SD card vs the USB stick
I was wondering which would be better. I know the SD card is cheaper, but uses more IO. Can you write and run prop or stamp codes on either? I just finished my Propeller RPM board for easy plug and play operation. I added a 5V regulator and a header strip with series resisor for 5V sensors. It also has a female header for rhe header strip. It has another male header row on the bottom for all the IO pins. This is plugged into a small breadboard (not visable) which in turn can be easily wired to a bigger breadboard. I went with the RPM because the memory and propeller chips can easily be removed. I already fried one. lol This will be the newist platform I am added to my Heavy Duty 3 servo robotic platform above the BS2 super carrier board platform. I am waiting for my X Bee experimenters package to arrive. You can see my robot on the Parallax robotics page.
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/usb/List/0/SortField/4/catpageindex/3/ProductID/434/Default.aspx
The SD card interface only uses 4 pins for the connection to the Propeller. It seems to be the standard for file storage for many Propeller projects and is well supported. I don't see where trying to go the USB route would save you that many pins. If you are running out of pins there are proably other ways to save them.
A great way to save pins is by using 74HC595 chips for outputs and 74HC165 chips for inputs. Three pins can get a large number of inputs/outputs that way. I'm using a set of four 74HC595's to control 32-LED's for lighting and relay control. Only takes three Prop pins.
Robert
