View Port standalone
AS
Hi!
It´s possible make standalone programs with ViewPort?
AS
AS
My other product- 12Blocks let's you make standalone programs. You can design an interface and then "save to exe". This results in a single file. Running that file will:
- start the user interface you designed
- load your firmware to the Propeller
- connect to your firmware allowing you to control things like servos, motors, lights from your PC interface, or measure things like sensors, other devices using the Propeller and display to your UI.
Give it a try!
You can use other languages to integrate with ViewPort- people have done so with python, matlab, c# and vb.net... Here's the kit: http://hannoware.com/viewport/clients.php
Hanno
AS
