Serial to parallel shift register ( 595) PBASIC code anyone?
595 serial to parallel shift register has been recommended here as a I/O expansion hardware for Basic Stamp.
I am looking only for output expansion.
I do not see anything out of the ordinary to write appropriate subroutine for 595 to do that.
However, if someone already done that and is willing to share the code I would appreciate it.
Please note - I you cannot constructively contribute to the subject (relevant code for PBASIC), please do not.
Thank you.
Vaclav
Thank you.
Vaclav
The 595s are incredibly simple to use, the only specific command you are concerned with will be the shiftout command.
Dave
