If you ... you might be an old geek. (Everyone join in) - Page 3 — Parallax Forums
135
  • Ding-BattyDing-Batty Posts: 305
    edited 2011-04-27 14:23
    - Extra GEEK points if you know what "L.E.W.P." stands for
    "Leading Edge Word Processor"
    I think I can lay my hands on my copy of that software at home in under a minute... sigh.
    I had a Leading Edge Model M (manufactured by Mistubishi, IIRC), and also later a Leading Edge Model D (manufactured by Daewoo, I believe). I though it was a great machine.
  • vaclav_salvaclav_sal Posts: 451
    edited 2011-04-27 14:38
    You are a rich old geek who said that any program should fit into 640 K of memory.
    You are a old geek if you read “The inmates are running the asylum” more than once.
    If you “own K&R” ( I know I got TWO , but being old have no clue where they are!)
    edited 2011-04-27 16:46
    You might be an old geek if you know the punch line to this joke:
    What do you get when you cross an automotive executive with vampire bat?
    edited 2011-04-27 18:56
    Martin_H wrote: »
    Autoexec.bat
    edited 2011-04-27 19:04
    We have a winner.
    edited 2011-04-27 19:34
    If you've played Space War on a PDP-1.
    If you've had to insert time delays in your program as part of the addressing of data
    If you had a job watching for "blooms" in a memory array or if you even know what that might be
  • homosapienhomosapien Posts: 147
    edited 2011-04-27 19:44
    - If you assembled large electronic projects with a wire-wrap gun
    How do you define 'large'?
    Just finished this one last week.....
    1024 x 768 - 283K
  • ForrestForrest Posts: 1,341
    edited 2011-04-27 19:59
    You might be an old geek if you've ever used a disk notcher to double the storage capacity of a 5 1/4 inch floppy, so you could store up to 88K on each side of the disk!
    You might be an old geek if you've ever referred to a 320 x 192 pixel screen as 'hi-rez'!
    You might be an old geek if you've ever turned up the volume knob on your TV so you could hear if the data being read by your floppy drive sounded OK!
    edited 2011-04-27 20:01
    You might be an even older geek if you can't remember having done any of this stuff! :)
  • davidsaundersdavidsaunders Posts: 1,559
    edited 2011-04-27 20:18
    If you have done 98% of the stuff in this thread and understand 99% though were born after 1975, you might be a young starting old style geek (Me born 1978, started on the Apple II 1982).
    edited 2011-04-27 22:40
    Forrst,
    Or even older if you have done that trick with 8 inch disks. For an Intel MDS in mt case.
    edited 2011-04-27 23:12
    "You might be an old geek if you've ever used a disk notcher to double the storage capacity of a 5 1/4 inch floppy, so you could store up to 88K on each side of the disk!" - lol
    This is fun, we could go on and on.... how about 'bumping' or 'yanking' the floppy at a specific sector during a disk format to purposefully create a bad sector as a means for copy protection. If you've done that then you might be an old geek.
    How about whistling at just the right pitch over the phone to start modem negotiation? - that might qualify as an old goof ball rather than a geek.
    edited 2011-04-27 23:34
    I've done the whistle. Can still get a FAX machine to start it's second phase of negoiation.
    Ahh, copy protecting floppies! Yep. Messed with those in all sorts of ways. One interesting story pops into mind. Once, I ordered a update to a CAD package being used to develop sheet metal flats for a small shop I worked for. (yes, they still used paper tape, with the big discussion being mylar, or oil paper --I was in the oil for sure camp) That "floppy came all bent to Smile. Sliced the case, transplanted it into a fresh case, removed the top of the computer, and applied light pressure to the head to copy it ONCE. Thankfully, it was not copy protected.
    The whole time, flop, flop, flop.... scary stuff. Would have taken a week to get another, and we needed the patch for a model I built that exceeded some pointer size in the CAD system. Had the thing in bits, waiting to be assembled and rendered down for a 2D drawing. Was almost quicker to just draw it by hand.
    F666G
    edited 2011-04-28 07:28
    You are an old geek if you type
    LOAD MYPROGRAM
    and that means that in another room, a girl gets a spool of magnetic tape and LOADS it into the tape machine.
    edited 2011-04-28 07:34
    You might be an oldish geek, if you modified a Spool to Spool tape system to use for data storage on your microcomputer (because those fancy cassette recorders were just to expensive and did not hold enough).
  • wjsteelewjsteele Posts: 697
    edited 2011-04-28 07:40
    -- If the "POKEY" chip rings a bell (pun intended) , you might be an old geek.
    Atari guy here! Antic and Pokey rocked!!!
    - If temporarily turning off the display graphics to gain about 30% more processing speed was a valuable programming trick, you might be an old geek.
    That the only way you could get anything done in a timely fashion on the Sinclair. FAST and SLOW statements!
    Bill
  • Ray0665Ray0665 Posts: 231
    edited 2011-04-28 07:52
    Know what a disk doubler is.
    built your own paper tape reader with two pieces of wood and two led arrays, the faster you pull the tape the faster it loads, then loaded 5k basic into a scratch built z80 and know now how to recognize the block markers on paper tape as well.
    edited 2011-04-28 08:00
    homosapien wrote: »
    homosapien, that's a nice wire-wrap project. I didn't think anybody used wire-wrap much anymore. The project I worked on in the late 70's used small cards with 16 wire-wrap DIP sockets on it. These cards were wire wrapped together to create modules consisting of 2 to 6 cards. The modules were inter-connected using flat cable. There were probably a total of about1,000 wire-wrapped sockets in the whole assembly.
    Dave
    edited 2011-04-28 08:41
    I once networked 26 Atari computers to a single Atari 810 disk drive my Sophomore year of high school (1985) for the 'computer science class' ... And it was capable of expanding to 32 computers! Does that make me an old geek?
    edited 2011-04-28 09:07
    LOL!!
    uber geek is more like it. Nice project, though I would imagine the file conflicts and seek times were brutal!!
  • ajwardajward Posts: 1,130
    edited 2011-04-28 09:38
    What a neat thread...
    Very first computer... Altair 8800 A kit. Yes... toggles switches and LED's.
    Second computer... Cosmac ELF kit. 1802 cpu. 256 bytes memory.
    First "real" computer... Radio Shack TRS-80 Model 1
    My first geeky project... Disassembling the Level 2 rom by hand so I could write basic programs using assembly language. Why? Still not sure, but I suspect having no life was a major contributor. :smile:
    Amanda
  • Sal AmmoniacSal Ammoniac Posts: 213
    You might be an old geek if...
    1) You've ever dropped a 4000 card deck and spent a few hours getting the cards back into order.
    2) You know who Gary Kildall, Ken Olson, Lee Felsenstein, and Bill Godbout are.
    3) You've wire wrapped an S-100 memory expansion board using dozens of chips just to get 16KB.
    4) You have both the ASCII and EBCDIC character sets memorized. (Bonus points if you know what EBCDIC is).
    5) You know how to unjam an ASR33 teletype machine.
    6) You thought 64K of RAM is more an anyone could ever use.
    7) You were impressed by the speed of your new 300 baud modem (that replaced your 110 baud modem).
    8) You know what the "Kansas City" standard was.
    9) You remember when Byte magazine was edited by Wayne Green, had over 500 pages, and printed real content.
    10) You thought that a HAL-9000 type of system was not only possible, but inevitable, by the year 2001.
  • TumblerTumbler Posts: 323
    edited 2011-04-28 10:07
    10 for x = 0 to 1000
    20 read z
    30 poke 49152+x,z
    40 next
    100 data 120,169,13,141,20,3
    110 data 169,192,141,21,3
    120 data 88,96
    130 data 238,32,208,238,33,208,76,49,234
    sys49152
    What a great time.:cool:
    ... if this was your first PIC microcontroller databook:
    This was before GI's microelectronics division was spun off to become Microchip Technology. Most of the PIC chips back then were NMOS (which explains why the battery in my bathroom scales ran down so quickly -- well, that and the LED display).
    486 x 648 - 41K
    edited 2011-04-28 11:37
    11) You still have your copy of Dr. Dobbs Journal of Tiny BASIC Calisthenics & Orthodontia issue #1.
    12) You still occasionally type "PIP" instead of "COPY" in Windows DOS boxes.
    13) You remember when disk drives were as large as a washing machine, had 14" platters, and held 40 MB.
    14) You remember when compiling a 100 line program took four floppy swaps and 15 minutes.
    15) You thought The Woz was a god (and still do).
    edited 2011-04-28 13:18
    You remember salivating over the COSMAC Elf kits in Popular Electronics, but couldn't afford one as a poor student.
    edited 2011-04-28 14:00
    I can certainly relate to that. I spent an entire summer and fall salivating over stuff I couldn't afford. I was working on a salmon troller in Alaska and received my Interface Age magazine subscription via General Delivery in Pelican. I drooled over those ads. By the end of the fishing stint, I had just enough saved up to buy my first computer, a Poly 88 -- and, hopefully, start a software biz. After I sent my 50% down payment, it took forever to arrive ('waited for delivery each day until three...), as my remaining salmon earnings dwindled to naught. 'Never could afford a floppy drive until I started making some bucks designing hardware.
    edited 2011-04-28 15:39
    you couldn't wait to spend a lot of time at the tube tester machine at the front of the store, and turning knobs that "helped" dad test various vacuum tubes while your mom shopped for groceries.
  • wmosscropwmosscrop Posts: 409
    edited 2011-04-28 15:41
    Bean wrote: »
    If your first computer had 4K of RAM or less... you might be an old geek.
    How about 240 bytes of - ready for this - delay line memory (aka the bits in the machine go round and round) (Olivetti Programma 101).
    Does that make me a reallly old geek?
    Walter
    edited 2011-04-28 15:45
    ... if you ever tried to "align the heads" on a Commodore 1541 floppy drive, all 170K worth!
    ...if you ever bought a book on programming the 1541 (6502 assembly, 2k ram) to get around the @$#@#@ copy-protection schemes that used disk errors that caused the drive to try to reset itself which in turn forced you to have to align the heads...
    Walter
