The South and the bad weather
blittled
I just wanted to say that I hope everyone that is where the severe weather was is doing ok. Our thoughts and prayers are with you. It has been a bad year for disasters... New Zealand, Japan and now the southern US.
Basically what I'm trying to say is that unfortunately we have a long way to go yet this season, So keep your thoughts and prayers with everyone so that people will listen to the weather warnings and stay out of harms way.
Also irksome: why does the NWS use up valuable air time giving tidal reports when the local region is under a freakin tornado warning? When you're in your basement, huddled under the stairs, trying to listen through the static at the robotic voice telling you to take cover, and you're not sure they mentioned your town or not because of the static, but here comes the blippity bleep tidal report for the next 24 hours.... geez!
It's looking to be a rough season. Stay safe.
(1' high hail is unreal, sheesh!)
Wundermap has storm tracks on it, that show tornadic storms as a purple triangle. I like it, it kind of shows whats happening better than just SAME weather radios. The problem with bad weather is that if you wait to see if its bad or not, its too late to do much, unless you live in wide open spaces where you can see whats coming better.
This has never happened here as long as I can remember.
I would use a computer but as soon as I get thiunder I unplug everything .
no point toasting $10,000 in gear in my room .
Mind I storm chase so I do not stay In my room If its bad . I am in car with more cams then a NSA spy van .
Peter...
