Anyone tried to bend clear plastic sheet ?
Britannicus
I've got a sheet of 3mm thick perspex - I'd like to use it for creating interesting housings etc.
Has anyone tried shaping perspex sheet into curves / rightangles - I''m figuring some kind of heat treament to soften it, but figure I could get myself really snarled up with burning plastic an dmelted goo - before I do, has anyone got any advice ?
Perspex is the UK trade name for acrylic sheet, for the foreigners! Lucite in the USA.
When I took an engineering design course 50 years ago I learned the proper name for it - something like poly-methyl-methacrylate.
Brilliant! I have melting plastic in my future!
http://www.usplastic.com/catalog/item.aspx?itemid=23104&catid=698
http://www.craftics.net/ShowItems.aspx?Category=86
-- Gordon
Plexiglass is my favorite material for robotics creation and I have work alot with it. However I have never tried to bend it. But some times as I cut the plexiglass I realize that this material has different reaction acordind the type of the plexiglass. You can build a variety of shapes using smaller pieces of plexiglass and metal brackets to connect them. I think It is easier to bend the metal brackets in order to create your shape.
They were trying to make a acrylic dome so the had a sheet of acrylic sandwiched between two pieces of plywood with a large central cut out. The put the plywood and acrylic in an oven and then pressed the acrylic over a form. It took them several tries, but it looked pretty cool once it worked.
Another TV program (I really don't watch a lot of TV) showed the making of and acrylic submarine. That was amazing. The acrylic sub could safely dive deeper than the WWII subs. They used cast acrylic for the sub. The had to bake the huge pieces in a large oven to get them to cure correctly.
