Tutorial - Using the MAX7219 (7 Seg Display Driver) with SX/B
A SX/B tutorial on how to use the MAX7219 to control 7 segment displays.·
The advantage is that it only utilizes 3 pins on your MCU, uses a simple serial protocol and you can control up to eight digits or 64 LED segments.· The MAX7219 can also be used to switch 5vdc·500ma loads, more·than a typical MCU can handle (which is about 20ma)
The disadvantage is that the chip costs $8.00.·
Edit: updated 4pm PDT
John J. Couture
San Diego Miramar College
Post Edited (John Couture) : 4/25/2010 11:01:34 PM GMT
John J. Couture
pdf
327K
