Using INDIRECT driver
Is anyone using the INDIRECT driver for the WIZnet module? I took a perfectly functioning prototype (uptime >20 days) and switched it from SPI to INDIRECT, and now it's completely unreliable. I'm pretty sure the connections are correct, as it works sometimes. However, I can't seem to even write a MAC address and then read it back and compare the values correctly.
BTW, I pulled the latest revision (0.12) from the Google code repository today.
Someone else reported similar symptoms with both SPI and Indirect drivers.
If you post your code I can run it on my Spinneret and report back.
Note you'll need to change the pin values, and the path to the WIZnet driver. I've made a copy to try to debug. On my setup, when I write MAC 00:00:00:00:FF:FF I read back 00:00:00:00:FF:00 the first time, and 00:00:00:00:FF:C0 in the "dump" output. When I write 255.255.255.0 as the SubnetMask, I read back 255.255.0.0 both times. The IP address and Gateway Address are OK.
Thanks for any ideas.
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 'WIZ module INDIRECT I/O ADDR0_PIN = 1 ' Address bit 0 (out) ADDR1_PIN = 2 ' Address bit 1 (out) CS_PIN = 3 ' Chip Select (out) RD_PIN = 4 ' Read (out) WR_PIN = 5 ' Write (out) RESET_PIN = 6 ' Reset (out) DATA_START_PIN = 7 ' Data (in/out) SEN_PIN = -1 ' SPI ENABLE PIN IS UNUSED VAR byte dbgArray[512] DAT MACaddr byte $00, $00, $00, $00, $FF, $FF IP byte 192,168,1,127 GatewayIP byte 192,168,1,254 SubnetMask byte 255,255,255,0 OBJ W5100 : "W5100_Indirect_Driver_CUSTOM" PST : "Parallax Serial Terminal" PUB main PST.Start(115_200) waitcnt(clkfreq + cnt) PST.Home PST.Clear W5100.StartINDIRECT(DATA_START_PIN,ADDR0_PIN,ADDR1_PIN,CS_PIN,RD_PIN,WR_PIN,RESET_PIN,SEN_PIN) PauseMSec(2000) PrintMAC(@MACaddr) W5100.WriteMACaddress(true,@MACaddr) W5100.ReadMACaddress(@dbgArray) PrintMAC(@dbgArray) PrintIP(@IP) W5100.WriteIPaddress(true, @IP) W5100.ReadIPaddress(@dbgArray) PrintIP(@dbgArray) PrintIP(@SubnetMask) W5100.WriteSubnetMask(true, @SubnetMask) W5100.ReadSubnetMask(@dbgArray) PrintIP(@dbgArray) PrintIP(@GatewayIP) W5100.WriteGatewayAddress(true, @GatewayIP) W5100.ReadGatewayAddress(@dbgArray) PrintIP(@dbgArray) DumpSettings PRI DumpSettings PST.Str(string("WizNet W5100 Module Settings::",PST#NL)) W5100.ReadMACaddress(@dbgArray) PST.Str(string("MAC Address : ")) PrintMAC(@dbgArray) W5100.ReadIPaddress(@dbgArray) PST.Str(string("IP Address : ")) PrintIP(@dbgArray) W5100.ReadSubnetMask(@dbgArray) PST.Str(string("Subnet Mask : ")) PrintIP(@dbgArray) W5100.ReadGatewayAddress(@dbgArray) PST.Str(string("Gateway Address : ")) PrintIP(@dbgArray) PRI PrintIP(IPptr) | i repeat i from 0 to 3 PST.Dec(byte[IPptr][i]) if i <> 3 PST.Str(string(".")) PST.Char(PST#NL) PRI PrintMAC(MACptr) | i repeat i from 0 to 5 PST.Hex(byte[MACptr][i],2) if i <> 5 PST.Str(string(":")) PST.Char(PST#NL) PRI PauseMSec(Duration) '' Pause execution for specified milliseconds. '' This routine is based on the set clock frequency. '' '' params: Duration = number of milliseconds to delay '' return: none waitcnt(((clkfreq / 1_000 * Duration - 3932) #> 381) + cnt)Argh.
