attached to this computer has malfunctioned
    and windows does not recognize it. Has anyone had a similar experience and gotten the usb connection to work?
    edited 2012-10-24 12:10
    When you install the driver, which COM port is it being installed as? Also, are you connecting the USB cable while the PDB is power on or off? If it was on try rebooting the PC and reconnecting while the power is off.
    edited 2012-10-24 12:14
    Didn't some people report issues when connecting devices to a USB 3.0 port instead of a USB 2.0 port? If it is a newer system that has both style ports then it may be worth trying it in a different USB port.
  • jk1jk1 Posts: 4
    edited 2012-10-24 18:20
    I am not sure which com port is being used as I clicked on the "setup executable" link for Windows
    at the ftdi website (http://www.ftdichip.com/Drivers/VCP.htm) and the drivers were automatically
    downloaded . I did download and unpack the files manually to recheck it and note the existence of an ftdiport.inf file
    but viewing it under notepad I am unable to tell what port is assigned. I am not sure that the ftdi driver is
    even being called or assigned.
    When I connect the usb cable to the laptop (with the other end connected to a powered on PDB), I can
    see in the Device Manager Window that under Universal Serial Bus Controllers an Unknown Device item
    pops up with a yellow warning sign implying that Windows was unable to recognize it. When I double
    click on this devie it gives the Location as Port_0004.Hub_#0006. The driver assigned to this Device is
    provided by microsoft and called usbccgp.sys
    I tried connecting the USB cable both when the PDB is powered off and when it is powered on with the
    same error of USB DEVICE NOT RECOGNIZED. Also tried rebooting laptop with PDB powered off but
    get the same result.
    Checked Windows Device Manager by first enabling viewing of hidden devices but still dont see any
    com port usage. In a DOS prompt i entered the following :
    set DEVMGR_SHOW_NONPRESENT_DEVICES=1
    start devmgmt.msc
  • jk1jk1 Posts: 4
    edited 2012-10-24 18:27
    The laptop is a toshiba with 2 usb ports, both of which are version 2.0.
  • Shawn LoweShawn Lowe Posts: 635
    edited 2012-10-24 20:23
    Well Chris, you should feel somewhat good because I was having issues getting online with my PPDB, and by going through your instructions, I am online and doing some programming! Yea! Thanks for the post!
  • jk1jk1 Posts: 4
    edited 2012-10-25 15:44
    Got it to work today! Hooray! Not at all sure why it worked this time and not the previous times. I plugged in the usb cable to the PDB, plugged in the power cable for the PDB, turned the PDB on, waited for about 10 secs, and then plugged in the other end of the USB to my already running laptop.
    This time a Microsoft window with the header Driver Software Installation came up saying :
    USB<--> Serial , Obtaining device driver software from Windows Update.
    Once the update was over there was the following 2 statements in the window:
    - USB serial converter
    - USB serial port (com3)
    I ran a small hello world program in the Basic Stamp Editor. It worked!
    Looked under Device Manager on the Control Panel for Windows and for the first time saw a Ports (Com & Lpt) line. Clicking on this shows a USB Serial Port (Com3) line.
    Right clicking on the properties shows that it is using an FTDI driver.
    Thanks to all of you for your input. Your feedback kept me going in search of a solution.
    Shawn, jk1, so glad to hear you are both up and running.
    As a note, the reason I asked for you to reboot and try connecting the board without the power on is that is the board was programmed to send debug data back to the PC (which many demo/example programs are) then connecting the board to the USB port could cause Windows to detect the board as a Microsoft Serial Mouse, or not properly detect it. You should always connect USB boards with the main power switch off for this reason. Power is not needed to detect the USB interface as that chip is powered by the USB port.
