Assembler - strange behaviour
Hi,
Not sure if its me - BUT - I am getting some very strange results when trying to use the MOVD instruction :
'32bit block done
blkstore mov 0-0, bitbuf 'now save incoming 4 char block NB MUST set DEST!!!
add p_IN, #$1 'set up pointer for next block
'mov p_IN, #cmdIN
'nop
movd blkstore, p_IN 'set dest storage cell
djnz blkcnt, #spi_char 'now if not all done - go get next block
''all done
wrlong p_IN, par
Notice the two commented out lines
p_IN is set earlier in the app to #cmdIN, so the following occurs :
1. if I comment out the add and uncomment the nop p_IN reports as being 36h
2. If I comment out the nop and uncomment the line above it p_IN reports 36
So far So GOOD ;-)).
3. If I comment out the line from 2 and uncomment the add line - p_IN reports as 38 (ie 2 more than it was previously!!).
OK - so what am I doing stupid here please anyone ????.
Also - if I try to compare the hex listing (Ctrl-F8), I see that my register numbers are 6 cells (24 bytes) out The above test on a running board shows cddIN as register 36 - but it appears at byte location 0FC (which is 36 * 4 + 24) :-O is this explained somewhere ??.
Sorry but I am pretty new to the Propeller - but have it already designed into a couple of PCB's :-O.
Many Thanks
Apologies if its something stupid I am doing (probably ;-).
Best regards
Graham
'32bit block done
'mov p_IN, #cmdIN
'nop
''all done
wrlong p_IN, par
Many Thanks
Best regards
Graham
And do you initialize the D field at some prior point?
You don't have to use p_IN.
If you just want to add 1, you can simple add %1<<9
as that value is higher than 511, it will need to be stored a data
'32bit block done blkstore mov 0-0, bitbuf 'now save incoming 4 char block NB MUST set DEST!!! add p_IN, #$1 'set up pointer for next block ' mov p_IN, #cmdIN ' nop movd blkstore, p_IN 'set dest storage cell djnz blkcnt, #spi_char 'now if not all done - go get next block ' 'all done wrlong p_IN, parWhere is blkstore destination initially set ? wouldn't make maybe more sense to set its destination first and then use the mov ?
No problem - will post the code below. Its the start of an SPI interface, as the obex ones don't seem to have a timeout - ie they use waitpeq :-((.
Graham
Like this ??
DAT org 0 ' ' SPI Engine - setup 'dummy long $aaaaaaaa dospi mov dira, #$120 'pin5 is data output mov outa, #$020 'start it with high and no led mov blkcnt, #2 mov dIN, #0 ' SPI Engine - main loop spiloop mov p_spiOUT, par 'par is start of HUB data structures add p_spiOUT, #(5 << 2) 'plus offset bytes mov p_OUT, #cmdOUT ' now local data pointer rdlong cmdOUT, p_spiOUT wz 'read output command from HUB 'wrlong countme, p_data if_nz jmp #spi_output 'ooh we got a command - so go handle it spi_input 'first we need to wait for a start of clock cycle. Clock is normally LOW test spiCLKmask,ina wz 'Test input pin. Is it low? if_nz jmp #spiloop 'oops waiting for a low clock!! mov p_IN, #cmdIN 'local data pointer movd blkstore, p_IN 'local data pointer mov time, timeout 'start timeout spi_char mov bitbuf, #$1aa mov bitcnt, #32 :loop test spiCLKmask,ina wz 'Test input pin. Is it low? if_z djnz time,#:loop wz 'No: Go back and check again. if_z jmp #spitimeout 'At this point the z flag will indicate whether we timed out or not. 'if we got here we should have a high clock pin :loop1 test spiCLKmask, ina wz 'so wait for it to come low again if_nz djnz time,#:loop1 wz 'No: Go back and check again. testn time, #0 wz if_z jmp #spitimeout shl bitbuf, #1 test spiINPmask, ina wz 'go get our data bit if_nz add bitbuf, #$01 djnz bitcnt,#:loop 'if we have not done all bit go round again '32bit block done blkstore mov 0-0, bitbuf 'now save incoming 4 char block NB MUST set DEST!!! add p_IN, #$1 'set up pointer for next block 'mov p_IN, #cmdIN 'nop movd blkstore, p_IN 'set dest storage cell djnz blkcnt, #spi_char 'now if not all done - go get next block ''all done wrlong p_IN, par 'mov outa, #$120 'OK so input is high, so wait for it to come low again jmp #spiloop spitimeout mov outa, #$120 jmp #spiloop spi_output add p_spiOUT, #4 'point to first data byte rdlong dOUT, p_spiOUT 'read output command from HUB add p_spiOUT, #4 'point to first data byte rdlong dOUT2, p_spiOUT 'read output command from HUB add p_spiOUT, #4 'point to first data byte rdlong dOUT3, p_spiOUT 'read output command from HUB add p_spiOUT, #4 'point to first data byte rdlong dOUT4, p_spiOUT 'read output command from HUB mov p_OUT, #cmdOUT ' now local data pointer ''all done jmp #spiloop '------------------------------------------------------------------------------------------------------------------------------ timeout long 80_000_000 / 10 '1/10th second at 80MHz spiINPmask long 1 << 4 'port bit 4 spiOUTmask long 1 << 5 'port bit 5 spiCLKmask long 1 << 6 'port bit 6 spiSELmask long 1 << 7 'port bit 7 'pointers to HUB input and output structures p_spiIN long 0 p_spiOUT long 0 'pointers to local COG RAM data structures p_IN long 0 p_OUT long 0 'local command structure 'NB mirrored in HUB RAM cmdIN long $aa '4 bytes of command header dIN long $bb '16 bytes of data dIN2 long $cc dIN3 long $dd dIN4 long $ee cmdOUT long 0 '4 bytes of command header dOUT long 0 '16 bytes of data dOUT2 long 0 dOUT3 long 0 dOUT4 long 0 'local data countme res 1 time res 1 bitbuf res 1 bitcnt res 1 blkcnt res 1 fit 496you need to move
mov blkcnt, #2
to or below spiloop
as here your are decreasing it.
That's normal. The binary file you see in the hex listing includes header info & Co, i.e. the first DAT block doesn't start at 0. One way to figure out the difference is to compile with F9 then place the cursor at the label you're interested in. The status line then tells you object location and cog location, e.g. I took your verbose example from post #4 added a dummy PUB method and compiled it. cmdIN reports $E0 object offset and $36 cog offset. Now, the binary file can have more than one object but the top level object is stored at offset $10 (in fact at offset word[3] of the binary file which amounts to the same right now). That gives us a file offset of $E0+$10 = $F0. Looking there reveals a long $AA. HTH
Many many thanks - you saved my sanity !!. Of course it gets bumped twice as I am indeed running through the code twice :-O. Told you it was something stupid.
Still the upside is that when you have to get down and dirty at this level - boy do you learn a lot and quickly ;-).
Still trying to master the assembler addressing modes (or lack of) :-O - coming from a wide variety of different microprocessor chips - right back to the 6800 ;-). For me 'dynamic' self-modifying code has ALWAYS been a NO-NO !! - as my background (way-back) was in EPROM-based designs - where you just CANNOT do that!.
Also many thanks to kuroneko - for the tip on the status bar after compilation. That will save me some time.
Thanks for your patience guys, as you can see - I am new to this CPU, so getting into assembler with little or nor real-time debugging isn't easy ;-)).
Best Regards
Graham
Thanks for your input ;-).
G.
