If you ... you might be an old geek. (Everyone join in)
Bean
If your first computer used a TV and a cassette player...you might be an old geek.
If you ever spent all day repeatedly trying to get a cassette program to load... you might be an old geek.
If your first computer had 4K of RAM or less... you might be an old geek.
If you ever used a 300 baud modem...you might be an old geek.
Bean
Bean
How about 4K or less of RAM?
Still got my Hayes Smartmodem 300 around somewhere. Very solid piece of hardware. Solidity matches the Epson MX-80 (although mine was a late model III I think - it's still around here somewhere, too).
- You might be an old geek if you figured out how to boost your 300 baud modem to auto negotiate with other BBS's to a whopping 450 baud!
- You might be an old geek if you ever wrote a program that turned your modem into a war-dialer, allowing it to run all day while you were at school keeping a log of 'contacts' for you to call back later.
-You might be an old geek if you ever hacked the Atari joystick ports and used them as OUTPUTs
-You might be an old geek if you ever decoded Short wave Morse code on an Atari computer so that the message would display in readable text.
- You might be an old geek if you had a keyboard character printout of Raquel Welch ... sorry had to throw that one in there ;-)
- You might be an old geek if you are reading any of this stuff. :-)
You might be an old geek if your computer "was" the keyboard...
You might be an old geek if you can hear the connect negotiation between two modems and "know" the speed...
You might be an old geek if you know what Trumpet Winsock was...
You might be an old geek if your favorite hardware device was designed by Chip Gracey back in the 80's..
OBC
11001011 <load>
10101111 <load>
11111111 <load>
....you guys were spoiled!!! Don't tell me you........... had a keyboard and BASIC, too???
Robert
If you ever submitted a program to the computer on Hollerith cards via a service window, and got your results back in a bin with your name on the printout.
If you ever stayed up to 2 AM playing DECWAR on a 300 baud modem because DECWAR gave you so many advantages to compensate you for 300 baud play that you could smoke the guys playing at 1200 baud, even though you had a 1200 baud modem.
If you ever connected your computer to the outside world by sticking the telephone handset into a physical box that had a microphone and speaker to couple with its speaker and mic.
If you thought having an ACTUAL TV TELETYPE was the COOLEST THING EVER.
If you have any idea at all what magnetic core memory is, or ever used a machine that depended on it for anything.
If you ever used a Turing complete computer that did not have a single integrated circuit.
Or even if you ever used a computer that was not based on a microprocessor or bit-slice set.
Or even if you even know what a bit-slice set is, as opposed to a microprocessor...
My BBS was called "The Cave" and I remember the monumentous day when I upgraded the Atari 400 it was running on to dual 1050 drives and 256k of ram!!! Oh yeah... I also remember swapping out the 300bps modems with Hayes 1200 modems! I had 4 of them puppies at one time!!!
Bill
I'm just old.
If you remember using prodigy (bonus if you ever used compuserve).
If you ever played the original "prince of persia" on the apple II.
Bean.
But those are mere memories -- not even nostalgic ones, really. Screw the past: things are so much better now, and improving constantly. I mean, when was the last time anyone here ordered a datasheet by mail from a manufacturer's rep?
My first PC was a RadioShack Co.Co.II with 16k of RAM.
The Color was the coolest thing.(If you had a color TV to hook-it to)
The best part was BASIC and not DOS.
It would not turn on so I didn't get to actually play with it.
But looking at the 6502 asm language I think it would have
been a fun machine to work with...albeit pretty slow.
@$WMc%
This line in your posts
"I see why we don't have any water,All of the pipes are full of wires!"
I know it must be humorous, but I don't get it?
If you ever soldered a one-bit-wide static ram on top of another one, to get the extra bit for lower-case characters for the video display logic... you might be an old (hardware) geek.
If you had one of the original Digi-Comp plastic mechanical computers... you might be an old geek.
If you ever used Sixbit encoding... you might be an old geek.
If you ever used a computer with drum memory.. you might be a (very) old geek.
If you ever used Hollerith constants... you might be an old geek.
If you ever played music through an AM radio by putting it next the CPU and running special programs... you might be an old geek.
If you know how the Lisp primitives CAR and CDR were named... you might be an old geek.
If you still can find your Adventure International cassettes.. you might be an old geek (with a hoarding issue).
If you ever dumpster-dived for hardware, software, manuals and code listings... you might be an old (very rich) geek.
If you ever thought 256 bits of memory would "be enough", and "what's a Intel 1101 static RAM anyway?"...you might be an old geek.
DJ
(I can't believe I've saved that all these years.)
Come on, it took a long time for assemblers to catch on. We have all hand assembled code and used a hex pad to input the result (haven't we [I am young]).
This issue has over 500 pages and a hardware construction article by Steve Ciarcia!
You might be an old geek If You ever made the Snake in Qbasic "NIbbles" game, go faster... =D
I'm glad I saw the world before the arrival of the microprocessor.
Was there a paper shortage? :-)
I like asm programming but I sure do hate
trying to make sense out of disassembly
listings...uuugghhh
Hey, I know who that guy is, I always read his column in Circuit Cellar.
He's a really smart guy :-)
Steve Ciarcia wrote a column in Byte called "The Circuit Cellar" for several years before Byte forgot its roots and went all consumer. That's when he quit and started his own magazine.
Brilliant! I really wish you had a video of that experiment.
