Outside the box: Can we do ANYTHING other than a PC with the USB connection?
Oldbitcollector (Jeff)
I've been around the block enough to know the quick answer.... but
Is there any 'outside of the box' thinking we could employ to hook a peripheral device to the USB programming port of a Propeller protoboard, C3, or Platform board?
Ideas?
OBC
Ideas?
OBC
http://forums.parallax.com/showthread.php?130380-Android-Debug-Bridge-on-a-prop
(OBEX) http://obex.parallax.com/objects/731/
Unfortunately we must stay inside the box on this one.
The problem is that you want USB host capabilities once you take it off the tether or you want a mini-b to do your programming and seriol IO back to the host and then a USB-A connector so your Prop can be a host.
USB is a blessing and a curse and thinking outside the box is always fun!
Jeff T.
Well, I currently have a prop connected to a Chumby via USB. Chumby listens on /dev/ttyUSB0 for characters from the prop. Since the prop is telling the Chumby what to do, I'm going to label the Chumby a 'peripheral' and the prop is the controller.
Scott
Anybody that can show me the way to decode a 6.9375MHz NRZ, to relay closures & usb reporting ??
Ah, this is the kind of answer I was fishing for.. Thanks for giving me a lead to follow up on.
OBC
Yep. It's big. I use the USB most of the time for programming. It's really easy and quite portable. Anyone care to link a nice, known to work, USB to SERIAL cable, just for reference? I've been very slow to adopt serial, just because it's not been necessary and I do most propping on the go.
That said, why can't we just utilize a smaller connector for serial? Seems to me, Parallax could stock a cable, with the only decision being the connector.
.01 headers. problem solved
If I use them do it 2 ways POWER , TX .GND. RX. POWER
or data only its TX. GND . RX
if you flop the cable over you wont toast your devece AND the data pins are in a team so tat data only can work too .
Mind the BS2 needs that reset . d so then we do RESET POWER TX GND RX POWER BLANK
Peter......
TONS of equipment in plants still has serial ports, usually with DB-9 connectors.
Have had more of those break than I have the entire time I've used DB-9. Plus, they fit Atari controllers!
