How to make the "propeller clock" by Propeller Chip??
Hello everybody !!
Just like the video : http://www.youtube.com/watch?v=UvXjT7MQt_4&feature=fvsr
or http://www.youtube.com/watch?v=-6JnAxTXApw&feature=related
Are any suggession ??
Thanks a lot !!
Thanks a lot !!
You can probably mount the whole setup to a CD and put it on a motor taken out of a CD player, which will already have the attachment on it. You could also use an electric fan. Be warned, however, that although both of these can take the weight of the batteries they MUST be centered. I tried this once on a fan with them on the blade, and they flew off immediately and nearly hit me. I'd suggest the CD, although the fan is already in a presentable package, and you won't have to deal with that circuitry.
Hope this helps,
Microcontrolled
After the circuit is built you will definately need some counter weights to balance it as Microcontrolled indicated...
Nice. You have qualified for a cushy job in the Government
Remove the vertical blade (on an arm) that sensor see each turn and if the mcu don't see one for 1 second it will shut down.
But I never seen one that have power/battery and all items mounted on the prop blade it-self, most use DIY slip ring to transfer power.
I've just received an ideal board for the creation of a Propeller, propeller display...
(That is as soon as I finish my "real" work intended for it.)
Something cool to bring to the UPEW expo.. and the clock is ticking...
OBC
Unfortunately I couldn't get a hold of an RTC so I have to use the Propellers internal clock for now.... sigh.....
Great project! Got a couple of suggestions that might improve the final product. One, use brushes and slip rings to transfer power from an external 5 V supply. Use a large power input cap on the CD to absorb variations and regulate onboard down to 3.3. That eliminates the scary use of batteries on board. Next, how about mounting an led on the base shining through a small hole on the CD into a photo/transistor/diode to act as a sync pulse to determine the position of the display. That way no mater what the speed of the motor, the display can always be in the same position. I haven't looked at the code, but I am sure you still have plenty of prop resources available to syncup the display.
Jim
I don't have any discombobulated motors or cd-drives or I would show a pic.
EDIT: a good example is the same metod used to transfer power to motors on a slot car that has the flat style motors. I'll post a pic here in a few minutes
Jim
Let me know how it works out! A lot of VCR's use sliprings and brushes to move the video to/from the videoheads to the main electronics. It should work well for just power. The Cap and onboard regulator should cover any power irregularities caused by the slipring/brush system.
Jim
