Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
MAX232N Programmer — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
Propeller 1
MAX232N Programmer
Bobrien
4
2008-11-08 20:56
edited 2008-11-08 21:48
in
Propeller 1
How would I go about wiring up a MAX232N chip to program the propeller?
JerryN
32
2008-11-08 21:33
edited 2008-11-08 21:33
Check here
www.parallax.com/DiagramsSchematicsandImages/tabid/254/Default.aspx
T Chap
4,224
2008-11-08 21:35
edited 2008-11-08 21:35
Is there some reason not to update to the newer version of programming using FTDI FT232RQ or RL?
The USB version is may be even less parts.
See the Prop demo board here for a schematic:
www.parallax.com/tabid/254/Default.aspx
Else, here is the old school Max3232 concept. TXD232 goes to Prop Tx pin, RXD232 goes to Prop Rx. RES232 goes to Prop reset pin.
755 x 427
47K
46.5K
JerryN
32
2008-11-08 21:48
OOPS! Wrong reference - sorry!
And you already have a better answer.
Jerry
Sign In
Register
to comment.
Jerry
