Please stress test my Spinneret 4 socket server.
Here's the link. Just click the 2 links.
http://spinneret.servebeer.com:5000/index.htm
You might have to refresh. You might lock the server. Who knows...
Please provide feedback; browser, steps to reproduce issue, etc
Thanks all.
Thanks all.
The Spinneret has 4 hardware sockets. The test pages require 5 and 6 connections.
@ElectricAye testing Safari right now.
Back to the drawling board.
Thanks again.
please buy a second webserver to do hotswapping
best regards
Stefan
I can do a ping
result
Ping wird ausgef
It not sure how. You're hitting the IP assigned by my ISP. If I could adjust the timeout, what are the steps? Do you mean TTL?
ab -n 100 -c 1 [url]http://spinneret.servebeer.com:5000/images/ES137.jpg[/url] This is ApacheBench, Version 2.3 <$Revision: 655654 $> Copyright 1996 Adam Twiss, Zeus Technology Ltd, [url]http://www.zeustech.net/[/url] Licensed to The Apache Software Foundation, [url]http://www.apache.org/[/url] Benchmarking spinneret.servebeer.com (be patient).....done Server Software: Spinneret/1.0 Server Hostname: spinneret.servebeer.com Server Port: 5000 Document Path: /images/ES137.jpg Document Length: 46477 bytes Concurrency Level: 1 Time taken for tests: 103.791 seconds Complete requests: 100 Failed requests: 0 Write errors: 0 Total transferred: 4659200 bytes HTML transferred: 4647700 bytes Requests per second: 0.96 [#/sec] (mean) Time per request: 1037.912 [ms] (mean) Time per request: 1037.912 [ms] (mean, across all concurrent requests) Transfer rate: 43.84 [Kbytes/sec] received Connection Times (ms) min mean[+/-sd] median max Connect: 339 351 18.8 347 478 Processing: 657 687 41.7 676 957 Waiting: 401 419 17.6 416 558 Total: 1008 1038 53.1 1024 1356 Percentage of the requests served within a certain time (ms) 50% 1024 66% 1026 75% 1029 80% 1032 90% 1058 95% 1175 98% 1263 99% 1356 100% 1356 (longest request) andrey@debian:~$
andrey@debian:~$ ab -n 100 -c 5 [url]http://spinneret.servebeer.com:5000/images/ES137.jpg[/url] This is ApacheBench, Version 2.3 <$Revision: 655654 $> Copyright 1996 Adam Twiss, Zeus Technology Ltd, [url]http://www.zeustech.net/[/url] Licensed to The Apache Software Foundation, [url]http://www.apache.org/[/url] Benchmarking spinneret.servebeer.com (be patient)...apr_socket_recv: Connection reset by peer (104) Total of 5 requests completed andrey@debian:~$
andrey@debian:/usr/lib$ ab -n 1000 -c 3 -r http://spinneret.servebeer.com:5000/index.htm This is ApacheBench, Version 2.3 <$Revision: 655654 $> Copyright 1996 Adam Twiss, Zeus Technology Ltd, http://www.zeustech.net/ Licensed to The Apache Software Foundation, http://www.apache.org/ Benchmarking spinneret.servebeer.com (be patient) Completed 100 requests Completed 200 requests Completed 300 requests Completed 400 requests Completed 500 requests Completed 600 requests Completed 700 requests Completed 800 requests Completed 900 requests Completed 1000 requests Finished 1000 requests Server Software: Spinneret/1.0 Server Hostname: spinneret.servebeer.com Server Port: 5000 Document Path: /index.htm Document Length: 1076 bytes Concurrency Level: 3 Time taken for tests: 274.925 seconds Complete requests: 1000 Failed requests: 8 (Connect: 0, Receive: 2, Length: 4, Exceptions: 2) Write errors: 0 Total transferred: 1266358 bytes HTML transferred: 1150666 bytes Requests per second: 3.64 [#/sec] (mean) Time per request: 824.776 [ms] (mean) Time per request: 274.925 [ms] (mean, across all concurrent requests) Transfer rate: 4.50 [Kbytes/sec] received Connection Times (ms) min mean[+/-sd] median max Connect: 339 397 490.9 348 9353 Processing: 411 427 23.7 420 844 Waiting: 0 408 22.6 404 624 Total: 751 824 493.4 772 9773 Percentage of the requests served within a certain time (ms) 50% 772 66% 776 75% 780 80% 784 90% 799 95% 824 98% 925 99% 3763 100% 9773 (longest request) andrey@debian:/usr/lib$
andrey@debian:/usr/lib$ ab -n 1000 -c 4 -r http://spinneret.servebeer.com:5000/index.htm This is ApacheBench, Version 2.3 <$Revision: 655654 $> Copyright 1996 Adam Twiss, Zeus Technology Ltd, http://www.zeustech.net/ Licensed to The Apache Software Foundation, http://www.apache.org/ Benchmarking spinneret.servebeer.com (be patient) Completed 100 requests Completed 200 requests Completed 300 requests Completed 400 requests Completed 500 requests Completed 600 requests Completed 700 requests Completed 800 requests Completed 900 requests Completed 1000 requests Finished 1000 requests Server Software: Spinneret/1.0 Server Hostname: spinneret.servebeer.com Server Port: 5000 Document Path: /index.htm Document Length: 1076 bytes Concurrency Level: 4 Time taken for tests: 254.216 seconds Complete requests: 1000 Failed requests: 4 (Connect: 0, Receive: 1, Length: 2, Exceptions: 1) Write errors: 0 Total transferred: 1187734 bytes HTML transferred: 1073848 bytes Requests per second: 3.93 [#/sec] (mean) Time per request: 1016.863 [ms] (mean) Time per request: 254.216 [ms] (mean, across all concurrent requests) Transfer rate: 4.56 [Kbytes/sec] received Connection Times (ms) min mean[+/-sd] median max Connect: 338 585 837.3 348 9359 Processing: 401 428 25.4 420 765 Waiting: 0 410 29.0 404 763 Total: 751 1013 843.0 772 9871 Percentage of the requests served within a certain time (ms) 50% 772 66% 777 75% 783 80% 788 90% 860 95% 3768 98% 3812 99% 3826 100% 9871 (longest request)
andrey@debian:/usr/lib$ andrey@debian:/usr/lib$ ab -n 1000 -c 5 -r http://spinneret.servebeer.com:5000/index.htm This is ApacheBench, Version 2.3 <$Revision: 655654 $> Copyright 1996 Adam Twiss, Zeus Technology Ltd, http://www.zeustech.net/ Licensed to The Apache Software Foundation, http://www.apache.org/ Benchmarking spinneret.servebeer.com (be patient) Completed 100 requests Completed 200 requests Completed 300 requests Completed 400 requests Completed 500 requests Completed 600 requests Completed 700 requests Completed 800 requests Completed 900 requests Completed 1000 requests Finished 1000 requests Server Software: Spinneret/1.0 Server Hostname: spinneret.servebeer.com Server Port: 5000 Document Path: /index.htm Document Length: 1076 bytes Concurrency Level: 5 Time taken for tests: 249.667 seconds Complete requests: 1000 Failed requests: 7 (Connect: 0, Receive: 2, Length: 3, Exceptions: 2) Write errors: 0 Total transferred: 1255383 bytes HTML transferred: 1139852 bytes Requests per second: 4.01 [#/sec] (mean) Time per request: 1248.336 [ms] (mean) Time per request: 249.667 [ms] (mean, across all concurrent requests) Transfer rate: 4.91 [Kbytes/sec] received Connection Times (ms) min mean[+/-sd] median max Connect: 338 793 1204.1 348 9355 Processing: 397 434 33.9 421 852 Waiting: 384 415 30.2 404 723 Total: 751 1226 1213.7 775 10111 Percentage of the requests served within a certain time (ms) 50% 775 66% 784 75% 804 80% 827 90% 3767 95% 3804 98% 3859 99% 3892 100% 10111 (longest request) andrey@debian:/usr/lib$
andrey@debian:/usr/lib$ ab -n 1000 -c 10 -r http://spinneret.servebeer.com:5000/index.htm This is ApacheBench, Version 2.3 <$Revision: 655654 $> Copyright 1996 Adam Twiss, Zeus Technology Ltd, http://www.zeustech.net/ Licensed to The Apache Software Foundation, http://www.apache.org/ Benchmarking spinneret.servebeer.com (be patient) Completed 100 requests Completed 200 requests Completed 300 requests Completed 400 requests Completed 500 requests Completed 600 requests Completed 700 requests Completed 800 requests Completed 900 requests Completed 1000 requests Finished 1000 requests Server Software: Spinneret/1.0 Server Hostname: spinneret.servebeer.com Server Port: 5000 Document Path: /index.htm Document Length: 1076 bytes Concurrency Level: 10 Time taken for tests: 234.081 seconds Complete requests: 1000 Failed requests: 69 (Connect: 0, Receive: 22, Length: 25, Exceptions: 22) Write errors: 0 Total transferred: 1169861 bytes HTML transferred: 1055835 bytes Requests per second: 4.27 [#/sec] (mean) Time per request: 2340.805 [ms] (mean) Time per request: 234.081 [ms] (mean, across all concurrent requests) Transfer rate: 4.88 [Kbytes/sec] received Connection Times (ms) min mean[+/-sd] median max Connect: 0 1489 2150.2 351 9364 Processing: 410 827 2808.9 421 21000 Waiting: 0 414 56.3 404 954 Total: 751 2317 3372.8 780 21000 Percentage of the requests served within a certain time (ms) 50% 780 66% 864 75% 3763 80% 3768 90% 3851 95% 9767 98% 10026 99% 20998 100% 21000 (longest request) andrey@debian:/usr/lib$
Jim
I also hit it with this from the Linux box:
while [ 1 ]; do wget [url]http://spinneret.servebeer.com:5000/index.htm[/url] -O /dev/null done
It worked flawlessly up to 3 of them in parallel. A fourth instance started showing some infrequent delays connecting. 5+ was getting an occasional intermittent read error (socket reset by peer). I went all as far as 8 of them.
Scott
That's what ab is for.
