SX Video and SX Key — Parallax Forums
SX Video and SX Key
ajajackajajack Posts: 26
edited 2012-02-06 12:33 in General Discussion
Hello,
I would like to know if it is safe to use the SX Key to update the firmware of Terry Hitt's SX video module. The video module has on board a 50MHz resonator.
Will this harm the SX Key?
Andrew
    You can program the module with the resonator in place without any issues. You just can't use the debugger with the resonator in the circuit.
    Now, If the SX chip is being driven by a TTL clock osc module then that MUST be removed for both programming and debugging.
