PING sensor problem?
I've connected my PING sensor to my BS2 and ran the Ping test.bs2 program. But I'm only getting a maximum number of 172(around 6cm). No matter how I point the PING sensor, that is the max reading I get. I also have the sensor elevated about the table by around 8 inches or so.
Would this indicate a faulty sensor? Is there something else I could be doing wrong?
[Tim]
[Tim]
I found my Ping))) to be really plug'n'play recently.
Are you using it with a Stamp or what?
Are you using the Parallax connector cable (white-red-black)?
If you have a bad cable or bad connection between the PING and the Stamp, you would probably get a maximum reading all the time.
If the PING is connected to the wrong Stamp I/O pin, you would get a maximum reading all the time.
[Tim]
' PingTest.bs2 ' {$STAMP BS2} ' {$PBASIC 2.5} time VAR Word DO PULSOUT 15, 5 PULSIN 15, 1, time DEBUG HOME, "time = ", DEC5 time PAUSE 100 LOOPAnyone else ever run into this?
[Tim]
If your breadboard is right on the tabletop or whatever, then that might be a problem.
Other Notes -- The Ping))) that I bought from Parallax came with 2 standoffs, 2 screws and 2 nuts to mount it "remotely" and I supplied my own 3pin cable (but that's available from Parallax.) The Ping))) that I got from RadioShack was just the device itself and no "accessories". If you can fashion a post and a mounting bracket, to get things up in the air and away from other stuff, the device's performance will improve.
http://forums.parallax.com/attachment.php?attachmentid=80565&d=1303663383
http://forums.parallax.com/attachment.php?attachmentid=80570&d=1303663386
http://forums.parallax.com/attachment.php?attachmentid=80773&d=1304198239
minw is gettting 4.38 but im not sure if it is actually working because it wont talk to my chip
[Tim]
